[ Total Views: 24894 | Total Replies: 345 | Thread Id: 91175 ] |
Pages: 1 .. 5 6 7 8 9 .. 12 |
2442supercharged
Threads: 2
posted on September 4th, 2012 at 11:49 PM |
more pics
Error |
Error |
Error |
dangerous
Mood: 591
posted on September 5th, 2012 at 10:41 AM |
Nice updates Ben and Wayne.
New set up should have pick-up!
You will be amazed how much fuel a blown car can handle.
Mine was using metanol at about 18lt/min at 7000 rpm, which was about 9lt per run.
This was with the blowers supplying about 4.55 lt of air per revolution.
This information may help when you choose a fuel supply system.
Quote: | Originally
posted by westi
That's mad Alan.
20bkombi
Threads: 26
posted on September 5th, 2012 at 11:13 AM |
Nice progress Ben. Looks like a full set of albins gears, but no super diff or spool?
Are you running the same engine combo this year?
Just a few more late nights to go.... Keep up the good work Ben
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
2442supercharged
Threads: 2
posted on September 5th, 2012 at 12:38 PM |
yeah it is a full set of albions gears with a welded diff and i am running the same combo as before not changing anything still a few nights to go i
should have the enigne done tonight than start on manifolds thursday
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on September 5th, 2012 at 03:15 PM |
Lookin good Ben, should be good to have a blower that doesn't leak boost pressure, what sort of boost do you think it will make??
2442supercharged
Threads: 2
posted on September 6th, 2012 at 12:53 PM |
i am hoping to run 20 to 25 psi
humpty
Threads: 139
Mood: Totally boosted!
posted on September 6th, 2012 at 01:46 PM |
Quote: | Originally
posted by 2442supercharged
yeah it is a full set of albions gears with a welded diff.....
I thought welded centres were not allowed?
2442supercharged
Threads: 2
posted on September 7th, 2012 at 01:07 PM |
i check the rule book and i could not find anything about it
humpty
Threads: 139
posted on September 7th, 2012 at 05:28 PM |
It is something that came up at Kwinana last year.... One of the tech guys at the track was talking to another racer about it.... It could will be
untrue, but worth finding out for sure I reckon....
Maybe some of the more tech savvy/aware racers here will be able to clear it up?
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on September 7th, 2012 at 05:31 PM |
How would they ever know?????
scrutineering guy Q. Is that Diff welded???
racers A. No
scrutineering guy. Ok
2442supercharged
Threads: 2
posted on September 7th, 2012 at 06:40 PM |
i have never been asked about the diff
dangerous
Mood: 591
posted on September 7th, 2012 at 07:45 PM |
I was going to keep my mouth shut about this
because I would prefer to make only positive contributions, but...
Welded diffs are not legal for andra sanctioned events. (it IS in the rule book)
It is ones personal choice whether they lie about it or not,
as is your safety, which is the reason they are disalowed.
Correctly made spools are not expensive when compared with other race car parts,
and can be purchased either here, or in the USA.
They are also a good way to eliminate the weak cast IRS iron factory carrier
that I have broken before when I used to run super diffs.
Locally, Dave Stoker has made some, and I am also sure that Albins makes a solid shaft
that will run through the stock carrier, or one of their own billet steel superdiffs.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 7th, 2012 at 10:14 PM |
Cant seem to find the rule I spoke of in the current rule book.
Perhaps it was a repressed memory from an older time!
Anyone concerned should perhaps ring ANDRA's tech line.
If it were me, I would, as a minimum, get a steel hemisphere cover to replace the factory cast one.
Make sure the welding and housing is regularly mag particle crack tested.
Quote: | Originally
posted by westi
That's mad Alan.
modnrod
Threads: 50
Mood: Old School Volksies!
posted on September 9th, 2012 at 06:13 AM |
Quote: | Originally
posted by dangerous
I think it's under the General Safety Regulations for SS/SST in the rear of the book (at work so can't check ATM) Dave.
A throwback to the "good-old-days" when every second Chevyshit with C-clip axles would throw a 28x10.50x15 and Centreline in a graceful loop over
the heads of the startline crew coz the welded diff strained the axles........
Having said that, I'm with Dave. Personally I wouldn't be comfortable with it, coz I've had to catch a car that speared into the wall at 100MPH
when an axle broke, and that was with a spool, which gives a fair bit more leeway.
But hey, race and have fun man, each to their own I guess.
