I have a low Km 2110cc stroker for sale. The motor is a complete longblock (does not include carbies or tinware)
Details:
AS41 case bored for 90.5mm
Mahle 90.5mm barrels and “B” pistons.
10mm case savers installed.
CB Performance 82mm Counterweight Crankshaft.
CB Performance 5.4 inch “H” beam rods.
Lightened Flywheel (13lbs)
Near new Sachs Clutch and Pressure plate.
All parts professionally balanced.
CB Performance 044 (40x35.5) heads ported and valves unshrouded.
Engle 110 cam.
Chromoly pushrods with 1.1 rockers on Empi solid shafts and Bugpak Swivel Feet.
Compression is set at a healthy 9.0:1.
Oiling is handled by a full flow pump.
Ignition is Bosch 009.
1 5/8 full merged stainless exhaust and stainless fatboy muffler.
Engine breather to alloy tappet covers, oil filler and fuel pump block off.
Large volume Berg style deep sump.
(temp and pressure sender not included)
This combination gives plenty of torque and would be perfect for any beetle or VW that suits a type 1 upright motor.
The motor is currently in a vehicle and can be test driven by appointment. The vehicle is in QLD for the next two weeks and will then be located in NSW.
Price: $3900... (well below the cost of the parts alone)
Price of above engine less exhaust: $3400... BARGAIN
This is the same motor that was offered for sale last year.
http://forums.aussieveedubbers.com/viewtopic.php?tid=42929#pid410983
[ Edited on 18-7-07 by Craig Torrens ]
[ Edited on 22-7-07 by Craig Torrens ]
[ Edited on 23-7-07 by Craig Torrens ]
