[ Total Views: 1527 | Total Replies: 10 | Thread Id: 109143 ]
Author: Subject:  Positve Ground 71 Beetle
Membermuroc47
Threads: 2
posted on May 28th, 2015 at 07:24 PM
can anyone tell me perhaps if they have come across this before, My 71 is wired Positive Ground, I am happy to switch it around , change the battery and re-polarise the coil, making it regular Negative grounding however will this affect or damage any electrical components, specifically the fuel gauge ?
I know the radio I plan to fit will work but the gauge is a concern to me , has anyone gone through this procedure who can shed some light for me ?
posted on May 28th, 2015 at 07:30 PM
You are 100% sure is is +ve earth
Not saying you are wrong - just saying it is the first beetle I have heard being wired that way.
Would love to know why
The battery wont need changing, just re-wiring / swapping terminals?
Things like radios will need to be swapped around as +ve needs to be +ve
Anything that is "just" a coil (fuel gauge) would just work backwards.
But regulators and the like will need to re-wire.
that is just too weird for me at the moment :borg:
posted on May 28th, 2015 at 07:53 PM
check it with a multi meter first, could be a mislabelled battery
posted on May 28th, 2015 at 07:55 PM
ONLY pommie cars are wire back the front
check as per above
Membermuroc47
Threads: 2
posted on May 28th, 2015 at 08:34 PM
checked the battery and it definitely is connected with positive to earth, would it make a difference to the fuel gauge if I disconnect it before switching over the terminals and depolarising the coil?
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on May 28th, 2015 at 09:31 PM
There may be other things to consider. Depending on the complexity of the items. Coil, Generator, Flasher unit, Headlight relay. Anyone with Auto Elec knowledge on here.
I know with the English cars at our work that are Positive earth, when they convert them, it is not a complicated procedure, as they are 1950's cars usually, and there isn't even a radio installed.
posted on May 28th, 2015 at 10:49 PM
Double check that the wire connected to the positive is actually the ground.
I've seen many people on the forums over the years think they have a positive ground bug but all it is was the ground strap had been remade with red cable so it "looked" like it was positive ground ( stock pos cable is black)
No aircooleds were ever made pos ground and it would be a huge backwards step to convert one, like swapping discs out for drums.
A.k.a.: Pete S
Threads: 312
posted on May 28th, 2015 at 11:03 PM
That is a point. Does the +ve on the battery actually have a short cable that goes from the +ve terminal directly bolted to the body right next to the battery? Ignore any colours. Actually point your finger at the +ve on the battery and follow it to the end of the cable. Or does the -ve terminal go to the body? Take a picture and post it.
posted on May 29th, 2015 at 08:32 AM
I repeat could be a mislabelled battery, only a multi meter will tell you this
Memberbevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on June 1st, 2015 at 08:03 AM
I've heard of people putting a dead flat battery in a pommie car the wrong way around, push starting it and the battery charging backwards. Multimeter first I think.:cool:
Country Buggy King & Link Pin Overhauls, Type 1 & 2 King Pins, General Machining.
http://forums.aussieveedubbers.com/viewtopic.php?tid=74138
My car is KO813
Membermuroc47
Threads: 2
posted on June 1st, 2015 at 01:08 PM
Thanks everyone for the replies and advice, it appears, after some checks that it is only the battery that was connected up wrongly, switched it around, checked all wiring to Generator and regulator and all was correct, everything seems to work fine, radio, fuel gauge etc. and the generator and battery seem to be working/charging okay.
No need to re-polarise the generator either.
[ Queries: 40 ] [ PHP: 15.2% - SQL: 84.8% ]
