Skip to content
Aussieveedubbers
bug with radiator in the rear (pics)
Share Share on Facebook Share on X Share on Reddit
Log in to reply
Baja Wes V6 Baja Pioneer
3,119 posts · joined Aug 2002 ·
#380538
here's a more recent pic I dug up. It shows everything installed with just the hatch cover removed. You can see the big blue 3" air intake from the throttle body.
The rear subframe hoop has sleeves for bolts welded into it, so it then bolts through the body and makes everything strong again after hacking a hole out of the body. There's foam strips here and there to seal it all, including some bigger foam pieces glued onto the front edge of the radiator to seal it against the hatch and stop hot air recirculating through the radiator.
1 attachment · Log in to view
Wes - www.offroadvw.net - 200HP Quad Cam V6 in a VW Baja - with climate control... 🙂
