[ Total Views: 797 | Total Replies: 5 | Thread Id: 107526 ]
Author: Subject:  Breather Box
Memberlandfall
Threads: 36
posted on October 30th, 2014 at 07:01 AM
Breather Box
How important is a breather box on a 1600 mildly tuned engine?
Or should I just vent into the air filters?
Memberpsimitar
Threads: 148
posted on October 30th, 2014 at 11:16 PM
A baffled plate in the alternator stand is a good idea to help remove oil vapour from the crankcase vapour. Then ducting into the air filters means they won't get so mucky from the oil vapour.
A lot of crankcase pressure can mean a worn engine so for a mild 1600 IMO the breather isn't needed if the engine is in good condition.
Memberlandfall
Threads: 36
posted on October 31st, 2014 at 05:49 AM
Thanks, in the process of purchasing all the necessary bits to rebuild the engine.
Easier to include it in the order than pay freight later.
MemberPerformance Upholstery
Threads: 10
posted on October 31st, 2014 at 09:02 AM
These little breather boxes are good for small engines... I've had good results with them but you must use at least 1/2" hose.
http://www.piersideparts.net/BP3043.html
Cars, boat seats, furniture and more!
0439002870
performanceupholstery@live.com.au
Mt Gravatt east Qld.
Memberlandfall
Threads: 36
smile.gif posted on October 31st, 2014 at 11:11 AM
Thanks also, any suggestions are more than welcome.
The engine upgrade will still be a stock 1600 size, but better components and balanced, hopefully.
Memberpsimitar
Threads: 148
posted on November 1st, 2014 at 02:53 PM
Better off having a bit of pipe welded to the covers as those bolt on spigots leak like crazy after a few years.
