[ Total Views: 11160 | Total Replies: 77 | Thread Id: 106613 ] |
Pages: 1 2 3 |
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on March 21st, 2015 at 08:53 PM |
A few more.I reckon I can use the Type3 air cleaner ends that screw to the carbs.Just weld the openings shut with some steel,then weld some round tube
to the top skin to attach a pod filter.
Error |
Error |
bevoracing
A.k.a.: Tony Beven
Threads: 35
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on March 22nd, 2015 at 05:54 AM |
Pod Filters
Good stuff Gary.
For everyone, my advice, for what it’s worth, is to choose your “Pod” filters very carefully.
I’ve used both types over years of off road racing. While the ones with the moulded rubber base is convenient, particularly for bikes, they have some
nasty drawbacks that can catch you out. I’ve seen filters looking properly oiled and the carb full of dirt. The cleaning & oiling procedure for a
foam filter “Uni-Filter” is straight forward, but the filter is useless if the oil doesn’t coat the outside of every cavity in the foam. It’s the
final action of rolling it up and squeezing the last of the oil out that ensures it’s pushed into every space. It’s also important that all the oil
you can is squeezed out because too much oil makes a mess. It’s impossible to squeeze out “too much” oil by hand. This is all VERY hard to do
correctly with a moulded base on the filter that doesn’t allow it to be folded up. So, if you get the chance to make a choice, build an inlet jug
(velocity stack) for your carb and choose the all foam filter that holds on with a tie, like you would use on a side draft Webber, and be sure it’s
properly oiled, every time. Could save you an engine.
That’s my 2 cents.
http://www.uniflow.com.au/contents/en-us/d135.html
Carry on
Tony
nbturbo
Threads: 89
posted on March 22nd, 2015 at 12:31 PM |
Good call Tony- I was thinking on the same lines. You made any progress yet? Just thinking- better ring Bob at Volkscare to see how is going with my
CB transmission.
bevoracing
A.k.a.: Tony Beven
Threads: 35
posted on March 22nd, 2015 at 01:52 PM |
There’s always just a little bit of progress. I had to get some front end parts in for someone else the other day so I got in a set of fulcrum plates
for my box. I reckon that’s all it’s going to need, will be worth a go anyway. I’ll get to putting the box back together soon. I’m in New Zealand
on a shutdown at the moment so nothing happening. Painting is the big one, not looking forward to that. Probably not through the winter.
nbturbo
Threads: 89
posted on April 7th, 2015 at 09:41 PM |
Finally got all the brakes and wheels on so it can come off the hoist.Put a new set of link and king pin bushes in the stub axles,new bearings and
seals in the new front brake rotors,but still have to do the front calipers.Need to get the yellow,turbocharged white elephant back on the hoist and
check out the issue with the engine's oil pressure.Cut into the fibre glass to fit one of the new tail lights I bought for it.Have done an order from
the US for it-3 inch body lift kit,17X7 Fuchs mags for the rear,Type 2 rear bump stop rubbers,and a set of gas shocks.I have stripped the steering box
and fitted new bearings and seals,a full set of new tie rod ends and a new steering damper.
Error |
Error |
nbturbo
Threads: 89
posted on April 9th, 2015 at 06:26 PM |
Had a win today-got my rear towbar/protection bar back.Had it done in an irredescant silver which is awesome in the sunlight.
Error |
Error |
bevoracing
A.k.a.: Tony Beven
Threads: 35
posted on May 18th, 2015 at 09:38 PM |
How come, when I look at that last post, logged out, there's 2 pictures there I can't see.
But when I log in there's nothing?
I can see most pictures but have noticed this before several times
Weird
Error |
Error |
nbturbo
Threads: 89
posted on May 19th, 2015 at 09:51 AM |
Mystery to me Tony.
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on May 19th, 2015 at 10:05 AM |
Yes... definitely a mystery...
Pics are working for me!
bevoracing
A.k.a.: Tony Beven
Threads: 35
posted on May 19th, 2015 at 05:16 PM |
Thwere are apparently 2 files attached to my last post too. I can't see them, logged in, can't remove them or change them either. I logged in on
my girlfriend's apple, nothing there either.
There's something seriously wrong with this server. Bugger.
