Skip to content
Aussieveedubbers
009 ?
Share Share on Facebook Share on X Share on Reddit
11CAB If ya got it....Baja it
4,674 posts · joined Aug 2002 ·
#168662
Does the 009 dissy have two advance weight springs or just one?
I have 2 009 dissys here and they both only have the one spring, but the post etc is there for a spring on the second weight like the stock carbies........
So have I got two dissys both missing a spring or is the 009 only meant to have one spring????
Graham
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Craig Torrens 6 times Australian, 7 times State Hillclimb Class Champion
8,040 posts · joined Jan 2003 ·
#168686
only have one spring, but I will double check for you tonight.
#168717
Thanks Craig, so you mean only one of the weights has a spring and the other one has no spring?
65 Meyers Manx
68 Baja Bug
68AutoBug Beetle Restorer - Experience over 138\% - YIKES --
11,654 posts · joined Aug 2002 ·
#169114
The Genuine VW Bosch Dual centrifugal / vacuum distributor has two springs...
the early vacuum only Dizzy used one spring, so I'm assuming the 009 Centrifugal Only dizzy uses the one spring... that Is why the original DUAL Bosch dizzies are the Best... and are very expensive... even in the USA...
[for an extra spring and a diaphram?]
- Helping keep Air Cooled VWs on the road - location: SCONE in the Upper Hunter Valley - Northern NSW 320 kms NNW of SYDNEY---
fullnoise Fahrvergnugen
964 posts · joined Sep 2002 ·
#169437
One spring is correct.
CYA, CT
esratrams
70AutoStik Insano Dub Head
730 posts · joined Aug 2002 ·
#169609
No, 68autoBug, it's supply and demand. Only very few original dizzy's are ever needed, whereas 009s are very popular, so they churn 'em out by the million in Mexico.
Until now. According to CIP, Bosch have decided to discontinue them...
Anthiron The Baja Rejuvenation Begins
4,936 posts · joined Oct 2003 ·
#169631
i have what i beleive to be a 009 on my baja and am running a 30pict solex and have a huge flat spot in low revs......is this because im running a stock carbie? would dual carbs or a bigger solex fix this?
sorry to hijack but it seemed like a good thread to ask in
[Edited on 4-5-2004 by Anthiron]
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
OZ Towdster Keen to finish some projects
1,921 posts · joined Dec 2003 ·
#169658
First of all Anthiron i would check your dwell angle as from previose experience this will create a huge flat spot if not right. There is also 3 different 009 distributers and they all have a different advance curve, and last of all running a 009 with a stock cam will also possibley create a flat spot because the distributer advances too fast at lower revs. Hope this helps any body as it can be quite frustrating tring to get rid of a FLAT spot. Andrew
#169666
thanks heaps......yeah i think ill try and locate a dual advance dissy
Nick
1974 Chevrolet Luv
#169668
oh by the way.......what on earth is dwell angle :P i have no idea with this sort of stuff......how do i check this?
1974 Chevrolet Luv
