[ Total Views: 1267 | Total Replies: 2 | Thread Id: 106522 ]
Author: Subject:  Turbo kit
MemberRodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on July 3rd, 2014 at 07:04 PM
Turbo kit
I have found this turbo kit here that I purchased on one of my US trips a few years back . The header is ceramic coated , is to suit a stock width engine , has a T3 sized turbo with a polished compressor housing , ceramic exhaust housing , a Deltagate mk2 wastegate with a dial a boost controller , complete inlet manifold to suit either Super flow or Comp eliminators , has electronic injectors and fuel rails , has a 50 mm throttle body with TPS installed , air temp sensor and will work with the stock cooling tin . The turbo is mounted 250 mm behind the front pulley and the wastegate is 400 mm from the pulley . This is located in Wollongong NSW and I would like $ 800 for this complete kit . I can also supply you with a new or reco set of heads to suit , ROD , 02-42729920 .
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
MemberRodPenrose
Threads: 330
posted on July 3rd, 2014 at 07:11 PM
Memberturboty
Threads: 26
Mood: good
posted on September 18th, 2014 at 10:56 PM
Hi rod,
What do I need to run this on my 1600 twin port? I tried calling today but couldn't get onto you...
just because its a kit car... doesnt mean its not a vw!
