[ Total Views: 775 | Total Replies: 4 | Thread Id: 106025 ]
Author: Subject:  engine missing
Memberchrissys beetle
Threads: 32
Mood: HAPPY
posted on May 12th, 2014 at 05:50 PM
engine missing
Hi We have a 71 beetle and the damn thing is missing
it appears to idle ok
I did all the normal things like clean the points ,cap and plugs
Checked the wiring
anything else I missed?.
I spose its obvious but I don't know what else to check
Graeme
MemberLUFTMEISTER
Threads: 119
posted on May 12th, 2014 at 06:01 PM
Start the car in the dark,lift engine lid & look for any arching from plug leads or dissy. Cheers
MemberACE76
Threads: 19
Mood: ACE 30 FOR SALE!
posted on May 12th, 2014 at 06:12 PM
Thought you meant it had fallen out!
Check the rotor button is on firmly, and has its little spring inside so it doesn't flop around when spinning. It must have no cracks at all, and if has a resistor shoukd be about 5 kohm (5000 ohm), can check with an ordinary multimeter. The Carbon contact must be inside the top of dist. cap. Cracks/tracks inside or outside the cap can be very hard to see, esp. on black caps. One minor looking track can cause mis-fire.
Is the condenser OK? Can check by opening points with ign. on - should be only a tiny spark jump the points (you can hear it 'click' if can't see it).
If all that looks OK, try changing the coil (- terminal to points; + terminal to ign.) ANY coil can fail, or become 'intermittent' in behaviour, the red GT40 type seem prone to that.
ACE 30 & ACE 40 oil: specially formulated for your Air Cooled Engine...
Delivery free Outer Eastern Melb. & Dandenong Ranges.
from$19 for 2.5L (spot-on for 1 fill, re-use bottle to measure), or $29 for 5L (2 fills)
Membergrumble
Mood: happy all the time
posted on May 12th, 2014 at 06:38 PM
Check the dwell angle/point gap as the points may have closed up.
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on May 13th, 2014 at 12:46 PM
Does it only miss underload like when taking off?
Do you have 009 dissy (mechanical advance) and 34 pict 3 by any chance?
(ô_!_/ô) (ô_!_/ô)
