Didn't know you could done for oversize tyres on a baja.
does anybody have copy of the modification guide that states vw types 1,2 and 3 are exemt from that rule due to beach buggy heritage?
Quit calling rust patina
I thought there was a copy on the manx club forum but just had a look and can't find it
haha, take it to the inspection with stock vw rims and tyres, take a few photos for shiz and giggles. It'll get ya by for the moment, and will get you through the pits!
Then change back that afternoon lol.
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears. 👍
nils wrote:Didn't know you could done for oversize tyres on a baja.
It would be good if someone did. But seeing as no one has ever been actually able to show me a copy, does it actually exist?
And Chris, not doing to Transport anymore, they didn't want to see it. All I need to do is get a roadworthy and take that to the police.
Smiley
Smiley wrote:nils wrote:Didn't know you could done for oversize tyres on a baja.
Smiley
got to be honest and say, i've never seen it either. vw urban legend perhaps?
Sounds like maybe andrew has seen it before
Smiley wrote:SebastienPeek wrote:Smiley,
What'd she get defected for?
Glad to see you're on the road to recovery however, hopefully you can get in a few runs through the tracks before Christmas.
Good luck!
- Oversized tyres
- No mudflaps
- Broken Hood latch
- Cracked door pillar
- Oil leaks
- Wipers
- And my brakes.
Smiley
i thought these items were part of a baja kit
🙂 and in the baja build/ kit fitting instructions
I used to have the document. Definately not a myth.
What happened to it? Does anyone know where I can get a copy?
Smiley 🙂
no mudflaps
are they f serious..?
BS at its finest
Fantasy
http://seventhchronicle.com
Barrels
www.barrelman.com.au
The baja papers are an available item on the Manx Club Forum but the link of that item is broken at present so i' can't see if the tyre papers are also attached to the baja papers
OZ Towdster wrote:The baja papers are an available item on the Manx Club Forum but the link of that item is broken at present so i' can't see if the tyre papers are also attached to the baja papers
Who do I contact about having the link fixed?
EDIT - and can you send me the page that the link is on??
Smiley
The document was like a brochure from Dept of T'sport about allowable wheel/tyre combinations ( +1, +2 etc.) and the allowable variation front to rear, in the wording it stated different sizes were allowable only if from the factory that way, but in the fine print it said 'except Volkswagen types 1,2 & 3'
If I remember that was for rim width, you could go up to a 7 inch rim but track and height had to remain in the limits. I have that bulletin but I'm in Townsville and it's in Mackay.
Quote of the week
[IMG]https://www.vw-mplate.com/mplate2-18600.png[/IMG]
Come on smiley , we need some pics and report on what you have rebuilt
He's building everyone christmas presents right now, cut him some slack andrew
I'm uploading some pictures onto the net right now. I should be able to do a post up tonight.
I figured you're be more interested in getting your Bus and Tow'dster done Andrew. Instead of trying to live vicariously through my build 🙂
Smiley 🙂
I am working on my bus , but while i'mm picking on you i'mm leaving Dave alone 😂😂
Still waiting
Still waiting
Still waiting
Still waiting
Can't you type any faster
Firstly, Merry Christmas to all.
Seeing as everyone else is still in bed asleep I figured I have time to do a quick morning update to get Andrew off my back.
While the car was defected I figured it would be a good chance to get my rear disc brake conversion done. I've been planning it for a little while and now was as good a time as any.
I'm using VN Commodore rear discs, which nicely match the VN discs I have on the front 🙂
First step was to strip all the old drum craps off and set it aside. I'm sooooo happy to finally get rid of these, having to adjust them after every beach trip was annoying and shoes weren't even lasting 6 months.
I cut an old swingaxle axle tube down and set it up in the vice to work off. On the IRS arms the handbrake bracket on the caliper backing plate doesn't clear the trailing arm unless you rotate the assembly slightly. Then you have to redrill the mounting holes.
I used the bearing cap to help line up and drill the holes, then test bolted it down to the swinger axle.
