What sort of Jack should I buy, meaning brand. What quality can i expect for $100? Thinking jack to lift engine.
Volkswagen ist der strassekoning - Vergnügen fahren finden!
$100 isnt going to get you much exept alot of trouble and hard work!
you need a trolley jack,bigger the better,if you can lift the car 2 feet you can pull the motor from under it after you have dropped the motor on the floor.
dont get a cheapie from super cheap autos or wherever, it will twist and break, even if you get a good second hand one that will be better than a cheap crap new one!
take care. jon
3 1959 cadillacs
1 musso
2 early notchbacks
2 split kombis
2 split panels
1 split ute
1 low light panel
1 ex-pmg bay
1 country buggy
1 beetle ute
1 14" syncro caravelle
1 16" syncro doka
1 golf cabrio
1 vw camper trailer
2 3meter bombs
thats what i thought, and wondered why they offered them..thanks vwjon
yeah ive had a few cheapies and WOFTAM to that.. spend some dollars and get a good industrial type one, it'll last for eons.. worth it in the end..
two is better cause you can remove engines from buses heaps quicker.. 🙂
Fantasy
http://seventhchronicle.com
Barrels
www.barrelman.com.au
I have 3, a large (890mm of lift industrial one) a smaller one with about 400mm of lift (like a normal mechanics jack) and a little super cheap $20 one which i put in the boot and use to change tires at the track. For $20 you can;t go wrong for changing tires.
Go hard or go home!!!!
i have a supercheap trolley jack and have used it to remove my engine many times with no troubles.
cost about 45 bucks i think its just a little trolley jack but i put a flat peice of wood on the cup to spread the weight and cushin the engine from damage.
a bit more difficult than a larger jack as u have to balance the engine while raising it whereas with a larger jacking cup surface the engine will pretty much just sit there and balance it self.
i have a baja with a reasonable amount of clearance with the rear and i find with the peice of wood it still does the job, otherwise i just put some of my spare lower profile wheels and tyres on the back to bring it down a bit.
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
