Skip to content
Aussieveedubbers
sling
Share Share on Facebook Share on X Share on Reddit
badkarmann Seriously Crusin Dubber
121 posts · joined Mar 2008 ·
#701281
have a oil leak around the sling whats the best fix
vwsteve karmann crazy
2,087 posts · joined Jul 2006 ·
#701290
mine has that too, so annoying! you can try and take the pulley off first and try cleaning the spiral grove first, it may help if blocked other wise like vw54 mentioned
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
matberry Moderator Go hard or go home
8,114 posts · joined Mar 2006 ·
#701291
Might be high internal case pressure from not enough breathing/ventilation, blocked breather or worn engine.
#701292
Or I have an engine here where the slinger was fitted backwards !!
#702133
been told an oil catcher box to relive crank case pressure would work
yes or no guys
hercules Learner Dubber
7 posts · joined Jan 2009 ·
#702316
maybe cross fingers
Bizarre Moderator The artist formerly known as blue74l
12,785 posts · joined Aug 2002 ·
#702387
badkarmann wrote:been told an oil catcher box to relive crank case pressure would work
yes or no guys
Depends
WHY do you have crankcase pressure
Sure all motors have some
Even stock. That is why they have a breather hose.
What set up do you have at the moment for crank case relief?
#702388
looking at some pics of your motor the only relief i can see is a small than stock braded hose going down
Is that it??
Are your rocker covers vented??
If that is all you have i am guessing that is your poblem