Last pictures I can see in this thread is Garry's motor on March 21st.
grazza7755
Threads: 49
Mood: relaxed
posted on May 19th, 2015 at 05:32 PM |
All pics are clear to me .
April 7th and April 9th all there
Mystery eh.
nbturbo
Threads: 89
posted on May 21st, 2015 at 10:20 PM |
My US order arrived this week.Got 2 Fuchs 17x 7 polished repos,a 3 inch body lift kit for a standard length floor pan and some other bits for the
Buggy.Put some 265/65 Bridgestones on the Fuchs and bolted them on-like what I see.I cut and shut the lift kit to suit the shortened pan and welded
extra bracing pieces on.I will mount it differently to how it was intended.It was made to have thru bolts to hold it all together.I will mount the
lift kit solid to the pan with the rubber seal and then bolt the body to the lift kit so the body can be removed leaving the lift kit part of the
pan.With the new wheels on the back,it can almost go over a 20lt drum standing up.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on May 21st, 2015 at 10:45 PM |
I also bought some wheel adaptors to bolt Fuchs 5x130 up to early 5x205.I recently bought 4 Fuchs from a bloke in Sydney to fit the Buggy,but decided
that 15x5 inch weren't going to cut it, so got the 17x7's.I already had an OG pair of 15x6inch Fuchs,so they are going on the front.I am going to
fit the 4 15x5's now onto my 31 thousand mile all original 64.I have had the 2 late model seats I modified to fit the 6 volt pan recovered in a
marine grade material for the Buggy-very pleased with the result.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on May 21st, 2015 at 11:06 PM |
Picked this up recently.I was told that it was a Ziegler pump set up,but it's not.I forget who put it together-it's on the pump but that is in
another shed.I am told that the motor still has the original oil in it which I find hard to believe.Story is that soon after it was purchased,some
retards took it to try and filled the pump with large rocks and smashed the impellor and that's how it has remained since 1964.It has a unique genny
stand which I haven't seen before-there are 3 x 8mm studs on the front face.The best part of all is that it has a 12 volt genny which is the same
size as a 6 volt unit.It still has the OG crank handle.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on May 29th, 2015 at 09:29 PM |
Made a new ally windscreen frame for the Buggy today.The OG screen was cracked and was only 360mm high-which was way too low.First made it 500mm
high,but it looked too bulky and was much higher than needed for wind protection.Decided that it only needed to be 450mm high,so cut the sides to
suit.Made new side brackets from 6mm ally plate using the shitty OG's as templates.With the tall tyres and body lift,it's a bit of a struggle to get
in and out,so Im thinking some side protection bars to use as a step may be needed.
Error |
Error |
Error |
CheapChalee
Threads: 1
posted on June 2nd, 2015 at 02:11 PM |
Nice looking project.
Chalee
nbturbo
Threads: 89
posted on June 8th, 2015 at 07:50 PM |
Bought 2 lengths of 50mm by 3mm wall thickness pipe for the roll bars.Took it to a local Engineering place with detailed drawings to get it
bent.Looked like shit when I picked it up.They had flattened the outside of the bends and crinkled the inside radius of each bend.Have ordered a new
hydraulic bench bender to have a go at it myself.I cut up one roll bar and made the front nudge bar.I had the exhaust bloke bend the 2 small vertical
bars for the nudge bar- his machine does a neat bend, but it decreases the inside radius diameter too much.Doesn't look so bad when it's so low on
the car.I have made plates for the rear bars to sandwich each side of the fibreglass and bolt to tubes I made to connect to the torsion bar tube and
my rear bar that ties into the towbar.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on June 8th, 2015 at 07:52 PM |
The top side plates
Error |
Error |
modnrod
Threads: 50
Mood: Old School Volksies!
posted on June 8th, 2015 at 09:53 PM |
I have a cheap nasty pipe bender. To use it to make smooth bends I've tried small angles at a time, using the Force, swearing, a few graduated kicks,
all to no avail. I thought about sacrificing a virgin when the planets are lined up, but that's just weird.
I ended up using a bit of 3mm flat bar bolted over the top of the former to "capture" the pipe and stop it lifting then kinking, and that worked a
bit.
I'm thinking of a home-made mandrel bender, U-tube has them everywhere and they're easy-peasy apparently...........how hard can it be? (insert
sarcastic smilie here please).
