[ Total Views: 2085 | Total Replies: 11 | Thread Id: 112426 ] |
binner
Threads: 210
Mood: want more grunt
posted on May 8th, 2017 at 05:16 PM |
subaru radiator placement
Has anyone seen or done this position for the radiator?. I am toying with the idea and will add a gurney lip / scoop to direct air. I will keep both
rad fans and couple them so they both are activated when reaching 90C.
Any ideas, thoughts if it would be ok to try.
Cheers,
Binner
Error |
Error |
Error |
binner
Threads: 210
posted on May 8th, 2017 at 05:19 PM |
or stick with my pos i have now and add a system like this
or if i keep my rad underneath but add one of these inline electric , fully programmable pump.......
http://daviescraig.com.au/electric-water-pumps
EWP 115 with controller
BlasterTheRedBajaBug
Threads: 78
Theme: UltimaBB Pro Charcoal
Mood: Playing the cards, like they were what I wanted
posted on May 8th, 2017 at 05:53 PM |
I personally would go with the idea you are toying with depending on how hot it runs already, I am considering putting the radiator on top of the
engine in my baja.
Nobody can drive you crazy, unless you give them the keys.
karmann141
Threads: 47
posted on May 8th, 2017 at 07:41 PM |
Won't work in that position.
I purchased a panel with an EJ20 with the radiator in that position (albeit higher). The owner could not keep it cool and had the fans wired to run at
all times the ignition was on. Just doesn't get the airflow.
If you're planning a vented engine lid - don't waste a good lid.
There's heaps of info on here as to what works or not.
Error |
Error |
1961 K Ghia - Porsche 5 sp, EJ20T, Brembo's, Dble A arm susp
1974 L Bug - Porsche 944 brakes, Boxster 16's
1974 Bay Camper - EJ20, twin radiators, Boxster 16x7's
Half Beetle trailer with Boxster 16x7's
2011 Tiguan TDI 4Motion
2010 LR Discovery 4 TDV
Threads: 78
posted on May 8th, 2017 at 08:32 PM |
I don't have a lid just a hacked up whale-tail with a radiator support built in.
karmann141
Threads: 47
posted on May 8th, 2017 at 08:40 PM |
Quote: | Originally
posted by BlasterTheRedBajaBug
Sorry not you Blaster - Check the other posts, Binner wants an engine lid.
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on May 9th, 2017 at 05:39 AM |
What was wrong with where you had it underneath?
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
binner
Threads: 210
posted on May 9th, 2017 at 06:37 AM |
unsealed roads
Quote: | Originally
posted by 11CAB
done a few camp trips off road and have noticed some stone chips and road noise.
Was thinking of relocation and was just seeing if its been done before in the rear. There is so much room/space there as you can see.
Bone
Threads: 43
posted on May 9th, 2017 at 07:39 AM |
If off road , up front out of harms way! (Where it should be..lol)
11CAB
Threads: 321
Mood: Beach'n
posted on May 9th, 2017 at 05:48 PM |
I'm mounting mine under the belly, but I've got 33 inch tyres and about 6 inch lift
65 Meyers Manx
68 Baja Bug
karmann141
Threads: 47
posted on May 10th, 2017 at 10:55 PM |
https://forums.aussieveedubbers.com/viewtopic.php?tid=95862
binner
Threads: 210
posted on May 11th, 2017 at 06:21 AM |
rad man
thanks for the link, some real good info there and plenty of discussion.
