[ Total Views: 24847 | Total Replies: 345 | Thread Id: 91175 ] |
Pages: 1 .. 9 10 11 12 |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on November 21st, 2012 at 04:17 PM |
Quote: | Originally
posted by humpty No fuss, no theatrics, just boogie!
I think you are onto something there Simon , a new logo for Team WPVW .... lol
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
2442supercharged
Threads: 2
posted on February 27th, 2013 at 09:50 PM |
It's been a while since I done anything to the car but it is ready for dyno tomorrow with the new exhaust for dyno only
Error |
Error |
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 12th, 2013 at 08:38 AM |
after cracking another AA 94mm barrel on Bens last dyno session , we have decided to step it up a notch and purchase some better quality heads &
barrels for his supercharged engine .
In our experiences on both Chris Bolton and Ben Fords' race engines we have found that the AA barrels are very reliable / suitable for up to 250hp .
Once both engines exceeded this level of performance ( Chris 305hp @ the wheels and Ben 310hp @ the wheels ) we have had issues with the AA barrels
splitting down the top spigot , normally resulting in cylinder head damage also .
Bens new 910 Autocraft cylinder heads have arrived !! Titanium valves 50x39 & K800 springs . Ben wont use the Autocraft 1.4 rockers that came with
the heads as we will stay with his Pauter billet 1.4 roller rockers
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 12th, 2013 at 08:53 AM |
Bens new raceware headstud kit has arrived and also his new Pauter semi-modular 94mm cylinders . These cylinders have a large flat seating surface to
the cylinder head which will keep the cylinders a lot more stable under high cylinder pressure and a far better seal with the 0.060" copper head
gaskets and 6-stud configuration .
Bens Autocraft 910 heads will undergo quite a bit of machining to accept the new cylinders , which will entail removal of all cooling fins down to the
sealing surface .
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 12th, 2013 at 09:01 AM |
Ben has also now decided to go Methanol EFI injection , he has purchased a Holley style throttle body to bolt to the supercharger manifold .
He has also purchased 4x ID-2000 new Bosch injectors and a Microtech ECU
Error |
Error |
Team
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on June 12th, 2013 at 06:46 PM |
Fun times ahead!! Got to chase the boss down in that rail and keep him honest!!
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 13th, 2013 at 07:26 PM |
Bens new Pauter semi-modular cylinders are fitted to his engine to check clearances & all OK .... Ben installs the microtec ECU & loom , now
he starts the wiring to the sensors & throttle body .
We fabricate some flange plates for Bens 910 Autocraft heads and the flange plate ports are machined to the size that we want his intake ports on the
heads . I will match-port the heads after I have finished Chris Boltons' engine
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 15th, 2013 at 05:22 PM |
today I started porting Bens 910 Autocraft heads . Starting with the intake ports
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 15th, 2013 at 05:27 PM |
then the exhaust ports ....
Error |
Error |
Error |
Team
humpty
Threads: 139
Mood: Totally boosted!
posted on June 15th, 2013 at 05:45 PM |
Yeah.... They are big enough.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 18th, 2013 at 01:17 AM |
Tonight we polished the ports in Bens' Autocraft heads , then attacked them with the milling machine to cut them down to suit the semi-modular Pauter
barrels
Error |
Error |
Error |
Error |
Error |
Team
SuperOwen
Threads: 67
posted on June 18th, 2013 at 06:33 PM |
Interesting port design, whats your rationale behind siamesing the ports like that rather than keeping them individual? Certainly out of the box
thinking.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 19th, 2013 at 10:47 AM |
Bens barrels are bolted to his heads with the 5th & 6th smaller studs , then are located onto the headstuds to check alignment prior to drilling
the cylinder heads for type-1 stud pattern
Ben removes his engine & transmission last night to install his new aluminum spool
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 20th, 2013 at 10:12 AM |
last night was transmission night at WPVW . Ben removed his transmission so that I could install his new aluminum spool . After many passes over the
past 4 years the ring & pinion still look great .
The new aluminum spool & chromoly drive flanges gives Ben a bit more piece of mind that the transmission will cope with the added power he is
searching for from his supercharged engine
Error |
Error |
Error |
Error |
Error |
Team
posted on June 20th, 2013 at 11:00 AM |
What brand of spool did you go with Wayne?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 20th, 2013 at 01:53 PM |
Quote: | Originally
posted by LIFE IN THE LOW LANE
Ben purchased his new aluminum spool from Rancho Transmissions in USA . It is an 091 2-litre style , which required the replacement of all associated
diff parts (except the crownwheel) to fit into the 002 transmission
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 21st, 2013 at 12:40 AM |
tonight Ben installed his transmission & connected everything at the rear of his bug , he finished the wiring for the Microtech EFI , then he
fabricated new flange plates from aluminum as that is what we will fabricate his new plenums from
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 25th, 2013 at 09:15 AM |
I bolt Bens new Pauter barrels to his cylinder heads , align them with the headstuds in the engine case , then tighten them in position so that I can
drill the heads to type-1 stud pattern as the Autocraft pattern has approx 2mm further stud spread pattern on each stud . I use the barrels as a guide
to ensure correct alignment . To do this Allan extends & machines a new drill bit for me .
