i'm in the process of pulling my engine down to reco it and make some improvements... so here will be my log asking answers to questions i dont know...haha
--1, your view on volkswagen alloy heads and reseating them and inserting new valve guides? i've heard that you dont bother reseating them as it doesnt take or the different expansion rates of the alloy and steel ends in a dropped valve?
i ask this as i intend on using new valves and springs, and to get a few of the old valves out meant tapping them out with a punch as the collet area of the valve was a tight fit through the guides and ended up pulling through some brass shards with em...
--2, i see in hibbards book he talks about pushrod tubes being vulnerable to cracking/leaking/puncture etc in the off road treatment due to their thin walls. anyone here or out in the wider community attempted to make their own out of thicker pipe? i use to work in an engineering shop, its entireley feasible... the only hurdle being maybe the cooling properties of the thinner pipe?
--3, after pulling off the doghouse fan housing i found my oil cooler a bit damaged. i have talked to someone before about using type4 cooler/s... anyone know of this or have experience? he says it kicks ass and also reccomened modifying the fan housing to suit.
--4, on the subject of fan housings, i am wanting to run more amps then my genny can pump out. i've heard of upgrading to a kombi alternator, how is this done? i think i saw a pic somewhere, it gets mounted over near the coil and you run a bigger belt to accomodate the existing generator also to turn the fan? i spose you could ever run both them in parrallel (i think its parrallel) and really pump up the amps?
--5, do all type1 engines sport the same fan housings? mine is pretty beat up and has holes so will need to replace..
--6, any other general mods i can do to increase torque? i'm talking porting, using bigger barrels and pistons etc... i havent heard much on these topics with the vw engine so far so would be interested to know everyones views/experiences/ideas.
--7, anyone ever thought of adding valve stem seals to the head? reduce oil use etc... could easily be done using hemi valve seals if the valve compression height and valve width complied..
--8, i've heard you can only buy cork tappet cover gaskets. is this true? anyone ever tried to get some plastic/rubbery ones made up?
thats about it for now......haha, not much... if anyone can help or has ideas, give it a go...
[ Edited on 7-11-2005 by ~air fooled~ ]
~air fooled~ ·
