[ Total Views: 30346 | Total Replies: 265 | Thread Id: 44043 ] |
Pages: 1 2 3 4 5 .. 9 |
pete wood
posted on March 26th, 2008 at 02:10 PM |
loving my stock NA motor now. you can keep your haltech and turbo if it's that much stress.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on March 31st, 2008 at 06:02 PM |
yeah, all for a laugh guys .....you may come to
realize all the pictures will provide me a reliable, accesable reference to connections etc, should disaster strike and i loose my way
trailer plugs would be a nice addition, but it won't be me cuting into those looms
..... the bench full of removed bits and pieces.....
........job done!
"why did i get this job..".......... oh that's right, i fried
the clutch
flywheel will be removed and "ground"..........to remove hardened hot spots and uneven surface.
we estimated the standard 228mm pressure plate and clutch had done only two hours work.........but that's solid HARD work! (several years of racing)........very sticky tyres, tall 1st gear, shirt
loads of torque + horsepower and not enough clamp force, combined with a total lack of mechanical sympathy........results in a little bit of heat
undoubtedly the replacement will last much longer........
clamp force will be over three times as much on previous set up...........
that's life in the hellfast lane
hellbugged
A.k.a.: Daimo Pell
posted on April 1st, 2008 at 05:45 PM |
well, that was easy!.......
just undo the six bolts and off the flywheel comes........no 8 dowels and interferance fits and pullers to contend with
i'm starting to dig this subie stuff!
flywheel has survived the ordeal ok and resurfacing will be fine
took some measurments of the new clutch and pressure plate to compare to the old set up..........flywheel will be ground to provide maximum clamp
force by adjusting pressure plate height relative to the clutch plate surface
1303Steve
Threads: 556
posted on April 1st, 2008 at 05:52 PM |
Kennedy make nice stuff, I just got my G50 stuff today from them. So you were running a stock 228 pressure plate with the puk clutch?
hellbugged
A.k.a.: Daimo Pell
posted on April 1st, 2008 at 06:23 PM |
yeah stocka Steve, never worked........suffering from slip from day one
the puck clutch injested so much heat it is warped very badly and has a build up of metal that came off the pressure plate on the pads. closer
inspection of the pressure plate sees gourges 5mm deep!..... we knew it would need replacement and just tried to get it down the track for the
spectacle..........i'm very suprised the flywheel has
survived
i'm looking for the dyno sheets for the motor.......new set up is good for up to 500H.P so should be A.O.K
nice to meet you at Oran Park by the way
1303Steve
Threads: 556
posted on April 1st, 2008 at 08:31 PM |
Nice to talk to you as well. I'm hoping for about 260 - 280 hp at the wheels, 500 should be insane.
hellbugged
A.k.a.: Daimo Pell
posted on April 1st, 2008 at 08:51 PM |
o i see..........no, new clutch is rated to 500hp..........
.... engine currently makes 260hp at the wheels and will stay at that for the moment.........
pete wood
posted on April 2nd, 2008 at 01:16 PM |
I too pulled my motor out last night. Only took 2 hrs. I guess I've had a bit more practice than you.
BTW, love those EFI ida manifolds on the bench there. must be time to install them on something don't you think? [pete the broken record]
hellbugged
A.k.a.: Daimo Pell
posted on April 8th, 2008 at 09:03 PM |
oki doki....
got the flywheel done. looks heaps better! you may be able to see the swirl pattern from the grinding. checkout the operational surface area provided
by the 228mm surface
you can see the lip near the ring gear (pressure plate seat)
is also ground to keep the height correct.
further more to the plate seat being ground the matching amount, it had more taken to account for the thinner pads on the new clutch (opposed to
standard plate) and also extra to lower the plate down onto the clutch to get even more "clamp".........
with the pressure plate sitting "relaxed" you can see the fingers of the diaphram rising up to the center........
now with the plate bolted down, the fingers should still be ever so slightly higher in the middle compared to their outer diameter mounting
points..............this is a great indicator that the pressure plate installed height is good ... maximum clamping force with minimum pedal
pressure
hellbugged
A.k.a.: Daimo Pell
posted on May 13th, 2008 at 08:57 PM |
ooorkay, so i've been quietly achieving progress on this machine, with an aim of just having it in storage , "race ready", for whenever the
opportunity arises............
with the flywheel refitted and new clutch in place, the motor was ready to go back in. the bellhousing was cleaned up, necessary's greased (throw out
bearing pivots, guide etc) and new thrust bearing (german) installed.
the standard liberty pipe from turbo to intercooler was long since blown apart, repaired track side, but never replaced. there was no way i could
leave it. so a few options were sorted, as it's nice to arrive at race meets far from home with spares at hand...........
to avoid reinventing the wheel at this point, it has gone back together as it was previosly run. the samco model specific hose (wrx) will allow the
use of standard recirulatory style blow off valve.
in the future, we have the option of going to a aftermarket BOV which can be plumbed into either the stainless "up" pipe or the one from the
intercooler to T.B
so here is where i'm at now..............note the "workshop manual" taped to the back window a picture says a thousand words............and people wonder why i do boring threads with too many pictures, but for sure they come in mighty handy
the hands on experience has been great. i now understand all of the engines components and have spotted some room for small improvements with routing
of fuel lines etc.............might even consider doing a subie conversion for myself down the track
matberry
posted on May 13th, 2008 at 09:22 PM |
I spot those manifolds too!!!
