| [ Total Views: 767 | Total Replies: 5 | Thread Id: 104141 ] |
Newt
Threads: 82
Mood: Born 10 minutes late & never caught up.
| posted on November 20th, 2013 at 11:02 PM |
Painting inside of rear torsion tube
Hi Guys,
Has anyone found an easy way to paint the inside of the rear torsion tube.
I figured that while it was appart it wouldnt hurt to do this.
Newt
It is as it is - If you didnt enjoy today, you've missed the opportunity.
vw54
| posted on November 21st, 2013 at 05:24 AM |
brush on a stick should do the trick
get a plastic brush n bend to 90 deg attach to a stick
matberry
| posted on November 21st, 2013 at 08:17 AM |
I go the rust proof direction as to me paint will only lock in the rust that's already there, even surface rust will continue to gro when the
moisture is locked in. And I use rust prevention that does not dry and also seal in the rust/moisture.
Newt
Threads: 82
| posted on November 22nd, 2013 at 09:30 PM |
Matt
Were you thinking about a POR 15 type process, fish oil, or something else?
Ta
Newt
vw54
| posted on November 22nd, 2013 at 11:34 PM |
yep Matts right u have to get ride of the rust n crap in there b 4 u use the 90 deg brush
matberry
| posted on November 23rd, 2013 at 09:48 AM |
PM replied to Roger.
