Has anyone seen or done this position for the radiator?. I am toying with the idea and will add a gurney lip / scoop to direct air. I will keep both
rad fans and couple them so they both are activated when reaching 90C.
Any ideas, thoughts if it would be ok to try.
Cheers,
Binner
or if i keep my rad underneath but add one of these inline electric , fully programmable pump.......
http://daviescraig.com.au/electric-water-pumps
EWP 115 with controller
I personally would go with the idea you are toying with depending on how hot it runs already, I am considering putting the radiator on top of the engine in my baja.
Won't work in that position.
I purchased a panel with an EJ20 with the radiator in that position (albeit higher). The owner could not keep it cool and had the fans wired to run at
all times the ignition was on. Just doesn't get the airflow.
If you're planning a vented engine lid - don't waste a good lid.
There's heaps of info on here as to what works or not.
I don't have a lid just a hacked up whale-tail with a radiator support built in.
What was wrong with where you had it underneath?
If off road , up front out of harms way! (Where it should be..lol)
I'm mounting mine under the belly, but I've got 33 inch tyres and about 6 inch lift
https://forums.aussieveedubbers.com/viewtopic.php?tid=95862
