POR-15
https://forums.aussieveedubbers.com/threads/57898/por-15
Spellbound ·
POR-15
Not sure if this is the right area of the forum. Apologies mods if it is not.
I will be getting my 76 pan back in a week or so and I need to clean up the whole chassis/suspension area. Having never done this before I am a little perplexed as to what product to use.
I have been told on several occasions thet POR-15 would be the way to go, providing I follow the instructions. This was always going to be the plan until I was advised otherwise. I was told that POR-15 is great if the area/components are sandblasted first, however if this is not done then it will flake off. Sandblasting is not on the agenda, merely taking to the bars etc with a steel brush and then a paint. Is this info correct? Does anyone here have experience with POR-15 or any other product that I should consider?
Any help would be greatly appreciated.
Cheers.
oval TOFU ·
POR must be applied to bare prepped metal (with two other POR products) in order for it to adhere and perform properly. Rustbullet is another option that takes less prep... there's a few threads on it in here, so do a search and ye shall find.. welcome to the forum!
Spellbound ·
oval TOFU wrote:POR must be applied to bare prepped metal (with two other POR products) in order for it to adhere and perform properly. Rustbullet is another option that takes less prep... there's a few threads on it in here, so do a search and ye shall find.. welcome to the forum!
Thanks for that. I have spent the last hour or so looking around the forum - some great info!
By bare prepped metal, you meen blasted?
I was aware of the other products. If I sand back say the torsion bars, apply the other two products then topcoat with POR paint, it won't adhere?
oval TOFU ·
I think if you blast the metal, it would be the best, but neccessary. As long as it's bare metal and you Marine Clean and Metal Prep it thoroughly, it should be ok... wait for some other opinions though, i've only done my fuel tank and that was bare metal already.. it's still going strong though
Spellbound ·
Hmmm..now I'm confused.
Rust Bullet apears to be easier to use. Where is this available from and how does the price compare to POR?
Anyone else have any ideas?
Spellbound ·
Anyone??🤪
megalania ·
volksfolks.biz
Spellbound ·
megalania wrote:volksfolks.biz
doesn't help me :duh
Ive always had good results with White Knight products, except their chassis black which is not petrol proof. After all the horror stories I hear about POR, I think that I will use their gloss black again on my 1303.
pod ·
http://rustbullet.com/?gclid=CIjX046XmYgCFRcbYQodmQPYXA
info about rust bullet
Spellbound ·
Thanks for the replies guys.
Pod, I have visited the rust bullet site. Im wondering if this is the only way I can source the product or am I able to go into a parts specialist somewhere and buy it off the shelf?
And,,,has anyone actually used it?
I'll suss out the White Knight range too 1303Steve. Cheers.
A bit of info on the White Knight products. http://www.infolink.com.au/articles/68/0C03F268.aspx
Volksaddict ·
Ummm...anything you do will be a compromise if you dont blast ...spot painting or overcoating with any epoxy based products will more than likely cause a reaction withn existing coating (ie you can put single pac paints over two pac but not the reverse!!)...most industrial paint cos such as Altex Coatings ,Watty and Jotun all have a product to lock in any untreated rust and in my experience they are 90% successful with the first application ...but inevitably a spot or two will fail ..most often thru brushing only one coat on ...brushing doesnt always cover..two or three coats and a rub if necessary muuuuuch better.......
Spellbound ·
Thanks for the advice Volksaddict. Blasting is above and beyond my limited budget at this stage so any advice on the best prep and product is appreciated. One thing I do have is time, so a coat, rub back and another coat or two is not an issue.
Will have a look at the paints you mentioned...cheers.
Still curious about Rust Bullet though...any info/experience would be great.
VolksFolks ·
I have dropped my site for the time being, but have some stock left, u2u me
http://forums.aussieveedubbers.com/viewtopic.php?tid=54596#pid538307
[ Edited on 2-11-06 by VolksFolks ]
Spellbound ·
You have u2u 😉
