[ Total Views: 796 | Total Replies: 3 | Thread Id: 110170 ]
Author: Subject:  Gear boxes - Type 1 v Type 3 swingers
Membermossman
Threads: 30
posted on November 22nd, 2015 at 07:40 AM
Hi Guys,
does anyone know if a type 1 early swing axle gearbox is as strong as a type 3 swing axle box? Or are they the same?
I am installing in a 1960 Baja, but not for crazy offroad stuff just for turning over large wheels in the sand (32" tyres). Just running a 1600 tin port.
I have used type 3 boxes in the past for the wide axles and bigger brakes, but recently damaged the diff.
If I put the wide axles into a type 1 box would it be similar to a type 3 box interns of strength?
Mark
Memberpsimitar
Threads: 148
posted on November 22nd, 2015 at 11:29 PM
Dangerous on here would be the best person to ask cos he re-builds VW boxes for all uses.
Just from the fact though that the T3 is a heavier vehicle then I'd say the T3 are the better box. Also, IIRC the early T1 boxes don't have welded 3rd n 4th gears so can shear under load more easily than the later boxes.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on November 23rd, 2015 at 04:37 AM
No strength difference
Membermossman
Threads: 30
posted on November 23rd, 2015 at 08:25 PM
Thanks for your replies. Ill try the wide axles in the type 1 box and see how it goes.
