[ Total Views: 34870 | Total Replies: 375 | Thread Id: 98668 ] |
Pages: 1 2 3 4 5 .. 13 |
pete wood
posted on January 19th, 2013 at 08:06 PM |
Crank angle sensor. Did it in my Ej25 buggy for a while. Then one day it wouldn't start at all. ECU gave me the code and I replaced it. All the codes
are on the forum here in the resources sticky.
Sunnyjim
posted on January 19th, 2013 at 09:15 PM |
Pete
Thanks for the reply.
I will look.at that
can u tell me the best way to look up the error codes on this ej25
Can i use one of those obd scanners or do i wire up a Led to the check light?
Sunnyjim
posted on March 3rd, 2013 at 10:52 AM |
adaptor plate , flywheel on
some progress
I got the adaptor plate on nicely
flywheel went on. do I need washers? the Sherman kit did not come with them?
no bolts came with the clutch pressure plate, does anyone know what type I need?
vlad01
Mood: Side ways
posted on March 3rd, 2013 at 11:37 AM |
Quote: | Originally
posted by pete wood
those symptoms are also characteristic of leaking injectors. I would look at them also.
71 notchback,
Sunnyjim
posted on March 10th, 2013 at 11:44 AM |
hey vlad
yeah I am open to suggestions. not sure the best way to check injectors
I just replaced the crank sensor , that did not fix it . I also checked the impedance , the old one is the same as the new one
paul
Sunnyjim
posted on March 10th, 2013 at 09:16 PM |
wise thing to do
| guess the wise thing to do is to wire up a check light and learn morse code to read it.
Sunnyjim
posted on March 17th, 2013 at 11:54 AM |
I have started cleaning up the wiring loomand wrapping the black corrigated hoes around the loom.
I had to replace some black hoses as well.
I have 1 loose end and don't know where it goes.
have a look, it is the connector down near the flywheel.
it is a water hose and either end goes to the cylinder head
Sunnyjim
posted on March 17th, 2013 at 12:02 PM |
do u know where this waster hose connector goes?
Joel
posted on March 17th, 2013 at 01:34 PM |
They aren;t coolant hoses, they are oil breathers, for the rocker covers and the case breather, that T needs to feed into your intake between the air
flow meter and the throttle body.
Sunnyjim
posted on March 17th, 2013 at 05:44 PM |
Hi JOEL,
Thanks for the quick reply.
That makes a lot more sense now.
Sunnyjim
posted on March 17th, 2013 at 05:51 PM |
JOEL,
Let Me pick your brains again..
I am a fair way from installing the engine in the lowight engine bay
Can you tell me where exactly I connect my Kombi brake booster hose to the ej22
Manifold?
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on March 17th, 2013 at 06:13 PM |
You can see it hear to the left of the idle control valve.
http://forums.aussieveedubbers.com/viewtopic.php?action=attachment&tid=90...
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on March 17th, 2013 at 06:15 PM |
Mmmm that didn't work the way I wanted.
Third photo here.
http://forums.aussieveedubbers.com/viewtopic.php?tid=90207&page=4
Quote of the week
Joel
posted on March 17th, 2013 at 07:53 PM |
Quote: | Originally
posted by Sunnyjim
JOEL,
Manifold?
You cam just use the stock subaru brake booster fitting if it's the right size for the Kombi hose.
It is the one circled on the right
vlad01
Mood: Side ways
posted on March 18th, 2013 at 07:00 PM |
Quote: | Originally
posted by Sunnyjim
hey vlad
paul
pull the injectors with rails and all, and all lines and wiring still connected. prime the pump to build pressure or if you can run the pump
continuously. see if they are weeping or leaking fuel from the pintels (ends of the injectors).
what happens is when the car is left warm they leak fuel into the ports, which vaporizes and floods the engine and manifold with rich fuel vapor. when
left long enough to cool, like few hours or overnight the fuel vapor condenses back to liquid and settles which in turn the engine starts easy or
relatively easy.
had this experience few times before so i know it when I see it first hand. Sounds like what you are getting and its a good possibility with today's
fuel.
71 notchback,
Sunnyjim
posted on March 24th, 2013 at 12:42 PM |
Thanks Joel and Vlad for your help.