The next step was clearancing the caliper bracket and backing plate so they cleared the trailing arm. A little bit of tidy notching later and we have something that looks like this.
Then everything got beadblasted, cleaned and given some paint. And then I started assembling it all onto the car. New shoes, pads, rotors and calipers.
You can see in the next 2 pictures that the stock handbrake cable was maintained. It simply hooks straight onto the Commodore setup! Got to be happy with that. All I had to do was add the tube to the Holden bracket to act as the cable holder for the over sleeve.
And thanks to Mr Oztowdster she is now sporting spiffy new shoes too. On 16" Commodore steelies that have had the centres flipped, moved and rewelded.
While I wasn't driving the car I also figured it would be a good chance to swap on the full weight flywheel I picked up at Warwick. I had to have the centre drilled from 4 dowel out to 8 dowel. I weighed them both once I took my lightened one off and the new one is about 1.3kg heavier. Which equals more grunt down low where we want it!
Bolt this NASA spec tool on, torque her up and she's ready to go back in.
And in about 20 seconds we go from this.....
....to this.
Barwork on and back down on her rear wheels 😀
And onto the front. Had to patch a little hole at the corner of the windscreen. I finally got the massive hole in the bottom of my nosecone fixed up. Cleaned and repainted everything! Sorry there's not heaps of pictures like normal, I was actually working for a change 😂
Coming together...
Had to fit mudflaps, yuck! Managed to get them so they don't look completely crap. I hope I don't drive over them too much.
These are the last pictures I took. Will have to get some more now she's all clean and driving again. All I did after this was refit the engine cover and give her a thorough was inside and out.
She went through Police on Friday and is now defect free and driving again!!! HOORAY!!!!!!!
I have to say that the new brakes and freaking sweet. Stops well. I have yet to really stand on it cause I have been letting the pads bed in first. The handbrake is amazing, I'm sure it would hold the car on any slope without a worry at all.
Now that's all sorted, where was I? Fuel tank and rack and pinion wasn't it? More soon 😀
Smiley 🙂
I light chain from the mudflap back to the rear barwork will stop you driving over them
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Hey smiley what size are those rear tyres? And who modified your wheels?
grinderman wrote:Hey smiley what size are those rear tyres? And who modified your wheels?
Tyres are 265/70/16
Which are 31s basically. Same size as what I had. 33s will come later
Wheels were modified by a bloke at the Gold Coast. I'm not sure of the business name because I had someone drop them off and pick them up for me. They are located in the same industrial complex as Gold Coast VW in Labrador, Gold Coast.
Smiley
It would have been Billeau Engineering, I had them modify some mag wheels for my kombi years ago.
http://billeauengineering.com.au/
65 Meyers Manx
68 Baja Bug
Stand up work as always smiley, thanks for posting your brakes up. Been looking at alot of brake options of late. might have to take a leaf from the book of smiley
nils wrote:Stand up work as always smiley, thanks for posting your brakes up. Been looking at alot of brake options of late. might have to take a leaf from the book of smiley
Thanks for the props dude. If you have any specific questions about the brakes PM me and I'm happy to let you know.
I just noticed that I didn't mention where I go the hubs from. They are brand new blank Type 3 rear hubs. John Sherman on the Gold Coast supplied them, he also drilled them, studded them and machined them to fit inside a Commodore rear rotor.
Smiley
Awesome work Smiley. 👍👍
Your front and rear brake conversions remind me of a set I had a hand in in the 90's. Very similar to look at but we used VW 5 x 112 type 2 F & R hubs and rotors, later T 4 rotors in the rear...can't remember the hand-brake set-up but yours looks great.
Nice work on the brakes!!! Bet having discs now front and back will make a real difference. 🙅
I thought I's share some pictures of the car now she's all done and washed. I think she's looking the best she has in years. I also pulled the standard handbrake back out and put my cutting handles back in (I thought the Po Po might frown on these 😂 ) I haven't had a chance to use them yet but they seem to work really well. They lock the individual wheels up no worries at all.
Out with this...
...and in with these.
Smiley 🙂
Nice approach / departure angles !
Love the commo disc setup too
