[ Total Views: 4200 | Total Replies: 4 | Thread Id: 86968 ] |
ztnoo
Threads: 120
Mood: Dazed & Confused
posted on November 3rd, 2010 at 10:38 PM |
VW Country Buggy Original Front End Beam Complete
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230546232837&ssPag...
Fine tuning the proper daily ratio of Maxwell House to Bacardi 151.........
* Don't worry about the world coming to an end today. It's already tomorrow in Australia !
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on November 3rd, 2010 at 10:59 PM |
woah man! legal 3 inch lift peoples!!!
wait... correct me if wrong but aren't the shock towers meant to have factory gusseting/strengthening?
update:
my bad... just did some research. stock bug beam, with type 2 arms and king pin assemblies...
(ô_!_/ô) (ô_!_/ô)
bevoracing
A.k.a.: Tony Beven
Threads: 35
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on November 4th, 2010 at 04:27 PM |
Almost Chris. Standard type 1 beam, except for the little strengthening gussets where the bump stop arms meet the shock tower. Type 1 trailing arms.
Special “type 2 like” king pin assemblies with type 1 link pins and bushes (no bearings like the later type 2). Bushed king pins like the pre 54
type 2 (pictured), but not the same. Steering arm is at the top like the pre 54, later type 2’s are at the bottom. The stub axles are the smaller (I
think after 64) type 2 with the smaller bearing. The brakes are the last of the type 2 drums, 64 to 69 style. Type 3 steering box and pitman arm to
take the larger tie rod end tapers that type 2 and 3 had. The king pin assembly is unique to Country Buggy. I saw a set a while back that had been
modified to take roller type 2 link pins. Bit of work but it can be done.
Tony
Error |
Error |
ArtyP
Threads: 20
posted on November 4th, 2010 at 05:56 PM |
Mine also has a steel bar approx 12mm dia accross the front like a sway bar shouldn't that be a part of it also I would have thought the 2
strengthing bars that bolt onto the bottom bar back to the main pan would also be a part of it , don't know what you call them but Bill will know
.Arty
58camper
A.k.a.: Bill Moore
Threads: 110
Mood: Curt but friendly
posted on November 7th, 2010 at 07:28 AM |
Arty,
Yes- I would agree those beam strengthening bars should be there for a complete unit. Maybe they were sold separately.
countrybuggybill
