Easiest/cheapest upgrades?
https://forums.aussieveedubbers.com/threads/46100/easiestcheapest-upgrades
droopz ·
Hey guys... New to the bug world and just wanted to get a feel for what I can/should do to get this air-cooled moster pulling a little harder.
As far as i know, I have a refreshed 1600 (12v), with 4-1 extractors and a single barrel carby of some kind.
Ive done a few searches and couldnt really find anything else i can so to tickle her up a bit, so if anyone can suggest anything else id be very greatful.
[ Edited on 18-11-2005 by droopz ]
barls ·
a twin barrel progressive webber is a good upgrade but fuel economy suffers twin carbs are the best option but expensive.
here are a few threads on getting more out of the 1600tp.
http://forums.aussieveedubbers.com/viewthread.php?tid=25357
http://forums.aussieveedubbers.com/viewthread.php?tid=26056
http://forums.aussieveedubbers.com/viewthread.php?tid=25817
http://forums.aussieveedubbers.com/viewthread.php?tid=24850
another option is to put a bigger engine in there, the common favorites are the t4 kombi motor and the ej22 subaru motor. both conversion are well documented on here
droopz ·
Thanks heaps dude. Looks like most of the cheap stuff has already been done. I might look into a T4 conversion but it looks like it might be more money that its worth to me. This is just a toy for playing in the dirt with.
Thanks again dude.
barls ·
not a problem you might want to try a big bore kit then and a cam
lohoon ·
On a budget the cleverest thing to do is an oil change,tappet adjustment,new pionts,check yer plugs n leads and timing.A bit of a carbi tune - wala
Then at least you know what you've got is running at its best
And if playing in the dirt get a quality air filter and oil it up!
droopz ·
Thanks both of you! Where could i order a 'big bire kit' from and what dies it entail?
All the things you mentioned lohoon are definatly first on the lis though. Thanks again.
barls ·
its a set of pistons and barrels that are bigger than stock. most vw places carry them in stock
it does mean pulling the heads but you can increase the engine size to 1680 with out machining
pete wood ·
are 1679 barrels any good?
I heard they overheat easily and warp causing blowby between the head and the barrel. Is this true?
