[ Total Views: 1102 | Total Replies: 15 | Thread Id: 102968 ]
Author: Subject:  CB Rhino Coupler
posted on August 3rd, 2013 at 02:17 PM
CB Rhino Coupler
just thought I would put this out there
i just put a CB Performance Rhino Super Couple on my gearbox
Absolutely f'cking lovely!
Got it from VVDS and Boris gave it a little tickle with a welder as the clamp can come loose and spin
Yep - twice as much as rubbish.
They are suppose to be noisy - hey, I have a Berg mid mount and twin Dells
But the solid shift - clunk - clunk - just lovely
I'm just get happy when you buy something, however small, and it not only works, but exceeds.
Get one!
Member66deluxe
Threads: 139
posted on August 3rd, 2013 at 02:20 PM
Got one in my 66 and agree with you 100%.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
Memberpsimitar
Threads: 148
posted on August 3rd, 2013 at 05:45 PM
Ah, at last a well fitting coupler :)
I modded my orig VW coupler with new rubbers to get a tight fit to the rubbers and no noticeable play in it. Meant having to cut the cages that hold the rubbers and reform then to make a tight tight around the rubbers. Then weld the cage back up :)
posted on August 3rd, 2013 at 05:49 PM
my new rubbers turned to mush in under 2 years
MemberPaulc1964au
posted on August 3rd, 2013 at 05:50 PM
where did you purchase from maybe i should replace mine while boris has the car
posted on August 3rd, 2013 at 06:04 PM
Do it :tu:
Memberkarmann141
Threads: 48
posted on August 3rd, 2013 at 09:07 PM
Totally agree, they're excellent.
Bought 2 straight from CB Performance for $48 including postage - delivered in a week.
1961 K Ghia - Porsche 5 sp, EJ20T, Brembo's, Dble A arm susp
1974 L Bug - Porsche 944 brakes, Boxster 16's
1974 Bay Camper - EJ20, twin radiators, Boxster 16x7's
Half Beetle trailer with Boxster 16x7's
2011 Tiguan TDI 4Motion
2010 LR Discovery 4 TDV
Memberpsimitar
Threads: 148
posted on August 4th, 2013 at 12:34 AM
I buy from a place in the UK that doesn't sell the Empi/chinese tat. German quality and you can tell the difference :)
Member66deluxe
Threads: 139
posted on August 4th, 2013 at 11:14 AM
And that place is?
Memberpsimitar
Threads: 148
posted on August 4th, 2013 at 03:15 PM
And that place is?
Custom and Commercial. They have a good line of german quality items. I've bought rubbers for my doors and they are as good as Wolfsberg Wests and those are excellent quality. Dunno if they still sell the bushes seperate but they did a few years back. :)
Membersander288
"Bolt-on Master"
Threads: 183
posted on August 4th, 2013 at 05:42 PM
yep got one in mine from VVDS awesome
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membervlad01
Mood: Side ways
posted on August 5th, 2013 at 06:15 PM
whats this coupling?
71 notchback,
Memberpsimitar
Threads: 148
posted on August 5th, 2013 at 06:42 PM
Do they not use them on T3s? Gear stick selector linkage shaft to gearbox hockey stick. Under the rear seat inspection panel.
Or is someone being sarcastic? :lol:
Membervlad01
Mood: Side ways
posted on August 5th, 2013 at 07:18 PM
umm I was a bit confused why rubber is mentioned? and all this "which is better"?
yes type 3 have a coupling there which is accessed from under the car and its simple yoke type coupling so I am failing to see where rubber mounts? are involved. I though you guys were talking about the front gearbox mount or something along those lines.
71 notchback,
MemberAussie Dubbin
Threads: 90
posted on August 5th, 2013 at 11:43 PM
I have just shimmed my old genuine ones up with washers and made sure I had a tight snug fit. 3cars now and no replacement parts needed? Sounds like a good part, but not sure how buggered a lose part is, just loose.
Memberpsimitar
Threads: 148
posted on August 6th, 2013 at 04:07 PM
It is a yoke and the pin that goes thru the yoke and connects to the g/box has square rubber bushes either side of the yoke. Maybe T3 coupler is solid style yoke like a UJ.
