| [ Total Views: 846 | Total Replies: 9 | Thread Id: 108377 ] |
cnfabo
Threads: 140
| posted on February 13th, 2015 at 07:38 PM |
car trailer axle position??
Hi guys,I'm building a single axle car trailer at the moment and want to know how you figure out where to put the axle,I'm aware that with our rear
engined clunkers the axle is usually further back on our trailers but do I have to work it out mathematically or just put it pretty much underneath
the jacking point of the beetle etc...close enough hairy muff????
Thanks....
Stanley
Threads: 270
| posted on February 13th, 2015 at 09:55 PM |
Ultimately comes down to tow ball weight of you car. You can measure someone elses or If you have a set of scales you can work out the CG of your car
and it's a pretty easy calc after that. Probably already worked out somewhere on the net. or I made my chassis sit on a simple angle iron frame and
moved it backwards or forwards to get my desired tow ball weight then tacked it in place. Trailer can then be used for another car style by removing
tacks.
cnfabo
Threads: 140
| posted on February 13th, 2015 at 10:13 PM |
posted by Stanley
tacks.
That's a good idea......
But the axle inline with the jacking point on the bug sounds pretty close you think in general....
1303Steve
| posted on February 14th, 2015 at 01:47 PM |
I use a single axle trailer for front & rear engined cars, back the rear engine cars on, front engine cars go on frontwards.
I could measure it up for you but maybe you could measure other trailers at race meetings etc
cnfabo
Threads: 140
| posted on February 14th, 2015 at 04:22 PM |
posted by 1303Steve
Cheers Steve...I measured up the trailer I borrow off Humpty and made some changes for mine... I've made mine longer behind the beetle with a 800mm
beaver tail....slightly shorter draw bar...anyways,I get it sorted,thanks heaps..
Fabo..
1303Steve
| posted on February 14th, 2015 at 08:01 PM |
Dont weld the mudguards on and then you can move the axle around with a car on it
Stanley
Threads: 270
| posted on February 15th, 2015 at 07:47 PM |
Here's a bit on my build....I can take some measurements if you need. I also have a short draw bar
http://forums.aussieveedubbers.com/viewtopic.php?tid=68967&page=5
cnfabo
Threads: 140
| posted on February 15th, 2015 at 09:39 PM |
Cool build thread man,luved it;-)
Don't worry bout the measurement I've sorted it for now...curious,how much your trailer weighs??
Thanks man...
Stanley
Threads: 270
| posted on February 16th, 2015 at 06:08 PM |
360kgs....I've since mounted a winch and spare tyre so is probably close to 400kgs now
cnfabo
Threads: 140
| posted on February 16th, 2015 at 06:11 PM |
posted by Stanley
Nice and light..thanks dude
