[ Total Views: 750 | Total Replies: 8 | Thread Id: 101488 ]
Author: Subject:  Wiring for Alternator and tacho
MemberLateral
A.k.a.: Greg Hanley
posted on April 6th, 2013 at 02:14 PM
Hi guys
I need to rewire the Alternator in my 1967 beetle.
(See attached photo)
The B+ terminal goes to the Start motor. Does the D+ go to the Alternator light in the dash?
Also, my alternator was not directly earthed via the Earth Screw on the side of the housing...should it be?
I also having trouble tracing the wiring from the VDO Tacho to the rear of the car. As the car was running EFI with a Wasted Spark coil setup, am I correct in assuming that the Tacho would have been connected to the Alternator in order to get its "pulse"? If so, could the tacho therefore be connected somewhere behind the dash?
Regards
Greg
MemberAnthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on April 6th, 2013 at 02:25 PM
Have a look here
http://www.vw-resource.com/alternator_wiring.html
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 6th, 2013 at 02:30 PM
Oh and Tacho feed wire to - terminal on coil.
Tacho gets its pulse from Ignition system not charging system.
1974 Chevrolet Luv
MemberLateral
A.k.a.: Greg Hanley
posted on April 6th, 2013 at 04:12 PM
Thanks Nicko,
I was confused as I only had the wiring diagram page from the VDO Tacho and it shows that you can connect the Tacho to the Alternator and as the car did not originally have a standard coil, I thought that it was therefore connected to the alternator.
It appears that that is only able to be done on diesel engines.
Thanks for the link, I already saw it and basically wanted confirmation.
What about the question regarding "earthing"?
Regards
Greg
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 6th, 2013 at 04:38 PM
Ive never seen one earthed externally using that screw. Usually it is just left the way it is. The alternator is grounded and regulated internally.
Someone more knowledgeable may chime in here and correct me but AFAIK you will be fine without an external earth.
1974 Chevrolet Luv
Membernils
Threads: 65
posted on April 6th, 2013 at 05:16 PM
never seen one earthed either, fibreglass fan shroud maybe?
Quit calling rust patina
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 6th, 2013 at 06:09 PM
That would make sense.
1974 Chevrolet Luv
MemberLateral
A.k.a.: Greg Hanley
posted on April 6th, 2013 at 07:35 PM
Thanks guys....
Memberpod
A.k.a.: paul mrvw061
Mood: could be better
posted on April 6th, 2013 at 07:42 PM
mines earthed i used this diagram
check wbsite for location
All Welcome
http://www.flatfour.org/
