[ Total Views: 52113 | Total Replies: 372 | Thread Id: 97112 ] |
Pages: 1 .. 10 11 12 13 |
matberry
posted on April 30th, 2014 at 08:37 AM |
Very clever Aaron, good work mate
20bkombi
Threads: 26
posted on April 30th, 2014 at 05:49 PM |
Thanks guys!!
The next thing that crossed my mind was to make a full electronic solenoid valve body, but I think a multi clutch lockup converter will be first.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
matberry
posted on April 30th, 2014 at 07:08 PM |
Yep, guess so....
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
posted on May 1st, 2014 at 06:11 PM |
That is awesome dude.
20bkombi
Threads: 26
posted on May 2nd, 2014 at 03:16 PM |
Had 2 hrs in the shed today between feeding our new born (two weeks today) Lucy Belle Roberts.
Got some data from my v/b before installing it... And yes that is a drill to drive the pump shaft.
Then bolted it in for a test drive.
Ph 0402 233 027
humpty
Threads: 139
Mood: Totally boosted!
posted on May 5th, 2014 at 11:57 PM |
It's mad how your mind works.... How's Bec feeling Aaron?
Frallan
Threads: 0
posted on May 6th, 2014 at 01:14 AM |
Love it!..... and I know you know.
Now I have to look in to my Innovate logger and see how you managed 5 pressure channels.
20bkombi
Threads: 26
posted on May 11th, 2014 at 08:57 PM |
Quote: | Originally
posted by humpty
Thanks Humpty!!
Bec and Lucy are going great, 3 weeks and 2 day now.
Ph 0402 233 027
20bkombi
Threads: 26
posted on May 11th, 2014 at 09:54 PM |
Quote: | Originally
posted by Frallan
Haha!!.... I know ;-)
We'll have to workout soon if I can modify your valve body adding a trans brake and extra neutral or I make a new one. I'll email you tomorrow.
With the logging, on this one I used one of my DL-32 innovate units configuring all 5 channels to = ( 0-5v ) and using 0-400 psi sensors. I think
they are around $40au ea with wire connectors.
What innovate are you using??
Ph 0402 233 027
Frallan
Threads: 0
posted on May 12th, 2014 at 08:39 PM |
I have a LMA 2 a LMA3 and a TC4 for my EGT.
The DL32 is probbaly more flexible. Cool in any case.
No hurry yet for the trans brake. I will test it in September and then during our Swedish winter, I can update.
Thanks!
20bkombi
Threads: 26
posted on June 9th, 2014 at 07:51 PM |
Machined some steels to fit more clutches in the auto.
I've moved the steel from where I machined it to get a better pic.
Ph 0402 233 027
Frallan
Threads: 0
posted on June 9th, 2014 at 09:35 PM |
You are building on your hero status.....
20bkombi
Threads: 26
posted on June 9th, 2014 at 10:06 PM |
Quote: | Originally
posted by Frallan
You're so funny!!!
Today I had great success with the manual valve body I made. Logged all the shifts and modified the v/b to shift absolutely perfect. This one is going
in Dean Penrose turbo injected beetle with mini spool, 930 flanges and one of my high rpm stall converters.
This will be one to watch out for on the street or the track!!!
Ph 0402 233 027
Frallan
Threads: 0
posted on June 9th, 2014 at 11:09 PM |
Good luck for you and Dean! I will follow the progress, as usual with interest, far away but still so close.
20bkombi
Threads: 26
posted on July 13th, 2014 at 09:14 PM |
Had time between auto rebuilds so got a little done on the notch, cut 6 of the intercooler end tanks off and welded them in pairs, made new end tanks
and tiged all the pipes.
315 amp tig, still getting use to aluminium welding
Turned up two V bands one for each turbo with o'rings
And a new seat
Ph 0402 233 027
Performance Upholstery
Threads: 10
posted on July 13th, 2014 at 10:11 PM |
Holy moly!
Cars, boat seats, furniture and more!
0439002870
performanceupholstery@live.com.au
Mt Gravatt east Qld.
Stanley
Threads: 270
posted on July 14th, 2014 at 12:21 PM |
Wow...been busy Aaron...glad you upgraded the seat
Threads: 10
posted on July 14th, 2014 at 12:57 PM |
Speaking of the seat.... Wanna get rid of the old one Aaron? Do you know if they are ok for a 10.99 tech??
0439002870
Vw nutter
Threads: 148
Mood: Chillin
posted on July 14th, 2014 at 08:13 PM |
Wow that is a very impressive setup! nice work!
what sort of hp will this thing be putting out?
Threads: 10
posted on July 14th, 2014 at 08:23 PM |
Heaps! Lol!
0439002870
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on July 14th, 2014 at 08:58 PM |
Well Aaron-it looks like you have nailed another professional Trade.Thats some very neat ally welding for a newcomer.I had better get some scrap ally
and do some practice runs to try and keep up.The work on the coolers is outstanding.
20bkombi
Threads: 26
posted on August 10th, 2014 at 09:07 PM |
Thanks Greg, there's still lots of room for improvement.
I made the seat base, welded under the whole chassis and started on the ally sheeting. I'll use the bead roller on the panels at a later stage.
Very messy work shop, but got a bit done the last couple of days
Made 100 of these and have already welded 86 on using a quick jig to line them up
Hopefully I get time go finish the rear fire wall the week after next.
Ph 0402 233 027
humpty
Threads: 139
posted on August 11th, 2014 at 11:47 PM |
You have a MACHO bender hey?
20bkombi
Threads: 26
posted on August 12th, 2014 at 08:18 PM |
It an't so mucho, I had to reweld the eccentric clamps so now it bends 3mm instead of 1.6mm
Ph 0402 233 027
20bkombi
Threads: 26
posted on August 20th, 2014 at 06:30 AM |
All the aluminium work is done
I made some seat belt covers to protect them from the engine bay.
And fixed down the battery
Now to finish fitting all the guards and start to think about a rear wing and rear opening window.
Ph 0402 233 027
Stanley
Threads: 270
posted on August 20th, 2014 at 07:17 AM |
Starting to really take shape Aaron...looking great
mactaylor
Mood: even my dog is german
posted on August 20th, 2014 at 12:29 PM |
Hi Aaron Where did you get your thin wall ally pipe and bends?
EVERLAST CONCRETE TANKS
1800 552 123
20bkombi
Threads: 26
posted on August 20th, 2014 at 04:10 PM |
The cooler doughnut pipes are 2mm thick from a local fab shop. They always have them in stock.
Ph 0402 233 027
FROSTY
Threads: 65
posted on August 20th, 2014 at 06:00 PM |
Very nice!! can't wait to see this in the flesh.
morgan
A.k.a.: morgan smith
Threads: 30
Mood: excited
posted on August 20th, 2014 at 09:10 PM |
looking good