Could you please show pics of your bought bender if they work out, please?
nbturbo
Threads: 89
posted on June 9th, 2015 at 08:56 PM |
I will show you when it arrives.I used a borrowed bender to do the rear bars-I'm sure Noah made all the handrails on the Ark with it.The dies are all
Imperial and the 2 rollers to hold the back of the bend are only about 25mm diameter,so they leave a dent in the back of every bend.I welded a lot of
the dents up and ground them out but was a major PITA.I see the back rollers on the new one are about 75mm Diam.I fabbed some spot light brackets and
a sand flag bracket today on the nudge bar.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on June 29th, 2015 at 07:18 PM |
The bender arrived-got it from SupacheapAuto-on special for $149.It's a 12,000KG with 6 dyes.Made a couple of bends and they were no better than the
ones I had done professionally-thought OH shit blown my $149.Spoke to a bloke from a place here that does some pipe bending-told me to heat the pipe
to cherry red where each bend will be,let it cool and bend it.Turned out really good with bugger all distortion.Have made a 3 bar cage and tacked it
all together-just have to lift it out and fully weld.Have to fab up some brackets to hold the inertia reel belts and drill some holes for wiring for
some LED dome lights.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on July 16th, 2015 at 09:30 AM |
Finished all the bars and got them back from the Painter.I have done all the repairs to the fibreglass-used some fibreglass bog to do the bigger
faults and finished it off with normal car bog.The fibreglass bog sure takes some sanding to get it right.Was down to 40 grit pads on the
sander.Pretty happy with how it turned out.Have it at the painter getting some high build primer put on.I drilled the centre bar and to run some wire
to fit LED lights to use as interior lights when needed.Will use an early wiper switch on the dash somewhere to make them work.Made the seat belt
anchors and bought some new inertia reels to suit.The small bars welded at each end are grab handles to make it easier to get in and out of the thing
Error |
Error |
Error |
nbturbo
Threads: 89
posted on July 16th, 2015 at 09:57 AM |
Drilled and tapped the front of the trans 1/8 NPT and fitted a breather hose with a fuel filter to keep the shit out-one day it could end up in deep
water.I made a bracket that bolts to the front beam and supports the fibreglass under the fuel tank-there is a lot of weight on the body with a full
tank.The last mechanical job is the handbrake cables-figured an easy way to do it-fit the threaded ends of the cables to the lever and cut the cables
at the calipers and fabricate a clamping/pivot arrangement to hook on to the caliper lever.
Error |
Error |
Error |
pete wood
posted on July 18th, 2015 at 10:40 PM |
Nice work... so basically you annealed the steel pipe before working it more. Makes sense. I might use that trick in the future.
nbturbo
Threads: 89
posted on July 19th, 2015 at 06:30 AM |
Yes that's what I reckon to call it. In one pic you can see the inside radius of a bend with slight wrinkling of the pipe. Before I heated it- the
inside of the bend was seriously distorted,but the outside of the bend had about a 30mm wide flat distortion. Looked like shit.
nbturbo
Threads: 89
posted on July 28th, 2015 at 06:19 PM |
Got my ally windscreen frame pieces back today from being painted in 2 pac silver metallic-same as the roll bars.I was going to polish it all,but it
would always need repolishing from salt air etc.I had an early mesh sunvisor here which was pretty shitty,so had it blasted and painted silver as
well-very nice.I have taken all the dents and scratches from the stainless end pieces,then polished them.They look better than when it was made.
Error |
wombatventures
Threads: 44
Theme: UltimaBB Pro Orange
Mood: BUSted, BUGgered & NOTCHed
posted on August 2nd, 2015 at 01:08 PM |
Looking forward to seeing it all together mate. Those bends have come up sweet.
nbturbo
Threads: 89
posted on August 8th, 2015 at 02:43 PM |
One of my mesh visor with the restored end pieces.
Error |
modnrod
Threads: 50
posted on August 8th, 2015 at 02:53 PM |
You're a legend mate.
Now I have an idea for mine, looks good, thank you.
wombatventures
Threads: 44
posted on August 8th, 2015 at 05:23 PM |
Any chance you might get down to Morgan with us Gary? Although I don't want to drag you out of the shed, coz I'm looking forward to seeing your Toy
finished.
Pages: 1 2 3 |
