| [ Total Views: 1400 | Total Replies: 23 | Thread Id: 102285 ] |
Bizarre
| posted on June 2nd, 2013 at 08:57 PM |
air box for dual carbs
Does anyone run an airbox set up for dual carbs??
Something like the CSP set up??
My car lives outside 24/7 and I have always had trouble over the years with popping and farting, blocked jets and the sort.
Anyway - I made up a sheet that blocked off the vents on a late deck lid. A bit of light plastic that hangs down and effectively covers the filters
when parked.
I have number plate and tail light cut outs so heaps of air is coming in.
Anyway - since doing this for the last 3 weeks, it has been pissing down at times in Sydney - and not a pop or fart. Perfect.
So - my troubles is definitely water related and I need to make up some sort of air box for my Dells.
Bizarre
| posted on June 2nd, 2013 at 09:03 PM |
Do filter socks protect any better for water??
1303Steve
| posted on June 2nd, 2013 at 09:06 PM |
A guy on here with a Baja made some sort of air box using Commodore air boxes I think, it looked like a good idea.
You could fit turbo tops to the air cleaners and run a pod on each end or run into a central box.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on June 2nd, 2013 at 09:11 PM |
C'mon Steve, surely you have the blueprints for the powertune setup ????!!!!
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on June 3rd, 2013 at 08:48 AM |
posted by 1303Steve
Smiley! On Alyce the baja,
(ô_!_/ô) (ô_!_/ô)
Joel
| posted on June 3rd, 2013 at 10:13 AM |
Didn't Barls make one from an Excel air box aswell I seem to recall.
I started making one from the stock Beetle air box to shut the induction roar from my old webers.
just needs a second 2" outlet on the bottom and ducting to each side.
Are you still using IDFs?
the turbo hats you can get for them make excellent air box connectors.
Bizarre
| posted on June 3rd, 2013 at 11:00 AM |
Yeah, still running DRLAs.
It isn't the noise, it's the water from living outside.
Going to try and get some turbo hats and go from there.
sander288
"Bolt-on Master"
Threads: 183
| posted on June 3rd, 2013 at 11:25 AM |
http://www.gwd-weiser.de/?page_id=343
Craig Torrens
Threads: 347
| posted on June 3rd, 2013 at 11:40 AM |
Looks good, just need someone to translate !!
sander288
"Bolt-on Master"
Threads: 183
| posted on June 3rd, 2013 at 12:00 PM |
posted by Craig Torrens
Use Google Chrome it translates the page for you; or learn german
Bizarre
| posted on June 3rd, 2013 at 12:22 PM |
Yeah - only looking on my phone at the moment bu it looks like the CSP set up.
Would like that but really can't justify the price.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on June 3rd, 2013 at 02:34 PM |
http://forums.aussieveedubbers.com/viewtopic.php?tid=94554&page=1#pid879217
Bizarre
| posted on June 3rd, 2013 at 06:35 PM |
Thanks - that is exactly what i was thinking
I have flicked him a question or 2
Wondering if anyone knows what the box is?
Looks like a 1600 but the intake seems more rounded??
| Error |
hulbyw
Threads: 133
Mood: I'm OK, RU?
| posted on June 3rd, 2013 at 07:40 PM |
The oil vapour hose connects in a different spot on my Beetle air cleaner, however that would be easy to change, so I reckon it is a Beetle one
Joel
| posted on June 3rd, 2013 at 08:07 PM |
Its a stock 74-76 Beetle one, just facing arse about with the snout removed.
Bizarre
| posted on June 3rd, 2013 at 08:10 PM |
yeah - it was the lack of snout that threw me
mmm... have to start having a play
Joel
| posted on June 3rd, 2013 at 08:31 PM |
It's similar to what I was building but leaving the snout with a functioning preheat flap setup intact.
1303Steve
| posted on June 4th, 2013 at 08:38 AM |
Maybe you could use a twin carb Kombi air box?
Craig Torrens
Threads: 347
| posted on June 4th, 2013 at 09:51 AM |
Barry, I have a 76 airbox if you need one
narumi
I'll do it tomorrow
Threads: 8
Theme: UltimaBB Psyche Red
| posted on June 6th, 2013 at 12:48 AM |
the idf i pulled off of alfa romeo 33 has the 90 degree bend hat thing that goes to
the center filter box like your previous post.
I have a set in the shed but never bothered trying anything
Bizarre
| posted on June 6th, 2013 at 09:21 AM |
There is some reason the Alfa box doesn't work.
Or so I have been told.
Think it has to do with the "tops" going the wrong way or something.
Would appreciate if you could have a look and confirm.
Flintstones
Threads: 69
| posted on June 6th, 2013 at 09:26 PM |
posted by Bizarre
Barry, i think the alfa tops will hit the fanshroud....as they are come off perpendicular to the webers
Bizarre
| posted on June 6th, 2013 at 09:41 PM |
Ahhh.............. that's the reason
Maybe a flat fan
| Error |
modnrod
Threads: 50
Mood: Old School Volksies!
| posted on June 6th, 2013 at 10:31 PM |
Can I add an unproven idea that I'm going to try myself for my Beetle?
If it works, then could you please tell me?
Pretty simple, stacks on your Dells/Webers/Expensive-Italian-fuel-stuffer-upperers, then use flex tubing (seal it up to the stacks with foam and cable
ties, done deal) up to an airbox from a Beetle/Commodore/Skyline/whatever, that mounts to the fan shroud just above the alternator, same as the pic
above.
Light, quiet, cheap filter. Worth thinking along those lines maybe?
