| [ Total Views: 25894 | Total Replies: 184 | Thread Id: 65678 ] |
| Pages: 1 .. 3 4 5 6 7 |
Joel
Threads: 210
| posted on July 2nd, 2008 at 04:35 PM |
bet it sounds mean when u sink the hoof in
u have glove box full of earplugs??
how have u found tuning the carbs??
ive got a pair of DCNs im thinking of blowing thro with a single blower
camando
Threads: 8
| posted on July 3rd, 2008 at 01:15 PM |
Thanks Joel
Havent properly tuned it yet.
As I said its only just got running.
I'll throw a o2 sensor on and start soon.
so havent pushed it too hard yet either.
give you a woody though
Joel
Threads: 210
| posted on July 3rd, 2008 at 07:51 PM |
they ok for a rough guide
i went more by feel and plugs for jetting
76bug
Threads: 20
| posted on July 4th, 2008 at 09:49 AM |
hi joel
what sort of sensor did u use
Joel
Threads: 210
| posted on July 4th, 2008 at 01:00 PM |
hi,
its just a universal 3 wire heated unit
same one most EFI cars use
| Error |
76bug
Threads: 20
| posted on July 4th, 2008 at 02:21 PM |
a 5 wire sensor with a wide band unit such as a tech edge or inovate will give u much more acurate readings
Ampdub61
Threads: 27
| posted on July 4th, 2008 at 07:11 PM |
I started with my mock up, just a question, a dual vac dissy was mentioned and i found this
http://www.bfyobsoleteparts.com/1961-74-distributor-pr-1779.html
but in what configurations is it installed? which vac goes to where? if it sorts out any flat spots think it could be good.
Joel
Threads: 210
| posted on July 4th, 2008 at 09:56 PM |
a wide band woulda been nice but it woulda end up owing as much as the entire setup
i actually got it setup and running without one at all
i installed mine later on to see how close i was
my goal with the blower was to prove i could double my hp for under $1k and get performance as good as running a turbo
alot of ppl will argue superchargers have no topend...
i guess for all intents and purposes for the most part i pulled it off
going all out with instrumentation woulda been overkill
ampdub re. the dissy u want it to retard under boost
i got one of those same double advance dizzys coming
what i was gonna try was limiting the mechanical advance and timing it to max out at 24* and putting a one way valve on the vac line connected to the
advance side and tap it to the inlet manifold somewhere after the blower
that way the timing will advance with rpms like normal but retard when under boost
i must say tho im pretty happy with the way the plain ol 009 with limited wieghts has worked out
Ampdub61
Threads: 27
| posted on July 5th, 2008 at 02:16 PM |
Hmmm, i think i need a diagram or i think i will stuff this up. i have a 009 with electric ignition so will see how it goes modifying it. i like a
challenge as well as the next bloke.
greedy53
Threads: 466
Mood: strung out
| posted on July 5th, 2008 at 06:15 PM |
hay girls keep it simple until you are happy with it and you understand how it works before you try inventing the wheel
how are you going joel
Joel
Threads: 210
| posted on July 5th, 2008 at 07:14 PM |
amp ill draw u one up tomoro when i havnt been enjoying saturday night drinks
steve still havent put it back on yet
been enjoying the wonderful fuel economy of a stock 1600 with a 1300 carb LOL
76bug
Threads: 20
| posted on July 7th, 2008 at 10:08 AM |
you can buy a tech edge wide band unit for about 400 bucks
Joel
Threads: 210
| posted on November 28th, 2008 at 07:24 PM |
i guess i should update this
i actually went for a few months with no blower
wish i had $1 for everyone at valla that wanted to see it...
after putting it on the 1776 for a bit and upping the boost turned out shitty head studs i used and boost dont mix
the head studs stretched abit and when i retentioned them abit 3 snapped, 1 about 2mm out of the case....
well im sure most of NSW heard my expletives at the time
so i got a nice new set of scat chrome moly puppies off boris and watched them collect dust untill i built up the courage to tear my 4000km old engine
back to bits agian to remove the offending stud some how
but its all back togther and running sweet at now
also while it was apart i took the chance to get my tinware powdercoated....its bloody bright
i was more than happy with the current setup but when the chance came up to buy a bunch of Solex 32DIS carbs came up i grabbed them
blow thro just offers the chance to intercool, make a more compact installation and slightly less restriced intake breathing thro twin carbs
these carbs are almost identical to type3/4 PDSIT and kadrons just fitted with all the boost enrichment bits and seals needed to run blow thro so
adapting them isnt hard
my first turbo setup i built what seems like eons ago used one of these on a stock 1600
they pretty much bolt straight onto a stock manifold and only need a main jet change and there good to go upto 12psi or the 15psi mine did when the
wastegate jammed and blew the rings to pieces quite literally
theyre pretty hard to find in aus. afaik the only aus cars that used them were the KA whitelightning turbo lasers which is what my first one came from
and a few models of renault
anyway my plan is to jam them on a pair of k-dog manifolds make up linkages and some new boost piping
ive also worked out a WRX intercooler is gonna do the job so perfectly just sitting above the fan housing between the decklid hinges
now all i need is some time to do it which is the biggest hurdle off all atm
the farm is keeping me busy about 10-12 hrs a day atm so working on the dub is the last thing i feel like and having 3 other projects on the go atm
isnt helping either
Joel
Threads: 210
| posted on November 28th, 2008 at 07:32 PM |
oh yea heres why SC14 blowers just dont work on type1 engines
theyre just too long....
