[ Total Views: 139807 | Total Replies: 474 | Thread Id: 91358 ] |
Pages: 1 .. 8 9 10 11 12 .. 16 |
petemart
Threads: 18
Theme: UltimaBB Pro Charcoal
posted on November 1st, 2012 at 09:20 PM |
Matt, this ride is getting better and better.
matberry
posted on January 19th, 2013 at 11:20 AM |
Quote: | Originally
posted by petemart
| Thanks mate.
Plenty to do ........
Case has been inspected, measured and machined.
Since I'm a poor mechanic and Bluey is an old car, I'm happy to ue some of the less sort after parts.... ie. junk I have aquired that is stacked up
in the corner. Case is a freebee std/std AS21 single relief that on the outside looked a bit unloved but after some tlc came up ok
Pic is of one half bead blasted
I've roughed out the case internals and last night did the first clearance checks. Due to the beautiful Carrillo rods, the 78mm stroke only requires
minimal clearancing under the barrel locations for the rod bolts, about 2mm of material off should do it.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on January 19th, 2013 at 01:08 PM |
Good to see you have begun
tar76
Threads: 95
posted on January 19th, 2013 at 01:24 PM |
Ohh...bluey is getting some love.
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
matberry
posted on January 19th, 2013 at 07:42 PM |
Slowly slowly
Today's progress, all on the case still, fully clearanced and internal case prep 90% done. Tomorrow complete internal prep and drill n tap oil
galleries, hopefully spot face perimeter bolts.....
66deluxe
Threads: 139
posted on January 19th, 2013 at 08:43 PM |
Nice Matt. I put my 78 dpr crank in my case and it didnt need clearancing but still to get rods yet then hopefully only a little removal and should
be ready to build.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
IWL_86
Threads: 23
posted on January 20th, 2013 at 09:39 AM |
Great work Matt !!
Bizarre
Threads: 730
posted on January 20th, 2013 at 09:55 AM |
Quote: | Originally
posted by matberry
Mat
Why the single relief??
Because its a freebee??
I thought single relief was a no no for hi po?
Then again, I didnt think AS21 came in single relief??
Whatever - love your work
matberry
posted on January 20th, 2013 at 09:17 PM |
Thanks everyone for the encouraging comments, it helps thats for sure....
Quote: | Originally
posted by Bizarre
Mat
A combination of things really. Yes I owned it already and I like the fact it's a 'seasoned' case, and AS21 is supposed much stronger and better
lasting in high performance aplications. It measured std on the tunnel so that's definately a plus. The fact that it's single relief is a negative,
but I like to tempt fate and push the envelope with the old tech stuff. Not fully sure what I'll do with the cooler. I'm thinking I might delete the
cooler in the fan housing and let the full flow cooler with thermostat and thermo fan do thier thing. That way, #'s 3 & 4 will get a good air
supply but retaining the narrow fan to leave the decklid og (not requiring extra air vents)
My old race motor in Joint Effort was 2165 180hp built on an AS21 single relief case and had no problems with it. It was a better version being
filled behind #3 where this one isn't, but we'll just have to see how it lasts.....
Today I have all the major work done inside the case and the oil gallery plugs have been removed and the galleries drilled and tapped. Even on a clean
case, trapped junk came from some oil galleries. This is a must do on any rebuild IMO.
Sorry I rushed the pics so they aren't that flash , I'll get some more
as things progress.
Did I say 90% done yesterday?
This case had a mega amount of casting flash so I've ended up doing a heap of deburring and blending to remove stress risers and improve internal
windage and also speed the return of oil back to the sump.
matberry
posted on January 22nd, 2013 at 09:35 PM |
Looking forward to getting all this together.
More detailing on the clearancing, and preparing everything.
