| [ Total Views: 801 | Total Replies: 6 | Thread Id: 110175 ] |
oldturtle22
Threads: 57
| posted on November 23rd, 2015 at 09:49 AM |
Steering column radial play. 59 beetle
My 59 beetle has radial play or up and down movement so I purchased a new column bearing kit and nylon bush.
Not sure about the nylon bush though. Mine is either missing or its the wrong part.
My original bush fitted to the column is much smaller and looks like its been heat shrunk on.
The original bearing doesn't seem like its in bad nick.
Are both bushes meant to be installed?
Has anyone got a pictorial breakdown or come across this before?
grumble
Mood: happy all the time
| posted on November 24th, 2015 at 07:05 AM |
From memory some of the early columns had a convoluted metal bush between the bearing and the bush to take up the play.
oldturtle22
Threads: 57
| posted on November 24th, 2015 at 12:59 PM |
Ok. I do recall seeing something like this on one of the parts sites.
Ill check it out again. Thanx
psimitar
Threads: 148
| posted on November 24th, 2015 at 05:44 PM |
Is your column and wheel the early type with the indicator switch held to the column with a metal strap and the wheel is a half batwing type wheel? Or
the later cast indicator that sits ontop of the column with a grub screw to hold it in place and then the classic D type horn ring dishes bakerlite
wheel?
I've got both a 59-60 and a 56 so can easily tell ya what is what
oldturtle22
Threads: 57
| posted on November 24th, 2015 at 06:28 PM |
Hi Mike.
Its the second type. Its got an existing nylon bush but its more like a thick heat shrink.
Amd ive still got ur springplates. Ill try my best to get there before xmas!!!
Cheets bud
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on November 24th, 2015 at 08:47 PM |
posted by grumble
I've got this on my 76 so may be an alternative for all models.
psimitar
Threads: 148
| posted on November 25th, 2015 at 04:50 PM |
posted by oldturtle22
Hi Mike.
Cheets bud
Hiya Chris,
So for my one it has a concave ball bearing type bearing housing pressed into the top of the column. Then a curved washer sits against that bearing
and then there a spring that rests on that bearing and then the underside of the steering wheel.
The early batwing has the metal boss of the wheel slide into a pressed in solid bush at the top of the column and so only grease stops the wheel and
column from binding against each other.
The later ball bearing allows things to roll against each other.
No worries on the spring plates. I sold the pan without them last month as having a bit of a clean out downstairs. Maybe throw me a few bucks and put
the plates for sale on here?
Laters,
Mike
