Yes it up for sale after 20 years
1965 Orange Smoothie
1600 brand new Engine, Freeway flyer Gearbox, Genuine Porsche Fuchs 15 in Polish Mags, no chrome.
Contact David Birchall 0415-957-030 full description send Email to dbirchall54@gmail.com
$22000.00 or ONO
Sunny Sydney 2210
Any Questions answered
How did you fit the Golf steering wheel? Adapter, Golf steering column or ?
Cheers.....Wayne
Wayne
good question not easy to do. the original inner bonnet section is pressed with indentations to allow the steering column and fuse box to fit. it
wont allow the golf column to sit correct and flat under the dash
I cut out a section approx. 300mm x 200mm and welding in flat sheet metal to allow the golf steering column to sit flat against the sheet metal
this also allowed a bigger Type 3 fuse box that uses the indicator, headlight and intermittent washer modules to be fitted and a Audi headlight and
hazard flasher switch under the dash, so I don't have any switches of radio on the dash its full plated to fill in the original holes for radio s,
speakers n switches etc
So I used the Mark 1 golf column with wiper switch on lever with the outer column housing bolted to the new flat sheet metal and used the outer
column tube to run down the original beetle firewall steering tube hole.
I used the lower section off the 65 for the steering box end. I made a stepped bush approx. 200mm long to fit in the golf section and the Beetle
section, Both tubes are different IDs and it had to be stepped to give the strength also crossed pinned it into position, and hasn't moved in 20
years
Hope this explains
Thanks. Impressive work. Photo also answered my question about the speaker mounts. Good luck with the sale
Cheers.... Wayne
bump
in VMA this month
up
boot
Going to fit new rebuilt 1600 single port engine soon
$15,000
new 1600 engine fitted and running nice
Price dropped to $29000.00
bump
bump
bump
mn
value
WAITING
YEP
$10,000
come 0n your going down
hello
Not trying to be rude - but over 2700 people have viewed your ad on this site. If you're serious about trying to sell it, have you considered advertising it on Ebay, Carsales, Gumtree etc?
yes
had over 100 enquirers but they all want the car for $100 or so
none have ever owned or driven a VW before or realize the work that has been done
Belly button lint is one million dollars per ounce
Buttons are useless as i wear T Shirts
