Skip to content
Aussieveedubbers
sink
Share Share on Facebook Share on X Share on Reddit
mox3772 Casual Dubber
29 posts · joined Apr 2003 ·
#36420
Hi i got a sink in my kombi but there is no water tank and there are 2 tubes coming out underneith one comes from the plug hole and the other goes up to the tap so if i squirt the hose up it water comes out the tap. whats the deal with this should i have a water tank and pump????
sand kombi Officially Full-On Dubber
345 posts · joined Feb 2003 ·
#36431
There should be a pump tap[you move the tap knob up and down to create the suction]. I assume there sould be a tank either under the floor or under the sink in the cupboard ???. I have a camper which I'm useing for parts for my twin cab,it has the pump & sink,and the hose to the tap must just sit in a 20ltr drum or something ????? hope this helps
:thumb
MIKE.
VW'S DON'T LEAK OIL, THEY JUST LEAVE THEIR MARK !!!
KOM123 Smiling Assassin
1,164 posts · joined Aug 2002 ·
#36478
Whereabouts are you Mox? Perhaps I could show you the sink and stove setups in our Kombi 🙂
#36501
Yeah if you could that would be excellant Im in perth in a suburb called greenwood its about a 15 minute drive from the city
#36502
ah just see your location is sydney thanx for the offer anyway mate much appreciated:thumb
baybuscamperkid prince of insufficient light, ruler of heck
4,316 posts · joined Aug 2002 ·
#36536
that type of camper is it? i have a large flat tank that sits beneath the rear seats, holds heaps of water and pumps up to sink by hand. drain just goes thru floor.
#36650
Hmm, will have to take some photos of our setup when I get a chance. Basically the tube coming from your sink should be draining the water out somewhere. On most original setups this is often out through a hole in the floor. As I didn't want to put a hole through our floor (it had been re-covered at some stage of its life blocking the hole, I just connect the sink tubing to a longer piece that I can run out of the Kombi door into a trench or bucket. The tubing from the tap of some setups again goes through the floor and into an external water tank sitting under the Kombi. The tap setup can be like a manual pump or you can fit an electric pump. I never put the external tank back under the Kombi because I can't be sure of the internal condition of the tank i.e. is there rust or other contaminents. I got a quote to buy a new stainless steel tank (not fitted) and it was about $400. The stainless steel was very thin too and looked as though it would cave in pretty easily if you bottomed out on something. Most of the places we go have a readily accessible water supply only so instead as a backup I have a 35 litre jerry can sitting inside one of our cupboard areas which I have the tube running from the tap pump into.
Hope this all makes sense 🙂
[Edited on 6-4-2003 by KOM123]
Bobbles Casual Dubber
28 posts · joined Sep 2002 ·
#36810
A VW wrecker in Adelaide, 'Volksfactory', has several of the fibreglass underfloor tanks from Bay Window kombi campers. They have all the hose connections, and fit up between the sill and chassis rail, so they don't protrude beneath the vehicle. (They are about 10mm too wide to go in the same place in my 84 camper). I think they are about 60 litres. I guess any VW wrecker with campers in the yard would have some of these.
Bob
