[ Total Views: 687 | Total Replies: 0 | Thread Id: 106962 ]
Author: Subject:  EMPI Front and Rear Disc Brake Conversion Kit (NEW)
Memberwesdem77
Threads: 17
Theme: UltimaBB Psyche Green
Mood: Optimistic, of course!
exclamation.gif posted on August 23rd, 2014 at 11:58 AM
For '66-67 Beetles/Ghias
Disc Brake Conversion Kit, Front
If you like the great looks of the earlier 5/20 5 bolt pattern wheels on your ride, plus the unsurpassed stopping power of disc brakes, these “Wide 5” Disc Brake Conversion Kits give you the best of both worlds!
The conversion kit includes 2 rotors, 2 calipers with mounting brackets and mounting hardware, pads, new cylinder, new wheel bearings and seals, and new brake hoses.
Compatible with Ball Joint Front End
5 Lug
Brake Resevoir Sold Separately
5/20 5 Bolt Pattern
Fits 15” or Larger Tires
Disc Brake, Rear, Wide Track
This "Wide Track" rear disc brake kit is for off roaders who are looking to increase their rear wheel "track". This kit has the emergency brake cables and comes complete with 1- piece minimum offset 1" extra wide rotors, calipers, pads, emergency brake brackets and all necessary hardware and gaskets for a complete installation. Rotors are threaded for 12mm and 14mm studs.
5/205mm Pattern
E-Brake Included
Fits IRS Suspension Cars
Comes Ready to Bolt On and Go
When installing Disc Brake Kits the Front Brakes should be priority as these take the most load.
When installing Rear Disc Brakes Master Cylinder should be upgraded to 20.60mm. 325-036 or 319-246 or 313-732 dependent on your model.
Bought the kit for $1,100 from Mid American Motorworks (US), plus $150 for the shipping.
Will sell for $700, plus shipping.
The master cylinder is for a left-hand drive, but can be re positioned, if necessary.
***Had to abandon my VW project, so my loss is your gain!!****
Full pictures/listing on eBay.au: # 221530145107
Please message if you have any questions.
'71 U.S. Super Beetle
'68 Aussie convertible Beetle
