[ Total Views: 40720 | Total Replies: 578 | Thread Id: 89664 ] |
Pages: 1 .. 15 16 17 18 19 20 |
essex
posted on July 15th, 2013 at 08:07 PM |
FWIW I have used the Jaycee alloy buttons with wisecos in he past with success. Engine looks great !! Nice crank and case !!
Same here with teflon buttons,
Same again, engines looking great!
humpty
Threads: 139
Mood: Totally boosted!
posted on July 15th, 2013 at 10:00 PM |
Ditto.
matberry
posted on July 15th, 2013 at 10:03 PM |
Sorry guy's, I hate buttons, glad you got the spiro-locs in. Lightest option
Lookin flash as Michael Jackson Mick
1916baja
Threads: 176
posted on July 15th, 2013 at 10:19 PM |
Quote: | Originally
posted by Stanley
Quote: | Originally
posted by 1916baja
Nope, no straight cuts. I had planned to but being on a budget I was talked out of it by a reputable builder.
Why?
Because at the time I had a certain amount of money to spend and the straight cut kit was about 170 bucks and the helical kit was about 40... I'm led
to believe the gain isn't really worth the extra outlay. The budget at the time was the biggest factor, straight cuts were not exactly necessary.
Thanks guys, I'm really happy things are moving along.
Stanley
Threads: 270
posted on July 16th, 2013 at 07:20 AM |
Cool Mick...question was in relation to performance aspects of straight cut verses helical not budget.
1916baja
Threads: 176
posted on July 16th, 2013 at 08:13 AM |
Oh, if the money was there I would have used them regardless! I like the sound! But aside from what it looks like its still a budget build, the only
reason I have all these cool parts is because I got a really good deal on them!
1916baja
Threads: 176
posted on July 16th, 2013 at 08:01 PM |
Bit more gear rolled in today!
Error |
matberry
posted on July 16th, 2013 at 08:27 PM |
Straight cut's aren't just about the noise, but I'm sure your aware of that. Being a turbo (milder cam) and a race engine you will no doubt be
doing early teardowns so as to keep an eye on cam bearing thrust wear. They do wear faster using stock gears on a performance aplication.
1916baja
Threads: 176
posted on July 16th, 2013 at 09:50 PM |
yeah I know it's not all about the sound Matt.
humpty
Threads: 139
posted on July 17th, 2013 at 02:19 PM |
Really liking the direction and choices your making Mick.... Its a very logical build with solid processes, spending where you need to, based on what
life says you can do at that time... Taking is easy and making the right moves will prove the best course in the long run.
1916baja
Threads: 176
posted on July 17th, 2013 at 05:49 PM |
Gee thanks Simon, thats some kind words! I have been pretty lucky with alot of this gear... some of its been barterd, some of it ive been in the right
place at the right time and the rest of it is just down to knowing all the helpful people in this vw drag racing scene. Without mates like Dave and
alot of the people around here someone like me really woldnt know where to start or be able to afford to do this at all, so big thanks to everyone!
Boosr gauge showed up today!
Error |
1916baja
Threads: 176
posted on July 18th, 2013 at 04:33 PM |
Shiny stuff
Error |
Sides
A.k.a.: Dave Sidery
posted on July 18th, 2013 at 04:58 PM |
Quote: | Originally
posted by 1916baja
Boosr gauge... is that the drag racing equivalent to RBT ???
Good to see the parts keep on rolling in Mick...
My toys
1916baja
Threads: 176
posted on July 18th, 2013 at 05:09 PM |
Smart arse
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on July 18th, 2013 at 06:50 PM |
You need to drop the budget build off this post, cause if your on a budget build than I'm doing a poverty build, I haven't been able to afford to
buy anything for month... Lol looking but mick, going to run warwick
Stanley
Threads: 270
posted on July 18th, 2013 at 07:22 PM |
Quote: | Originally
posted by typethreeking
X2. if you can afford shiny stuff its not a budget
1916baja
Threads: 176
posted on July 18th, 2013 at 08:22 PM |
Yeah Troy, the plan is Warwick.... Hopefully. Shouldn't be a problem unless we run into trouble. I've gotta pay all this money back! It's kinda
like a loan from myself (my wife) lol! Stanley, The shiney one was the cheapest!
FROSTY
Threads: 65
posted on July 18th, 2013 at 09:24 PM |
Time for you to have a second kid, then you can pull out the budget card
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on July 18th, 2013 at 09:37 PM |
Is the alternator one of the ebay specials mick?
