| [ Total Views: 1135 | Total Replies: 8 | Thread Id: 110286 ] |
Gaston
| posted on December 18th, 2015 at 08:57 AM |
Accelerator (Jerking)
Hey!
I am now the proud owner of a lovely '71 S Bug. Had her serviced and now runs exceptionally, which is a testament to the guys at Custom Vee Dub. My
only concern is that when I release my accelerator pedal suddenly, like when changing gears, she jerks a bit before running smoothly again.
This doesn't happen every gear change (more prominent in the lower gears though), and I'm not sure if it was the way I was driving the car (
say, I need to be more gentle when bringing the accelerator pedal up than when compared to a "normal" car, or I need to be firmer with the
accelerator when changing gears ) or whether the accelerator pedal or some other aspect needs to be investigated.
I should point out, just in case it is related, that the mechanic also noticed a flat spot in the carburetor, and had a play date with it to get it
sorted. He was 90% happy with his work when I picked up the car, and said that if I had any problems with it that he'd get it sorted.
Oh, and thank you in advance for any replies, since I do appreciate it.
Gaston.
I hand out apologies like beating-red apples... Since trees can only bear fruit if it's root is planted in the soil of
sincerity.
psimitar
Threads: 148
| posted on December 22nd, 2015 at 08:29 PM |
Is it running a 009 dizzy?
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on December 22nd, 2015 at 11:14 PM |
Smoothest running for a stock 1600 Twin Port will be an SVDA Single Vacuum Dual Advance distributor. They are available new for about $180. The
original factory distributor for most 1971 1600's was vacuum only, no mechanichal advance. VW Australia replaced them under warranty they were so
bad. Been through it all with our 1971 1600 last year.
Gaston
| posted on December 23rd, 2015 at 01:15 PM |
Thanks psimitar and hellbus, I think the distributor is my problem.
Its running a 009 (Bosch 0 231 178 009), which with further investigation from here ( http://www.ratwell.com/technical/IgnitionSystem.html ), based on your comments, would explain why the accelerator pedal is
unhappy. The site also noted that it causes a flat spot near idle, which might be the culprit of the aforementioned flat spot.
So thanks for pointing me towards the distributor, and I will look into an SVDA single vacuum dual advance distributor for my little bug.
sincerity.
psimitar
Threads: 148
| posted on December 23rd, 2015 at 11:13 PM |
Cool beans dude
And just in case you wondered, cos it can confuse people, the DA of SVDA just means that the SV forms one of the advance mechanisms and the other is
formed my a mechanical advance mechanism but isn't part of the acronym
AA003
A.k.a.: Phill
Threads: 39
| posted on December 24th, 2015 at 09:29 AM |
I thought that SVDA was Single Vacuum Distributor Advance and DVDA was Dual Vacuum Distributor Advance? (But I am just guessing)
The dual vacuum distributors were a cheat to get around the Australian pollution laws. But Volkswagen wouldn't do that, would they?
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
psimitar
Threads: 148
| posted on December 24th, 2015 at 04:45 PM |
posted by AA003
well most people seem to refer to a vac and mech dizzy as being an SVDA these days. Whether or not it's the correct use of the term, who's to say?
yasdnil01
Threads: 33
Theme: UltimaBB Pro Orange
| posted on December 25th, 2015 at 01:22 PM |
have them also check the gearbox front trans mounts as that can cause the
car to jerk if old and perished as it rubs the gas peddle cable
Gaston
| posted on December 27th, 2015 at 07:10 PM |
Thanks yasdnil01, I'll be sure to take that into account when I go to the shop next. I'll take a look at the distributor first, mainly due to the
fact that it is an 009, and if that doesn't amend it the front trans mounts will be investigated.
Oh, and thanks again for all your help. Its been much appreciated.
sincerity.