After the heads are drilled I find that No.3 barrel has to be clearanced on the fins to clear the engine case .
After the barrels are clearanced and installed I find the cylinder head gaskets need to be hand-filed to elongate the stud holes for the smaller 5th
& 6th studs .
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 25th, 2013 at 09:23 AM |
Bens' Autocraft heads are prepared & assembled . The pistons are installed into the new cylinders , the cylinders are painted & the top end
is assembled
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 26th, 2013 at 01:58 AM |
today we started to fabricate the plenums for Bens' engine & Morgan was kind enough to come and glue them together for us with the TIG .
Bens' engine will be finished & installed tomorrow
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 30th, 2013 at 08:03 PM |
I shim the Pauter rocker assemblies to offset the exhaust rockers to suit the 910 Autocraft heads and find that I have to replace Bens pushrod tubes
also with wide-mouth tubes to ensure that the pushrods don't rub on the tubes
next problem was Bens pushrods are way too short for his new head & cylinder comination . We contact everyone reputable that we know to try &
find a set of really long pushrods (296mm) with no luck at all . We send Chris Bolton to CBB as Mike has a long set of pushrods , but we find that
they are 4mm too short !! (thanks for your assistance Mike)
So we send Bens parents to Sydney Thursday morning to purchase & collect 3mtr of 3/8" chromoly thickwall tube & to collect a 205ltr drum of
methanol . They took Chris Boltons T4 transporter , after collecting the fuel & the tube they are on their way back to WPVW when they break down
at 3pm in Liverpool (Sydney) . An hour later we organise a tow truck to go to Liverpool to collect them & the transporter . At 7-30pm they arrive
at WPVW , the transporters alternator decided to stop working & the old battery failed !!
I cut the chromoly tube into lengths & Allan picks them up , takes them to his machine shed & makes the new set of pushrods for Bens engine
Chris Bolton starts to fabricate fuel hoses for Bens new Boss EFI
Friday morning the battery is changed and the alternator has new brushes installed , the transporter is alive again.....
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 30th, 2013 at 08:11 PM |
Ben installs his engine ..... with help from Chris
Error |
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 30th, 2013 at 08:29 PM |
Ben Ford starts his engine with Pauter cylinders , Autocraft 910 heads , Boss EFI methanol injection & Microtech ECU
http://www.youtube.com/watch?v=ojNuPQmFOCY
Team
cnfabo
Threads: 140
posted on June 30th, 2013 at 10:57 PM |
Love what comes out of the wpvw factory,love it....good luck at Warwick guys
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on July 1st, 2013 at 12:31 PM |
You guys never fail to amaze me...........awesome work.
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
posted on July 2nd, 2013 at 12:11 AM |
Gotta love the blower lope
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 24th, 2013 at 05:54 PM |
A quick update on Bens Supercharged bug ...... after getting Bens bug running we took it to South Coast Rotary (SCR) for a run on the dyno to set up
the new Microtech EFI & the MSD ignition .
We did quite a lot of set-up and did approx 20 power runs before Kevin @ SCR pulled a little too much fuel out of the mid-range on the tune and the
engine pinged heavily at approx quarter throttle ..... He got off the throttle immediately but the head gasket on No.1 cylinder had moved , so it was
back to WPVW for head removal .....
several days later we removed the head from Bens' engine & all is well . No damage at all , just the copper gasket got too hot /soft and shifted
. We install 2 new head gaskets and head back to the dyno .
We do approx 24 power runs on the dyno again , but cant get Bens' engine to make power !! It makes 332hp@ the wheels at just 4500rpm , but wont
breath after that . Now that the blower is 50% overdriven , we are seeing 29psi boost . We are sure that the manifolds that I have fabricated for the
supercharger are too small as it makes the boost really early but doesnt maintain it in the higher rev range . We are going to fabricate a new upper
manifold between the injection throttle body & the blower over the next week , and then put Bens bug back on the dyno . If we don't see a
substantial improvement we will then fabricate a new lower manifold between the blower & the plenums
Team
LOWBUG
Threads: 33
Mood: OUT OF CONTROL
posted on August 26th, 2013 at 02:50 PM |
What size injectors are you guys running in Bens engine?
2442supercharged
Threads: 2
posted on August 26th, 2013 at 06:38 PM |
We use Bosch id2000 injectors
Frallan
Threads: 0
posted on September 2nd, 2013 at 11:43 AM |
On the note of the headporting, I thought it was fun.
A famous Swedish tuner Klas Ebbenäs (RIP) built a SC dragster engine way back 25 plus years ago.
He did them out of billet.
Look how he ported them and this is how the engine stands today in storage in South Sweden.
Error |
Error |