Number umpteen eleven trial assemble
westi
what the
Threads: 28
Mood: not blue, pink
posted on January 22nd, 2013 at 10:11 PM |
sorry i missed you call today,left my phone at work again.
asian rang me at home ,wow there light pushrods,i am jealous.
and wow you a smashing it,you'll be finished with time to spare at this rate.
i better pull my finger out of stock's arse,it will be easier with both hands i guess.
i am gona dumby up tommorrow night now so i can catch up.
down sharon.
matberry
posted on January 22nd, 2013 at 10:19 PM |
I've had a hold up, the rods hadn't had the pin bushes done so have to get that done before I know where I'm at with the deck and heads cr etc.
Need to balance all rotating so plan to run to Bris later this week. Got a few customer engines that need delivering too......
And yeah, they are light, even the ends are too at 6.2g each
vassy66T1
A.k.a.: Marcus Vass
posted on January 23rd, 2013 at 07:11 AM |
Loving it Matt. What rockers did you end up going with?
Push... push...push
matberry
posted on January 23rd, 2013 at 08:16 AM |
Quote: | Originally
posted by vassy66T1
Push... push...push
Thanks Marcus,
running with some Scat 1.4's until something better comes along
mactaylor
Mood: even my dog is german
posted on January 23rd, 2013 at 06:00 PM |
Quote: | Originally
posted by matberry
Quote: | Originally
posted by vassy66T1
Push... push...push
Thanks Marcus,
the 1.4 pauters are cheap!
EVERLAST CONCRETE TANKS
1800 552 123
matberry
posted on January 23rd, 2013 at 08:49 PM |
Quote: | Originally
posted by mactaylor
Thanks for the suggestion, but I prefer the wiping pad type like a Berg or JPM. The Scat will be ok, biggest hassle with them is they don't run stock
diameter shafts so you don't have as many shim options.
1916baja
Threads: 176
posted on January 24th, 2013 at 04:18 PM |
Quote: | Originally
posted by westi
Did you do a run to brisbane this morning matt??
matberry
posted on January 24th, 2013 at 09:58 PM |
I did Mick, came home empty handed though as far as my engine was concerned.
Tomorrow I hope the balancing and rod small end pin fit will be ready.
1916baja
Threads: 176
posted on January 25th, 2013 at 06:31 AM |
Bummer, yeah I was on my way up the coast and thought I saw the a blue flash if your van going the other way!
matberry
posted on January 25th, 2013 at 09:48 PM |
Picked everything up this arvo. Just home and had pizza n a bundy
Balanced and rods fitted to pins.
kombibob
Threads: 173
Mood: at by cows
posted on January 25th, 2013 at 09:56 PM |
Nice one!
Will kayak down tomorrow for a look.
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
matberry
posted on January 25th, 2013 at 10:12 PM |
Quote: | Originally
posted by kombibob
Yeah, feast or famine...heavy rain all the way to Bris and back, 350k round trip.
66deluxe
Threads: 139
posted on January 25th, 2013 at 10:14 PM |
What a mission.
matberry
posted on January 25th, 2013 at 10:35 PM |
Quote: | Originally
posted by 66deluxe
What a mission.
... two days running .....felt like a mission all right. T3 cruises well on the highway though.
cnfabo
Threads: 140
posted on January 25th, 2013 at 10:57 PM |
Whats the specs of the raptor cam mat
vassy66T1
A.k.a.: Marcus Vass
posted on January 26th, 2013 at 08:51 AM |
Raptor cam Specs???
Something like ... "This is the one you want" JP
matberry
posted on January 26th, 2013 at 09:10 AM |
You got it Marus.
It's split duration but the details ..... well, I told Johannes what I had and what I wanted and he sent me a cam.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 26th, 2013 at 09:12 AM |
Quote: | Originally
posted by vassy66T1
Raptor cam Specs???
tar76
Threads: 95
posted on January 26th, 2013 at 09:43 AM |
Saw that cam not long ago
"Obey your Dreams"!
62 Std beetle.
vassy66T1
A.k.a.: Marcus Vass
posted on January 27th, 2013 at 12:17 AM |
I have no doubt it will be the goods
Looking forward to it