1916baja
Threads: 176
posted on July 18th, 2013 at 09:44 PM |
Yeah mate, eBay special. Dave is running a similar one and it seems to do the trick.
ian.mezz
Threads: 280
posted on July 20th, 2013 at 12:21 PM |
we have 2 low budget vw drag cars .
VW case, VW heads, VW inlet manifolds and a Big VW Holley
1916baja
Threads: 176
posted on July 25th, 2013 at 08:46 PM |
Got another box from rod today! 27mm short torsion bars, oil cooler bypass, some offroad cylinder head tin that we will modify to run my fans and a
set of Scat 5.7" chevy journal rods with 3/8 bolts. The Cb ones i have need work to be used in this motor so i went with new ones....
Dave butler has had my engine and he has machined the barrels to the right length and set the deck height. Due to the restrictions of building an
engine around the header and having the wiseco b pistons we ended up with quite a bit of deck.... So compression is set at 7.5 :1 and we will run a
bit more boost than originally planned
In reality, By DB setting the compression a little lower than we had planned its bringing it back to the direction this engine was suppsed to be going
in before we started geting carried away! A nice reliable, long lasting turbo motor... Its safer this way im sure.
Error |
1916baja
Threads: 176
posted on August 3rd, 2013 at 12:29 PM |
Picked up some more gear today... the slicks are 26x6x15, going to a 5.5" rim under stock guards. They are the ones morgan put the link up for in
gatton. Cheers mate!
Error |
Error |
DavoBuggy 1641
Threads: 12
posted on August 12th, 2013 at 07:33 PM |
Hey, I'm posting some pics for Mick
I actually let him have a go on the welder today lol, and he did very well.
Here is some pics of the extra guages we mounted today. Mick also fitted his staging brake ready for us to make up some brake lines for it.
Mad Ash has also slipped a few boxes of what appears to be his whole engine in parts onto my shed floor hoping to have it all assembled before
Warwick??? We'll see..........
Cheers Dave!
Error |
Error |
Error |
1916baja
Threads: 176
posted on August 13th, 2013 at 05:09 PM |
More goods
Error |
Error |
1916baja
Threads: 176
posted on August 17th, 2013 at 11:12 PM |
Got these sweet old Skool rocker covers off the old motor from the buggy that is now daves drag buggy! They were in a pretty sad state but they
cleaned up sweet!
Error |
Error |
essex
posted on August 18th, 2013 at 12:32 PM |
looking good....
DavoBuggy 1641
Threads: 12
posted on August 18th, 2013 at 07:50 PM |
Hey, Got a fair bit done this week end. On Fri I snuck a bit of shed time and die grinded the oil holes on the main bearings and in the case so they
lined up and also grinded the 'chamfer' around the sump hole (DB Trick) to allow the oil to flow into the drop sump easily. Mick came to help out
Sat and began by cleaning the case, cam, crank, rods, lifers and laid everything out neatly, ready for assembly while I started with setting the cam
end float to .002". Had to skim a bit off the thrust washers to achieve this. Got both halves of the bearing exactly even. We then fitted the Timing
and distributor drive gears onto the crank by heating them in a tin with oil on the camp stove and knocking them into place with a tube of steel and
made our own 'dropped' pick up tube cos the one you get is, as Dave would say, Bogus.
Today we fitted all the bung's into the case where welch plugs had been removed while continuing to blow air through all the oil holes to ensure no
oil galleries were being blocked/abstructed by any of the bung's as we went. We then blocked the oil pressure relief passage at the flywheel end by
putting two pressure relief pistons plus a thin washer into the hole to block it completly and blocked off the bleed off hole from the passage at the
pully end. Two orig. VW plugs were then fitted. The reason for all of this is Mick is running a Jacee 'By pass' Oil filter housing which has
pressure relief built into it. Confident we had everything in place we continued to fit the Bearings, Crank, Dist Drive, Lifters and Cam into one case
half. Paying att to the Toyota Thrust washers on the crank shaft and adding the synthetic running in paste to the new Cam and Lifters. Put the
bearings and Lifters in the other case half painted the mating surfaces with Aviation Jizz. FITTED THE CAM PLUG and joined the beast together. Clicked
it all up and It all turn's beautifully.
Here's some Pics of the oil holes and sump hole.
Error |
Error |
Error |
DavoBuggy 1641
Threads: 12
posted on August 18th, 2013 at 07:57 PM |
Oil Pick up. No Curtain rod but it will do the trick lol...
Error |
Error |
DavoBuggy 1641
Threads: 12
posted on August 18th, 2013 at 08:00 PM |
Setting Cam End Float.
Error |
Error |