Daimo, you gotta put em on something.!!!
hellbugged
A.k.a.: Daimo Pell
posted on May 13th, 2008 at 10:12 PM |
o.k
they're the ones that were on the chop top Matt?
the butterfly tops (black with sassy exhaust pipe rams) of yours are about to come back into use
JVLRacing
Threads: 30
posted on May 13th, 2008 at 10:30 PM |
bloody idiot....looks goodly m8
matberry
posted on May 13th, 2008 at 10:35 PM |
Thats the ones !
They have been around.
hellbugged
A.k.a.: Daimo Pell
posted on May 20th, 2008 at 09:48 PM |
RUNNING AGAIN
soo basically it all went back together fine. a couple of re arangments because of the new pipes, but nothing spectacular
went to start it and no fuel pressure at the engine. so the process of elimination lead us to the primary efi fuel pump which was seized probably due
to "gumming" of residue fuel after the last run..........anyways got that sorted (not easy) and so it was time to fire up.
the engine sounds quite nasty on the warm up fuel curve from the computer, as soon as the temp reaches 50' it changes completely.
anyways, try this link for a video as i do the run around looking for leaks and noises having just got it fired up for the first time in 18
months.................damn sound has got me amped now i'm pretty chuffed with the results!
matberry
posted on May 20th, 2008 at 10:01 PM |
Daimo that sounds wicked. We need to see more.....like driving would be good....
hellbugged
A.k.a.: Daimo Pell
posted on May 20th, 2008 at 10:33 PM |
yeah, it's ooorsum hey.
yes, should have some paddock action to check the new clutch works on Saturday (although it went into gear fine in the shed but no time left so
fingers crossed)........and hopefully hillclimb 1st June followed by test and tune for the entre following day, then fingers crossed Grafton hillclimb
with the other VW crews............
for now "hear's" another;
matberry
posted on May 21st, 2008 at 09:07 AM |
Hey Daimo, incase you didn't notice, there's an onion on your throtle cable !!!
1303Steve
Threads: 556
posted on May 21st, 2008 at 09:18 AM |
Quote: | Originally
posted by matberry
I thought I saw wood chips on the ground
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
posted on May 21st, 2008 at 09:36 AM |
Hope to see you at grafton then..... me entrys sent off this week. Looks like the VW's will be out in force for this event.
White Knuckle Racing Team
"Drive it like dirt"
reub
VWRX is gone...
posted on May 21st, 2008 at 09:38 PM |
Sounds great
Reub
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
posted on May 22nd, 2008 at 08:18 AM |
Quote: | Originally
posted by matberry
Ah you old dogs keep on falling out of the wood work
matberry
posted on May 22nd, 2008 at 08:20 AM |
As opposed to you young fellas falling out of your prams
OZ Towdster
Threads: 132
posted on May 22nd, 2008 at 08:23 AM |
whaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
TheMiniMan
Threads: 162
Mood: swings
posted on May 22nd, 2008 at 08:48 AM |
I used to run my brick (mini) at Grafton hill Climb many moons ago, dam good little hillclimb track for a mini :-)
Gota love that fist corner hey? :-) & the "Flip-Flop" nearly got me on my first ever run there, but i nailed every run after that :-)
i`ll be back there soon, i`m building some new toys to play with on the hillclimb scene , Yammy R1 powered special & a fastback twin cam turbo
injected mini
I might even enter the duel cab kombi foir a laugh too :-)
good work & hope to see you there one day
OZ Towdster
Threads: 132
posted on May 22nd, 2008 at 03:30 PM |
bumped back
hellbugged
A.k.a.: Daimo Pell
posted on May 22nd, 2008 at 10:45 PM |
well it's actually the artist formerly known as the "onion"......
spending so much time in the woodwork he's now the "Lumber Jeff"
hellbugged
A.k.a.: Daimo Pell
posted on June 16th, 2008 at 06:50 PM |
why they let us put these donks in our road regoed cars i will never know...........check out the speedo needle after a tickle on the go pedal, on dirt with no traction and barely getting into the engines
sweet area!
sorry about the crappy vid quality, kinda hard to hold and grab opposite lock one handed..........will get some better footage (on a real camera) next week when we get the "navigators" seat mounted in
prep for joy rides at VALLA SPECTACULAR LAP DASH
JVLRacing
Threads: 30
posted on June 16th, 2008 at 08:25 PM |
not bad! still think mind sounded better
pete wood
posted on June 17th, 2008 at 10:08 AM |
looks to me like you need to Baja that notch
