[ Total Views: 24875 | Total Replies: 345 | Thread Id: 91175 ] |
Pages: 1 2 3 4 5 6 .. 12 |
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on September 6th, 2011 at 09:39 AM |
Quote: | Originally
posted by hypo-vw
Ben spends many hours on the cylinder heads porting & polishing . The exhaust ports have been increased in diameter by 4mm just to match-port them
to the exhaust flanges .
Fantastic work.
You could get the poor bastard a bench to work on - or at least a stool to sit on. :-)
From your ole' mate Jeff
venFun10
Threads: 0
posted on September 6th, 2011 at 02:09 PM |
Quote: | Originally
posted by beetleboyjeff
Quote: | Originally
posted by hypo-vw
Fantastic work.
he must be just blowing the heads down
no way will anyone port heads like that
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on September 7th, 2011 at 11:29 PM |
the new Pauter super-charger camshaft and the Udo Becker 56gm tool steel racing lifters have arrived
Error |
Error |
Error |
Error |
Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 8th, 2011 at 11:56 PM |
Ben assembles his engine in prep for warwick . This time we have decided to machine-up a set of aluminum buttons for the piston pins rather than use
clips .
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 9th, 2011 at 12:07 AM |
the engine is finished and will be put back into Bens bug before the weekend . We still have a lot of work to do fitting the Aeromotive fuel pump ,
filter , regulator , the demon alcohol carburettor , all new fuel hoses and fittings , all new oil hoses and fittings , and new breather hoses etc
Error |
Error |
Error |
Error |
Error |
Team
Stanley
Threads: 270
posted on September 9th, 2011 at 06:29 AM |
Lookin' good Wayne and Ben
and Mr venFun10....man you need to smile once in a while. I see your name in a lot of posts and you seem a little negative.
20bkombi
Threads: 26
posted on September 9th, 2011 at 03:44 PM |
Good work Ben! Love to see pic's of port work and engine builds.
Will be awesome to see it run again.... And with more power too.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 14th, 2011 at 12:26 AM |
Chris Bolton gives Ben a lift with the supercharger , Ben then finishes the engine assembly
all of the new Aeroflow fuel & oil fittings have arrived , along with the stainless steel braided hoses
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 14th, 2011 at 12:36 AM |
Ben fits his engine to his beetle , we then start to assemble the fuel system . There will be no shortage of fuel supply to the carburettor as the
main fuel line is 15mm diameter on the inside . The fuel lines alone hold just over 2 litres of methanol
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 14th, 2011 at 12:44 AM |
I remove the fuel bowls from the new Demon carburettor to check the internals and jet sizes . The are 4 main jets ( 2x primary & 2x secondary )
all measuring 3.75mm each ...... geez I hope we dont have to richen the mixture . lol
we also purchase a set of Aeroflow assembly spanners to avoid scratching the new fittings
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 14th, 2011 at 12:52 AM |
IT IS ALIVE !!
Ben has done a great job on his engine . We fired the engine after gaining oil pressure and it sounds awesome . No oil or fuel leaks . We will have
Bens bug on the dyno early next week and will post results . getting excited for Warwick again this year . Bens new supercharger pulleys now have the
blower at 21% overdriven .... should be exciting for him !!
Error |
Error |
Error |
Team
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on September 14th, 2011 at 07:37 AM |
Nice one guys!! Almost one car done how many more to go?? Love your dedication that's for sure!!
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 14th, 2011 at 08:19 AM |
Quote: | Originally
posted by LIFE IN THE LOW LANE
2 out of the 5 cars that we are preparing are almost complete . I still have 2 modified trannys to build , the engine for my turbo oval will go back
together tonight , Chris Boltons turbo engine is assembled and Cindys turbo engine bottom end was assembled last night ..... very tired , but still
very passionate about what we do
Team
posted on September 14th, 2011 at 09:18 PM |
I take my hat to your commitment to getting so many cars ready and the lengths you go to get them all there ready to race!!
mactaylor
Mood: even my dog is german
posted on September 14th, 2011 at 09:25 PM |
your a nut, hat off to you wayne, good shit!
EVERLAST CONCRETE TANKS
1800 552 123
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2011 at 01:39 PM |
we put Bens bug on the dyno at South Coast rotary . The engine is not making as much power as we would have liked , I was quietly hoping for approx
230 @ the wheels and about 20psi boost , but the old supercharger is buggered . The additional boost developed this time after gearing the blower up
is escaping into the front gear drive .
