Trouble getting response!
https://forums.aussieveedubbers.com/threads/98868/trouble-getting-response
kombirestorer ·
I am new to this site, so accept that I am probably making errors in communicating with a seller. I am interested in finding out if the 40 Dellorto carb advertised on this site is suitable for my kombi.
I have now inserted several posts - a couple to ensure I had posted 5 times, to effect a PM answer. I have then sent a PM to the advertiser/seller. Is the reason I have not received a response, simply because the seller has not logged back on to this site?
Appreciate any other advice you can offer, either on the carb's application etc to my kombi, and my use of the tools available on this site.
h ·
welcome to here
yep if the guy hasn't returned to the site that'll do it
go to pms click out box n see if the pm has indeed been read then you can see if it has been read or not
cheers pauly
Whats the link to the carbies I can send you there direct email
kombirestorer ·
The advert "Dellorto 40 DRLA carb" is on the Selling Swapping Parts section of this site. He calls himself "Fastie" - (seriously crusin dubber). Not sure how else to describe as I do not understand the terminology "link", on this site.
appreciate that address if you can identify from this info.
donn ·
http://forums.aussieveedubbers.com/viewtopic.php?tid=98604
On the add go to the top and coppy the link then paste it. 👍
empi ·
these would fit depending on the manifolds u use and the type of engine u have.
Klaus ·
you'd be better off with a set of kadrons as they would be similar $$ for a rebuilt 2nd hand set
barls ·
heres possibly why you have got a response
last active
17-9-12 at 14:18
hasnt been here in a couple for days im sure he will once hes back
so did u get a response ???
kombirestorer ·
Response received, thanks.