2442supercharged
Threads: 2
posted on September 9th, 2012 at 05:40 PM |
Quote: | Originally
posted by modnrod
Quote: | Originally
posted by dangerous
can you plase give me a page number as i have looked over book and can not see where it says no welded diffs
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on September 9th, 2012 at 08:22 PM |
Quote: | Originally
posted by modnrod I've had to catch a car that speared into the wall at 100MPH when an axle broke, and that was with a spool, which gives a fair
bit more leeway
please explain how a solid spool has a bit more leeway than a welded diff when you break an axle . We are on a public forum here where others read and
learn from our advise . Thanks , Wayne
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
modnrod
Threads: 50
posted on September 10th, 2012 at 06:15 AM |
I meant a mini-spool on a 9" diff Wayne, sorry for any confusion there! Turning into the pit bay you can hear the centre ratcheting and going
clunk-clunk-clunk as you turn in a bit, whereas with a solid diff the tyres just chirp and squeal coz it's all locked.
As you know, with a solid centre of any kind, when you break an axle the problem isn't so much losing drive to one side of the car and getting driven
sideways under power, it's more of a shock when you lift off the throttle (uhmmm, as you do when something goes BANG! ), and the car now spears in the opposite direction just as quick. The only way
to keep them fairly straight is to try to hold a steady throttle foot and get on the brakes smoothly to pull them up. The difference between a welded
centre and a machined solid centre is also the metallurgical properties changing on the welded steel, something Dangerous referred to.
Hopefully others on this public forum can now understand why I personally don't like them much.........then again, I always was a bit of a
scaredy-cat.
I didn't mean to jump on anyone's party here, I used to run a welded Banjo diff in a 308 Torana for a while, and most people know how strong those
things are.........NOT!!! At least with the VW your wheel and axle
aren't gonna fly off into orbit. Apart from the handling issues there aren't any safety dramas with a VW, but then again I'm not an ANDRA tech guy,
so it's not my decision to make. You guys do what you feel comfortable with, and have a good race.
whathaveidone
Threads: 98
posted on September 10th, 2012 at 06:42 AM |
that still does not make any sence????? A spool locks the centre, so the inside wheel is always going to "chirp".mine always does!!! It makes no
difference to an axle wether the center is welded or a spool if there is enough power its going to break regardles.
modnrod
Threads: 50
posted on September 10th, 2012 at 01:24 PM |
I said mini-spool.
I don't have to say "do what you feel comfortable with" again........
*sigh*
I'm bored with it all, wish I'd never said anything.
By the way Ben, I love your car man. Blown Bug's have a soft spot in my heart, and yours is a really nice one, I'd love to hear the thing make a
pass.
Enjoy.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 12th, 2012 at 08:25 AM |
well we ran into a small issue with Bens' engine ..... when washing all parts for reassembly we discovered that the gudgeon pin on No.3 cylinder was
bent and had flogged the piston . There is approx .003" ovality in the piston boss which allows the pin to float excessively . This is on the
cylinder where the rod came loose .
After a quick ring around to some reputable VW drag racers , no AA or Wiseco pistons could be located in 94mm . So Ben has ordered a set of 94mm JE
race pistons from US and are expected to arrive tomorrow .
Meanwhile I have continued with fabricating manifolds for the blower and Ben has concentrated on the body / interior .
The window net , parachute , new blower pulleys and other items have arrived for Bens' bug and he has also lashed out and ordered a RLR rev-6 dual
disc clutch assembly , which will arrive in a couple of days .
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 12th, 2012 at 08:42 AM |
more progress pics
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 12th, 2012 at 08:46 AM |
more progress pics
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 12th, 2012 at 08:50 AM |
more progress pics
Error |
Error |
Error |
Team
humpty
Threads: 139
posted on September 12th, 2012 at 09:59 AM |
Wow that's some fancy stuff there Wayne!!!.... Ben is investing in some nice toys and quality work.
dangerous
Mood: 591
posted on September 12th, 2012 at 10:57 AM |
MAN, even I am getting excited about this upgrade!
Quote: | Originally
posted by westi
That's mad Alan.
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on September 12th, 2012 at 11:22 AM |
In the words of dangerous "salubrious"!!!!! lol
typethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on September 13th, 2012 at 06:37 PM |
Looking good ben, hope all goes well for the lead up to Warwick.... Did I mention you've only got two weeks....
2442supercharged
Threads: 2
posted on September 17th, 2012 at 06:19 PM |
more progress
Error |
Error |
Error |
2442supercharged
Threads: 2
posted on September 17th, 2012 at 06:20 PM |
new clutch and pistons have turned up
Error |
Error |
Error |
Error |
Error |
2442supercharged
Threads: 2
posted on September 17th, 2012 at 06:22 PM |
body ready for paint
Error |
Error |
Error |