Sunnyjim
posted on March 26th, 2013 at 09:01 AM |
more progress
flywheel, clutch pressure plate all bolted down to the right torque
i picked up a liberty crossmemeber which will help as the engine mount
Sunnyjim
posted on April 2nd, 2013 at 08:18 PM |
hanging by 4 bolts
Ej22 getting closer to its new home
http://m693.photobucket.com/albumview/albums/Grubbyboy_bucket/20130329_140935...
Engine now connected via adaptor plate to the gearbox.
Hanging on the ground as I am yet to organise an engine mount.
Sunnyjim
posted on April 3rd, 2013 at 09:31 PM |
whioops , I will try again
Hanging on the ground as I am yet to organise an engine mount. I also snapped the engine lift. It is not rated to lift a kombi!
Sunnyjim
posted on April 9th, 2013 at 08:24 PM |
angle of the engine?
I have just got the engine mount made.I did a trial fit in the engine bay and realised I can gain another 2 to 3 inches in ground clearance by
raising the engine mount. As expected this puts the engine on a slant.
Do my question is - is this an absolute no no, engine must be 100% horizontal? Our can I have it on an angle?
Sunnyjim
posted on June 10th, 2013 at 02:41 PM |
more progress
Engine mounts now done and engine in nicely
got the original liberty exhaust front half on
Sunnyjim
posted on June 10th, 2013 at 02:46 PM |
questions ?
I am this far , cansoeme one help me?
1. I can gain 2 or so more inches in clearance if i push the engine mount up higher, however ths puts the engine on a slant forward. Is this an
absolute NO NO? i have it currently mounted flat.
2. I have to get my head aroud the fuel system. How do I provide a fuel return to the petrol tank?
where exactly? can some one provide a piccy?
thanks
paul
nils
Threads: 65
posted on June 10th, 2013 at 08:40 PM |
many of the off road boys run there scooby motors at an angle without and problems
you can also shorten the sump 2'' pretty easily aswell as the headers, I think it was custom offroad that did like a 90mm shorter sump?
easiest way to do the tank would be to get a later injected model tank or use a fuel tank bulkhead fitting into the top.
here are a few photos of my sump and headers
good luck with it
Quit calling rust patina
Sunnyjim
posted on June 11th, 2013 at 08:37 AM |
thanks nils
Nils thanks for posting the pics. I like that shortened sump, but as I have used the original liberty crossmember I wonder if it would fit?
Also I heard it common enough for kombi ej22 conversions to still use the original fuel tank, so I am looking find how they did it.
I assume I need a separate return back to the petrol tank not just connect back to thetank outlet..
What I like about this self imposed project I have had many questions and it has forced me to learn
Subarugears
Threads: 17
posted on June 11th, 2013 at 09:46 AM |
Sunnyjim, I have a couple of suggestions for you to make your engine mount setup much stronger and engineer-worthy.
Firstly, you need to weld a couple of crush tubes into your Kombi chassis rails so that when you tighten up those four bolts you don't simply crush
your chassis rails together.
Secondly, it would be a great improvement to have a plate/L bracket hanging down on both the inside and outside of the chassis rails instead of just
the inside - then weld those two brackets together so they form a channel.
At the moment you're putting a lot of upwards & downwards stress onto those bolts from just one side and are likely to snap them.
Sunnyjim
posted on June 11th, 2013 at 07:41 PM |
todd
thx for the advice, much appreciated
i had wondered about that,
i wil certainly look at it
john1960
Threads: 14
posted on June 14th, 2013 at 03:42 PM |
Sunnyjim I have a 74 kombi with a ej22 you could have a look at.I am on the gold coast are you close by.
Sunnyjim
posted on June 14th, 2013 at 06:16 PM |
yes close enough
John
Am in carindale, i go to goldie abit. Lets tee it up
Paul
nils
Threads: 65
posted on June 14th, 2013 at 09:01 PM |
Oh yeah, that's why I decided against the OG cross member, Don't mind me
Quote: | Originally
posted by Sunnyjim
Sunnyjim
posted on June 27th, 2013 at 07:07 PM |
Nils yes I can see that!
