[ Total Views: 1222 | Total Replies: 8 | Thread Id: 105397 ]
Author: Subject:  Type 3 Questions .....
MemberDibsy
Threads: 37
posted on March 12th, 2014 at 04:17 PM
Hi,
Couple of questions....
Is the front beam with disc brakes from a 69 a straight swop if I want to put it on a 66 .. or will the disc brake parts fit onto a 66 drum brake beam ?
How hard is it to convert a swing axle Gearbox 66 Squareback into an IRS Rear ? is it a matter of cutting out the gearbox horns and bolting in the later subframe or is it more involved ?
Thanks,
Mark.
Memberrebel
Threads: 48
posted on March 12th, 2014 at 05:40 PM
yes straight swap for front and unbolt whole rear subframe for a straight swap back.
but youll have to put in engine mounts for the body and motor as early is held by horns and late irs is mounted by a moustache bar.
Memberrebel
Threads: 48
posted on March 12th, 2014 at 05:41 PM
you could also keep the horns and weld in the irs
MemberDibsy
Threads: 37
posted on March 12th, 2014 at 09:59 PM
Thanks Rob.
Memberempi
A.k.a.: Empstar
Mood: thunderous
posted on March 13th, 2014 at 09:14 AM
Change the spindles and all will fit
MemberDibsy
Threads: 37
posted on March 13th, 2014 at 05:15 PM
Spindles on the front beam only - or front and rear ?
Thanks for your help.
Mark.
Membergrumble
Mood: happy all the time
posted on March 13th, 2014 at 06:28 PM
I have a complete 73 type 3 front end in Taree if interested.
MemberDibsy
Threads: 37
posted on March 13th, 2014 at 10:36 PM
Thanks for the offer, I have a couple myself hence seeing if they can be used in upgrading an earlier Type 3.
Cheers,
Mark.
Memberempi
A.k.a.: Empstar
Mood: thunderous
posted on March 14th, 2014 at 12:25 PM
Type 3 beams are all ball joint, so you can just change the spindles to disc and the master cylinder to dual type from a later car, the rear subframe unbolts from the pan but to use the IRS subframe you will need to weld in the engine cross bar mounts as early cars don have these.
[ Queries: 40 ] [ PHP: 14.7% - SQL: 85.3% ]
