[ Total Views: 24886 | Total Replies: 345 | Thread Id: 91175 ] |
Pages: 1 .. 6 7 8 9 10 .. 12 |
2442supercharged
Threads: 2
posted on September 17th, 2012 at 06:23 PM |
manifold pics
Error |
Error |
Error |
Error |
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on September 17th, 2012 at 07:07 PM |
Looking great!!!
essex
posted on September 17th, 2012 at 07:59 PM |
Lots of nice stuff there Ben, good luck with it all,
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2012 at 08:35 AM |
the bodywork is completed on Bens bug and he masks the wiring and cage so that paint can be applied . His bug is then taken to the panel shop for
final prep and paint .
Error |
Error |
Error |
Error |
Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2012 at 09:54 AM |
top end assembly starts with honing 0.0025" out of the barrels to gain the correct piston skirt to cylinder wall clearance and the gaping of all the
piston rings , then assembly of pistons and cylinders .
I love Bens new piston ring set with a 1mm top ring , 1.2mm second ring & a 2.8mm oil ring . When gaping the rings I have never felt top piston
rings so hard ..... they will certainly take some punishment and it was visablely noticable how reduced the friction is on the cylinder wall with the
narrow ring set
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2012 at 09:58 AM |
a CSP oil pump relief cover will be used with an oring sealed oil pump this time . the engine is assembled and the blower manifolds are welded up
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2012 at 10:23 AM |
our plans with Bens' bug changed a little this morning with the panel shop stripping all of the stickers and preparing the body for a full respray
inside & out
Error |
Error |
Error |
Team
humpty
Threads: 139
Mood: Totally boosted!
posted on September 20th, 2012 at 10:24 AM |
Did notice the removal of the inner skins there Ben?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2012 at 02:12 PM |
Bens drag bug is painted
we got Bens' bug back this afternoon and it looks great after being painted . The paint is a perfect colour match to the doors & front end , but
is far better quality than the first paint job
Error |
Error |
Error |
Error |
Error |
Team
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on September 20th, 2012 at 03:13 PM |
Looks good guys!! Glad you kept the same colour!! Nice and different!!!
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 20th, 2012 at 11:46 PM |
tonight Ben removed all of the covers from the cage and suspension ..... his bug looks great !!
Ben then started to reassemble his bug , starting with the fuel system . The fuel tank , pump , filter & lines have all been reinstalled while I
fitted his pushrod tubes and valve gear & adjusted the tappets . Tomorrow night reface the supercharger plate as it has distorted through the
welding process , install the supercharger & fit the engine back into his bug
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 25th, 2012 at 05:16 PM |
we have been doing heaps of fabrication work with Bens new supercharger manifolds and progressing with his bug .
fitted the new window net and mounting kit
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 25th, 2012 at 05:24 PM |
Bens new RLR rev-6 dual disc clutch assembly , the old 200mm clutch assembly looks huge compared to the 150mm RLR clutch discs
Error |
Error |
Error |
Error |
Error |
Error |
Error |
Error |
Error |
Team
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on September 25th, 2012 at 05:40 PM |
Nice work Wayne and Ben - really looking forward to seeing it run this weekend!
Al
tar76
Threads: 95
posted on September 25th, 2012 at 05:55 PM |
Thats some awesome work there fellas! I to are looking forward to watching this hammer down the strip.
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 25th, 2012 at 06:31 PM |
on saturday night we ran into a problem with the new RLR clutch assembly . The clutch assembly was striking the clutch fork casting area in the
transmission housing , leaving the engine approx 3mm from the transmission . It was later discovered that the clutch assembly supplied was to be used
with an engine plate between the engine and the transmission .
Late last night Ben, Dean, Cayne, uncle Ray and Chris decided to undo months of my work on DTTF (with my consent) and remove the engine to steal my
aluminum engine plate .
We took a template of the engine plate before cutting it to suit Bens bug , so that it can be reproduced after Warwick . The engine plate has been
installed into Bens bug and the cluch assembly clears with the engine being turned over
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 25th, 2012 at 06:39 PM |
Bens engine is installed as the rest of team WPVW assembles his bug . A new exhaust system is also manufactured staring with flaring up the size of
the exhaust outlets
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 25th, 2012 at 06:45 PM |
Bens engine has been fired-up and sounds great !! Dyno session tomorrow afternoon for both Ben and Dean
http://www.youtube.com/watch?v=Jd2iCD8sse8
Team
DavoBuggy 1641
Threads: 12
posted on September 25th, 2012 at 08:00 PM |
Awesome! That is sick, looking forward to catching up with you guy's on the weekend.
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on September 25th, 2012 at 08:17 PM |
benny you gotta be happy with that crisp, mean, tear your balls off sound......should be a good run vs Davo's buggy.
great work as always boys.
20bkombi
Threads: 26
posted on September 25th, 2012 at 08:18 PM |
That is absolutely awesome guys!!! This will turn heads.
Hope all goes well on the dyno for the two volkys tomorrow.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
posted on September 25th, 2012 at 10:17 PM |
Good luck on the dyno tomorrow guys. Hope all goes smoothly. With the flames that thing throws Ben no need to bring the BBQ lol.
See you guys Friday!!
humpty
Threads: 139
posted on September 26th, 2012 at 12:53 AM |
Holy cow Ben!!!!!..... You got flames coming out at idle even!!!!!
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on September 26th, 2012 at 06:16 AM |
Yeah sounding the goods now.
on a side note are you and Chris entered this year Wayne?
66deluxe
Threads: 139
posted on September 26th, 2012 at 08:51 AM |
Awesome. Just dont wear those shorts at Warwick please. Only cause your bugbis loud enough.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 26th, 2012 at 09:17 AM |
Chris Bolton is entered and his car is ready however I will not be running as I had a little mishap on the dyno several weeks ago.
http://forums.aussieveedubbers.com/viewtopic.php?tid=36521&page=36#pid923757
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on September 26th, 2012 at 10:33 PM |
Bens dyno session didn't quite go to plan today .......
Error |
Error |
Error |
Error |
Error |
Team
66deluxe
Threads: 139
posted on September 26th, 2012 at 10:39 PM |
Oh shit what happened
matberry
posted on September 26th, 2012 at 10:45 PM |
Oh NO.....not looking good.
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on September 26th, 2012 at 10:55 PM |
mate that sux, Ben has not flinched through the sequence of images which would have taken a split second.
