[ Total Views: 21180 | Total Replies: 310 | Thread Id: 90915 ] |
Pages: 1 2 3 4 .. 11 |
cjbolt051
Threads: 4
posted on June 23rd, 2011 at 02:01 PM |
More pictures to come of the other works being done .
Winner best engineered vehicle 2011 @ Warwick & 2012 sydney
1/8 6.71 @ 100.9 mph Warwick 2011
1/4 10.17 @ 137 mph WSID
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on June 23rd, 2011 at 09:56 PM |
Quote: | Originally
posted by hypo-vw
Quote: | Originally
posted by Dasdubber
G'day mate, if you still have the rear firewall aside I wouldn't mind working out a way to try and get it up here. We are after one for a
restoration on a customer's beetle.
Let me know either way.
Al (Gold Coast)
Hi Al , me and Ben just went out and dug the firewall section and rear wheel arches out of the bottom of the scrap metal bin . firewall and wheel
arches are in great condition , but cant say the same for my hands lol (only a few minor sctratches ) let me know what you need and we can send them
up with Michaels oval body . Wayne
Fantastic Wayne, thanks very much for your efforts - sorry about the cut up hands! Firewall is what I am after basically (well its actually for Dave
Butler). I did need one for the customer's project however we ended up just repairing what was there due to time constraints. However Dave is still
after one so sending it up with the oval for Michael would be sincerely appreciated. Obviously happy to help contribute to costs.
Al
dangerous
Mood: 591
posted on June 24th, 2011 at 05:20 AM |
Yes, thank you gentlemen!
Quote: | Originally
posted by westi
That's mad Alan.
cjbolt051
Threads: 4
posted on June 26th, 2011 at 11:54 AM |
your welcome.
h
posted on June 26th, 2011 at 11:59 AM |
great build keep it up
warwick coming along soon
cjbolt051
Threads: 4
posted on June 26th, 2011 at 12:11 PM |
I have cut out all inner skins to the bug and am putting in a cage now..
Error |
Error |
Error |
cjbolt051
Threads: 4
posted on June 29th, 2011 at 08:39 AM |
Quote: | Originally
posted by h
thanks H .did you get home for dinner on time ... Hoping to have its first run at gunnadah but i think it will be to much of a stretch
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 04:23 PM |
Started to build roll cage from chomolly. was fortunate enough to have been lent a bending machine to do the job.
Error |
Error |
Error |
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 04:26 PM |
woo hoo ... Hey presto.. one main hoop
Error |
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 04:29 PM |
then i cut up some angles to act as cage base on the heater tunnels
Error |
Error |
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 04:32 PM |
then placed main hoop into position (got to love sticky tape) ready take sides
Error |
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 04:48 PM |
bent up side bars an sticky taped them in
Error |
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 04:51 PM |
then top and rear spreader and side intrusion bars
Error |
Error |
cjbolt051
Threads: 4
posted on July 2nd, 2011 at 05:01 PM |
all tacked together ready to go down to chris to be tig welded up
Error |
westi
what the
Threads: 28
Mood: not blue, pink
posted on July 2nd, 2011 at 10:48 PM |
Why the weird bend in the main hoop.
down sharon.
cjbolt051
Threads: 4
posted on July 3rd, 2011 at 07:18 PM |
Hi Westi..Put the bend in for more clearance to the seat and i cranked the side bars outwards towards the door for the same. Side bars and yet to be
made rear stays will both meet at the bend. this is my first attempt at a cage so it may be differant to others , but as long as it complies when i am
finished that is fine by me.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on July 4th, 2011 at 10:29 PM |
I'd double check with ANDRA tech person or rule book about cage design , the front loop bar pad looks to small ( there is a set size ) plus they are
on a hollow section ( heater tube can crush down )
Cage being welded to body might be a touchy point becouse the body can separate from pan , I know it will be tide in to floor pan at rear . It pays
just to check .
cjbolt051
Threads: 4
posted on July 5th, 2011 at 09:33 AM |
Hi peter, I am still to weld an angle from the base plates of the hoop to the pan so it can not seperate. After i have finnished setting everything
up and i am satisfied i dont need to take body of pan they will be welded in. All pipework has been set as per Andra specs and sizes.(Chromolly pipes)
cjbolt051
Threads: 4
posted on July 10th, 2011 at 07:50 AM |
Aluminium Steering wheel with quick release and Aluminium door/dash panel
Error |
Error |
Error |
cjbolt051
Threads: 4
posted on July 29th, 2011 at 09:59 PM |
Been a bit slack and have not put anything up for a while.cut out all the rust and welded in plates
Error |
Error |
Error |
cjbolt051
Threads: 4
posted on July 29th, 2011 at 10:02 PM |
welded up holes to fire wall
Error |
Error |
cjbolt051
Threads: 4
posted on July 29th, 2011 at 10:06 PM |
and a bit more rust...
Error |
Error |
cjbolt051
Threads: 4
posted on July 29th, 2011 at 10:13 PM |
here are a few pictures of us cutting off the body so it is easier to weld up cage
Error |
Error |
cjbolt051
Threads: 4
posted on July 29th, 2011 at 10:27 PM |
next i started setting up the new steering and narrowed front beam. first the now narrowed 1 1/2 inches each side beam is reasembled into the shock
tower. I had cut redrilled tortion bars to suit
Error |
Error |
Error |
cjbolt051
Threads: 4
posted on July 30th, 2011 at 07:28 AM |
then i set up a bracket for new rack to mount using an old rack i had lying around as a dummy fit.
Error |
Error |
cjbolt051
Threads: 4
posted on July 30th, 2011 at 07:35 AM |
removing the old beam and cleaning up arms for new beam
Error |
Error |
cjbolt051
Threads: 4
posted on July 30th, 2011 at 07:48 AM |
then in goes the new adjusteble front beam .... drop spindles still to come.
Error |
Error |
Error |
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on July 30th, 2011 at 11:04 AM |
Love it-keep 'em coming.Looks like you have welded the ash tray closed-where are you going to put your timeslips????
venFun10
Threads: 0
posted on August 17th, 2011 at 08:33 PM |
looking good mate
is it going to be ready for warwick?
cjbolt051
Threads: 4
posted on August 19th, 2011 at 10:31 AM |
I will make it ... may be in primer only but it will be there. lots of nights after work still to come to get it there ....who needs sleep anyway...
lol