This time Bens engine made 212.8 bhp & just over 1210 lbs tractive effort @ the wheels with 12psi boost . That is all we can do on his bug for
Warwick this year , but he should have a great time with the added power and torque . Well done Ben !!
Error |
Team
SuperOwen
Threads: 67
posted on September 25th, 2011 at 01:06 PM |
Time for a new blower,
http://www.psisuperchargers.com/store/product/show/cid-1043/name-206c-superch...
Should be about right!!
dangerous
Mood: 591
posted on October 3rd, 2011 at 06:58 AM |
Good on you Ben!
Not only did you get into the finals this year but also into the 7.0 zone from what i heard!
Quote: | Originally
posted by westi
That's mad Alan.
posted on October 3rd, 2011 at 02:27 PM |
Congrats Ben on making the final!! Car ran great all weekend from what I saw!!
2442supercharged
Threads: 2
posted on October 3rd, 2011 at 09:51 PM |
i would like to thank everyone from WPVW for all there help over the weekend my car ran great all weekend running 7's every run done a best of 7.047
60ft 1.523 reaction .645 98.46mph i did do a pass at 100.22mph. i pulled the clucth out a bit to fast in final and bogged it really bad and ran my
worst time of weekend with a 7.976 maybe i will do better next time. once again thanks a heap to everyone that gave me a hand
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on October 3rd, 2011 at 10:10 PM |
Well done Ben!!!!! all your hard work was rewarded!!!!!!
2442supercharged
Threads: 2
posted on October 7th, 2011 at 11:44 AM |
vid of me running a 7.0 at 100 mph
http://www.youtube.com/watch?v=qhYGUNkK4l0
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 10th, 2011 at 10:43 PM |
vid of Bens supercharged bug on dyno
dyno session prior to Warwick VW drags 2011
http://www.youtube.com/watch?v=0rTWZaTXwtY
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 12th, 2011 at 01:03 PM |
Warwick 2011 timeslip
Well done Ben on your very consistant driving and great to see you do so well after the past 2 Warwick VW drags had been a nightmare for you .
Bens times for the event ( in order ) were .... 7.13 @98.46 .... 7.04 @ 98.46 .... 7.34 @ 95.33 .... 7.11 @96.56 .... 7.21 @ 99.77 .... and in the
final of the Top 10 shootout against Wally Pemboss , Ben buggered the start and the engine bogged unfortunately running his slowest time of the event
7.97 @ 98.90 .
Again , WELL DONE BEN !! from team WPVW .....
Error |
Team
2442supercharged
Threads: 2
posted on November 20th, 2011 at 09:01 PM |
took my car to wsid today for the retro day running in top gas class ran a best of 11.001. today was so good had 3 runs no problems with the car and
also came home with a winner trophy just like to thank my crew for all
there help
2442supercharged
Threads: 2
posted on February 27th, 2012 at 09:08 PM |
i had a great day at sydney vw day running a PB of 10.784 @ 110MPH not being inspected to run 10,s i had to keep backing off running 11.3 and 11.2
untill my engine developed a rattle in bottom end which i found out tonight to be streched con rod bolts so i will be stripping engine right down for
a freshen up
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 18th, 2012 at 07:23 PM |
Quote: | Originally
posted by 2442supercharged
FACT !! ..... the only thing changed on Bens supercharged drag bug between the last 2 meetings he ran was the new accelerator pedal I made for him
go figure ? a new pedal = 2tenths on the strip , Ben reckons the pedal was much lighter !!
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 18th, 2012 at 07:30 PM |
so i will be stripping engine right down for a freshen up
so Ben has gone a little overboard with the freshen up of his supercharged drag bug . My office seems to be a little crowded atm . He has stripped the
bug in preparation for the new chromoly rollcage , removed both the engine and transmission for a refreshen ..... and I hear a viscious rumour that
there is a new supercharger on the way
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 18th, 2012 at 07:34 PM |
Bens bug is stripped down
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 18th, 2012 at 07:37 PM |
Ben cuts all the double panel from his bug to lighten it prior to fitting the new cage
Error |
Error |
Error |
Error |
Error |
Team