Bizarre
Threads: 629
Mood: V Forced!!
| posted on November 28th, 2008 at 09:07 PM |
now you are just showing off
Scilicet putas te currum reficere posse - stipes es!!!
rocknrob
A.k.a.: Rob
Threads: 81
Mood: mystic
| posted on November 29th, 2008 at 12:00 PM |
Hi Joel...when you say the SC14 is too long...can you measure how long it is for me? might fit nicely on my EJ22
rocknrob
A.k.a.: Rob
Threads: 81
Mood: mystic
| posted on November 29th, 2008 at 06:10 PM |
heheh...don't worry about it...found that they are 31cm compared to 27cm for the sc12...doesn't matter heaps of room in the kombi...was going to go
turbo but all i want is more low down grunt...sounds good for that
Joel
Threads: 210
| posted on November 29th, 2008 at 06:13 PM |
its about 50mm difference
i could prob make it work in the bug but the pulley would be so close to the valance it wouldnt be funny and the lenghts of standoffs needed for
clearance would put the decklid about 3kms away from the body
i sold one of my spares to steve and he was thinking of whacking it on a subi
would make for one torquey engine
aintgotitmusthaveit
A.k.a.: Nick
Threads: 72
| posted on March 4th, 2009 at 09:08 AM |
356 sc..... Guess what the sc stands for?
Been slow but on the way....
organising pulleys this week then checking to see what mods I have to do to the lid to make sure it fits!
Go to
http://www.postimage.org/image.php?v=PqMHu90
http://www.postimage.org/image.php?v=aVLbgqS
aintgotitmusthaveit
A.k.a.: Nick
Threads: 72
| posted on March 4th, 2009 at 07:42 PM |
HEy Joel, Did you ever sort out that jetting on the 1776
Joel
Threads: 210
| posted on March 4th, 2009 at 08:25 PM |
hey nick
looks like ur running a DCOE weber?
mines a dell DHLA so theres abit of difference between them
legend has it dells are equal to next size up weber or so they say
40mm dell is equiv to a 44mm weber
dunno how true it is
but its been ages since ive had my carb top off but from memory the mains for the 1776 were 145s and idles were 65s, pump jets 40s and 200 airs
i also switched from 32mm vents to 28s, improved bottom end dramatically on both 1600 and 1776
neat job on your manifolds
only thing i would say is fit a BOV somewhere so if it spitsback u wont find bits of your blower lobes 3 streets away
mine has burped a couple of times b4, never while running but when cranking over
BOV goes off like a gun shot, just making sure your awake for the journey
aintgotitmusthaveit
A.k.a.: Nick
Threads: 72
| posted on March 4th, 2009 at 09:29 PM |
thanks Joel.
Havent ground the manifolds back yet. Thats this weekends job.
Planning on putting a BOV in there before start up; just trying to source one that I can fit on that plate on the SC outlet.
Picking up pulley and tensioner this weekend from wreckers
Its a long term project . Something to tinker on when I am bored....
Will keep you up to date!
PS Bought A dellorto to start with but had a riser on it that hit the deck lid so switched to a weber.
Newt
Threads: 56
Mood: Help me to love like breathing.
| posted on March 6th, 2009 at 12:06 AM |
Greedy
Whats it like for cooling with a portion ofthe fan housing removed?
Newt
It is as it is - If you didnt enjoy today, you've missed the opportunity.
greedy53
Threads: 466
Mood: strung out
| posted on March 6th, 2009 at 12:08 PM |
i had to rework the fan shroud insides it worked that well that 3-4 were cool but 1-3 were getting hot so of with the setup and reworked again now
great
i also tossed the stock oil cooler for better airflow now using a remote cooler very good now
inside the fan shroud there are ahost of baffles 3-4 were easy just cut all the crap out for the oil cooler than 1-2 needed to be opened up and
rewor5ked
if you are going to have a go find an old style fan shroud with no heater outlets and the oil cooler inside
happy blowing
aintgotitmusthaveit
A.k.a.: Nick
Threads: 72
| posted on March 7th, 2009 at 03:34 PM |
Joel,
When you replaced the pulley with the one off the 92 corolla, did you end up keepin the clutch?
You got any photoes of that pulley?
http://www.postimage.org/image.php?v=Pq10MX3r
Joel
Threads: 210
| posted on March 7th, 2009 at 07:22 PM |
Nick i had the clutch on a switch when i first started off
but i never turned it off
if u just drive sedately it behaves exactly like a turbo and doesnt boost, runs a vacuum most of the time
so the 2nd incarnation i did away with the clutch completley
its just the splined center and clutch plate bit bolted to the 4A pulleyi think is the main crank pulley
i'll dig around i have some pics somewhere
Joel
Threads: 210
| posted on March 7th, 2009 at 07:43 PM |
found em
so i removed everything off the blower
thats the 4A pulley with the clutch plate sitting in it
so i had a few wins, smaller pulley upped my boost from 8 to 10, got rid of the clutch which was using a bit of power to keep pulled in and also moved
the belt in alot closer so i could fit my quiet pack back on
aintgotitmusthaveit
A.k.a.: Nick
Threads: 72
| posted on March 8th, 2009 at 11:22 AM |
Joel,
The item that is in your hand in the first pict is used to react the moment resulting from the tension in the belt.
From what I can tell its used to protect the main bearing on the supercharger itself (the one in the housing).
Did you remove it ?
Was the pulley you used in the end the one off the 92 corolla? The one that hangs off the harmonic balancer and drives the aircon and power steering
as you suggested earlier? Does it have a spline drive on it that matches the SC?
Bizarre
Threads: 629
Mood: V Forced!!
| posted on March 8th, 2009 at 11:32 AM |
damn glad you got electronis ignition
Imagine seeting points on that set up
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
| posted on March 8th, 2009 at 11:41 AM |
Putting oil in looks like it would be a hassle as well
