[ Total Views: 680 | Total Replies: 3 | Thread Id: 106028 ]
Author: Subject:  Timing electronic ignition
Memberjldathome
Threads: 6
posted on May 12th, 2014 at 06:44 PM
I recently swapped out my Bosch points based distributor as the cams had had it.
First mistake was buying an Ebay special - one of the clear capped electronic variants.
Anyways - having fitted the electronic version, I'm now having issues dialling in the timing.
If I follow the advice I've researched, which seems to be to strobe light for 28-30 degrees at 2800-3000 rpms, I can't get a decent idle.
Of course I've played with the carb (a new 34PICT Bocar - probably my next mistake) to try any counteract the action of getting the timing right, but seemingly to no avail.
Anyone have any tips they can share?...please don't suggest switching back to the Bosch....I burnt that having wired it back to the wrong coil terminal at the weekend....now awaiting a new condenser.
No rush - If you do have some magic to share, I've still got to get a head repair to fix a stripped No 1 spark plug hole....arrrrrgggghhhh. :grind:
Memberpsimitar
Threads: 148
posted on May 13th, 2014 at 07:51 AM
Um, kinda not helped yourself here by fitting two new things at the same time.
Ideally you would fit the carb first with a correctly timed dizzy to dial the carb in and then fit the dizzy, or vice versa, but both together makes trouble shooting far more difficult.
I would actually start by putting points on the new dizzy cos these cheap, shit elec units have a habit of being bad right from leaving the factory.
Or you could pop the magnet ring and elec baseplate from the new dizzy and put on the old bosch as those new cheap dizzys can have loads of play in the shaft from new.
By you timing method you use a 009 instead of an SVDA? 009 are worthless paperweights and the orig SVDA will give better driving and MPG.
Web search for carb tuning the PICT as quite a few indepth pages available.
Memberjldathome
Threads: 6
posted on May 13th, 2014 at 06:47 PM
Cheers - you've confirmed what I already knew but failed to act on (in time).
I had the car dragged to Pete @ Custom VeeDub this morning, so once he's sorted the head thread I reckon I'll try and source a Bosch dizzy with points and convert that to electronic once I've resolved the timing and 34-Pict tune.
Memberpsimitar
Threads: 148
posted on May 14th, 2014 at 04:00 AM
no worries :) Hope it works out for ya.
[ Queries: 40 ] [ PHP: 3.9% - SQL: 96.1% ]
