[ Total Views: 24874 | Total Replies: 345 | Thread Id: 91175 ] |
Pages: 1 .. 3 4 5 6 7 .. 12 |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on June 18th, 2012 at 07:39 PM |
Ben cuts even more from his bug !!
Error |
Error |
Error |
Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
cam070
posted on June 18th, 2012 at 07:48 PM |
That's what I call putting a car on a diet!
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on June 18th, 2012 at 10:08 PM |
That accelerator pedal looks expensive.
From your ole' mate Jeff
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on June 18th, 2012 at 10:33 PM |
Wow....so what is the weight of all the removed metal ?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 19th, 2012 at 12:42 AM |
Quote: | Originally
posted by beetleboyjeff
the pedal might look expensive but I told Ben , 'THE HARDER YOU PUSH THAT PEDAL , THE MORE IT IS GONNA COST' .....
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 19th, 2012 at 12:47 AM |
Quote: | Originally
posted by Craig Torrens
we haven't weighed all of the removed metal as yet Craig , but Ben and Chris tried to weigh Bens old supercharger with manifolds and NO carburettor
..... my digital scales only went to 30kg , we estimate that it weighs a whopping 35kgs . There will be a heap of weight saving with a new blower and
alloy intake manifold system alone .....
Team
20bkombi
Threads: 26
posted on June 19th, 2012 at 07:48 AM |
Good work Ben, love the pedal !!!
Nice to see a cage going in.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 20th, 2012 at 11:48 PM |
with the assistance from Chris Bolton , Lincoln Jackson and myself , Ben gets a start on his new chromoly cage
strengthening feet are manufactured for the cage legs and welded into place . additional plates will be welded to these and attached to the floorpan
assembly .
The main hoop and front legs are formed from chromoly tube and fitted in place to be tach welded
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 20th, 2012 at 11:53 PM |
the front half cage assembly is looking very good ..... Ben has made great progress in the past couple of days
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 27th, 2012 at 10:42 PM |
Ben has made more progress on his bug , however judging by the following pics it actually looks like he has gone backwards , but the bug has to be
disassembled for cage welding prior to reassembly . Had the ANDRA tech inspector at WPVW to take a look at the progress on Bens bug and he is happy
with what he see's so far .
We manufacture a nice strong seat mount for Ben and weld it into place
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 27th, 2012 at 10:46 PM |
the body is cut and removed for ease of cage manufacture and welding of all the upper pipes . The body only had to be in place for the main hoop and
front legs to be manufactured , all other bars wont require the body to be fitted at this stage
Error |
Error |
Error |
Error |
Error |
Team
20bkombi
Threads: 26
posted on June 28th, 2012 at 05:44 AM |
Great work guys, coming a long very nice!!
Funny, I'm at the same stage with the type 3.
Looks like you are enjoying the bar work as much as me, it all comes together so fast.
Good idea chopping the a pillar and rear sill to remove the body to allow easy welding,
Better than slipping the hoop through the floor to weld and then trying to get around the body to do the rear stays can be tricky.
Keep it up!!!
Ph 0402 233 027
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on June 28th, 2012 at 10:30 AM |
Mr Andra man didn't mind main cage going to body sills (sill can collaps or bend) not the chassis of car , plus if body comes loose or falls off cage
strength is compromised .
I hope the rest is tied into chassis ( front and rear of car and side legs to tunnnel )
What was the bottom rear wards band in main loop for ? you will have to strengthen that area .
I think seat should be tied into chassis and roll cage not sill as it will bend or collapse , then you move then seat belts come loose ( put across
bar from front and rear main loop then seat mounts to it )
These are things I found when doing my cage ( yes every tech person has there own ideas )but I was told a beetle should be
thought of as a full chassis car as body can come off in a accident ( race cars are cut up, most don't have standed number of bolts or standed
strength any more )
The sills and floor are very thin tin , so can be punched or collapse through in a big hit , thats why you should think of car as a full chassis style
car .
Sorry for sounding negative (but a person rides along in side and cars
are becoming lite weight and much faster .)
Cheers Peter P
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on June 29th, 2012 at 06:49 PM |
Pee, i think i remember the cage that brad did for the vwma rat( ben's car) has the bar work running around the inside edge of the sill's and the
hoops attach to that and not the sill itself....Good point.
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on June 29th, 2012 at 08:56 PM |
ill have to check!!! I think mine are in the sills at the front but infront of the door pillers but on built up brackets sitting half on the pan half
on the sills!!!
Im pretty all this was bought up when chris bolten made his cage, and it turned out alright
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 29th, 2012 at 09:42 PM |
Quote: | Originally
posted by whathaveidone
yes you hit the nail on the head with that comment Ben ..... Bens cage is an exact replica of Chris Boltons cage and the same people made the same
remarks when his cage was being built also ..... Chris' cage has turned out awesome and the tech inspector was really happy with it as the strongest
point along the side of the beetle chassis is the heater tunnel area , and when you tie the cage mounting feet with additional plates into the
floorpan as we have done with Chris' mountings (and will do the same with Bens') , this is a far stronger method than fixing straight to the pan
with a plate as it can easily punch through on a high impact situation .
Ben is going to run really quick and I want the car safe for him .
Team
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on June 29th, 2012 at 09:46 PM |
Exactly... The WPVW team know what they're up to
Good stuff again!
I personally would like to see the windows score a black edging while they're out to cover the green mounting tabs..... They always looked a bit
funky compared to the standard of the rest of the car. My 2cents worth right there!
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on June 29th, 2012 at 11:43 PM |
Quote: | Originally
posted by hellbugged
I agree with you about the windows ..... Ben did say to me already that he was going to paint the black strip around the windows .....
We did have an official at WSID ask us to do that as he was working at the start line area and every time Ben came out to race it looked like the
front screen was missing
Team
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on June 30th, 2012 at 12:54 AM |
No one said they didn't know what they where doing or am I the person (same people ) making comments again , Guys .
As there is many ways to do things , it is all ways good to point out other idea's as well .
Yes , I know your not finished yet but it's good to take in and look at how other Pro's builders build race cars to , Wayne .
All good .
As long as Andra tech guy is happy .
westi
what the
Threads: 28
Mood: not blue, pink
posted on June 30th, 2012 at 10:37 AM |
nah troy it is my car that has the bar along the floor.vw floors and seals are shit.so i thought i would have a crack at making it better.
it is funny how different people do things and swear that they know what they are doin.we all have our reasons.
usually when you look back at what you were doing 5 or so years ago.you realize .
i haven't seen a cage that andra didn't tech.as long as the welds are good and there is a plate on the floor,it will pass.
your only as good as your last job and you can only hope to get better every time.
down sharon.
2442supercharged
Threads: 2
posted on July 2nd, 2012 at 07:59 PM |
i have ordered my new supercharger for my car i went with a whipple twin screw type it should be here in 5 weeks or so. i am hoping to have the cage
and engine rebuilt be than or close to it so i can get started on making the new intake system. will post pics of blower when it turns up
dangerous
Mood: 591
posted on July 2nd, 2012 at 09:17 PM |
What model and size did you order Ben?
Quote: | Originally
posted by westi
That's mad Alan.
2442supercharged
Threads: 2
posted on July 2nd, 2012 at 09:29 PM |
Whipple W140AX Supercharger (2.3 liter) / Black / Direct Drive WSC-140AXB-DD
is what i was recommended by the whipple dealer
20bkombi
Threads: 26
posted on July 5th, 2012 at 01:57 PM |
Can't wait Ben!!!
That supercharger looks the goods, though I'm not so familiar there sizing, sure you've got it sorted.
What's the latest??
Ph 0402 233 027
dangerous
Mood: 591
posted on July 5th, 2012 at 02:22 PM |
Quote: | Originally
posted by 2442supercharged
That is a great choice,
and plenty big enough to get you into the nines!
Perhaps even better if you can get it as light as Chris' car!
Would love to see more progress pictures of the cage.
I liked how well Chris' came out,
so it will be good to know that you will be safe with all that power!
Quote: | Originally
posted by westi
That's mad Alan.
2442supercharged
Threads: 2
posted on July 5th, 2012 at 06:27 PM |
i had to wait for more pipe to turn up which it has today so i am working on the cage tonight. will post pics as soon as i can.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on July 6th, 2012 at 10:33 PM |
after all the cutting and grinding of the body , Ben gives it a good clean to ensure that the grit doesnt leave rust stains on the paint .
and as Ben mentioned , we ordered another lot of chromoly tube in for his cage and it arrived yesterday . Last night Ben made a few more bars for his
cage and I cut them on the milling machine so that the joins would be a true fit .
Error |
Error |
Error |
Error |
Error |
Team
whathaveidone
Threads: 98
posted on July 6th, 2012 at 10:37 PM |
WOOOHOOOOO finally some naked women on here
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on July 6th, 2012 at 10:41 PM |
more progress pics of Bens build
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on July 6th, 2012 at 10:45 PM |
a couple more pics of Bens build ..... tomorrow we will continue work on his cage
Error |
Error |
Team
