| [ Total Views: 1512 | Total Replies: 12 | Thread Id: 111414 ] |
fullnoise
Threads: 103
Mood: Middle of the road.
| posted on August 12th, 2016 at 08:44 AM |
Help. Has anyone got a M11 x 2.0 tap for seatbelt bolt threads?
About a 17 years ago I had anchor points welded into the C pillars of the oval. Now I've finally removed the roll bar and I'm putting seatbelt a in
the back.
It was really tricky to get the bolt to find its threads in the drivers side bolt. It took about half an hour. The passenger side has been even more
tricky. All I need is a tap to clean up the thread.
But despite the millions of cars driving around Aus wth these bolts nobody seems to have a tap for this unusual thread.
I can get one custom-made by Suttons tools in England which will take 9 weeks and cost $200. So I can use it once!
So does anyone have one I can borrow or rent and return?
I don't want to drill the bolt out to an M12 as it may cause safety issues for the cars future custodians.
CT
esratrams
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on August 12th, 2016 at 09:21 AM |
Standard seatbelt anchors in Australia are 7/16" UNF 20 T.P.I (11.11 mm x 1.27 pitch). Are you sure that you haven't got that size. If you had it
done around 2000 then it would have been done to the Australia Standard (ADR) of 7/16 UNF.
Quote of the week
Camo
A.k.a.: Kev
Threads: 209
| posted on August 12th, 2016 at 06:16 PM |
Hi CT,
Cant help you with one for a loan but found one here in Australia for $62 if you get desperate
https://www.bolt.com.au/m11-20-intermediate-high-speed-steel-tap-p-100034.html
Kev
AA003
A.k.a.: Phill
Threads: 39
| posted on August 12th, 2016 at 06:35 PM |
I think that I would prefer to use the correct tap.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on August 12th, 2016 at 07:33 PM |
You should use 7/16 UNF high tensile bolts, or else increase your public liability insurance, CT.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on August 12th, 2016 at 08:29 PM |
I'll look for that size in the cupboard tomorrow CT
fullnoise
Threads: 103
| posted on August 13th, 2016 at 09:11 AM |
Thanks for your help everyone.
I think Mackaymax is right. Thanks .
The tool shop I took the bolt to sent me down the wrong path by accident. It seems so much more logical that it's a common 7/16 UNF thread when you
consider how common seatbelt bolts are. I bought a 7/16 tap yesterday and I'll try it in the harness plates first.
CYA CT
esratrams
AA003
A.k.a.: Phill
Threads: 39
| posted on August 13th, 2016 at 11:13 AM |
If you did get a M11x2 tap, where would you get the bolts from anyway?
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on August 13th, 2016 at 11:29 AM |
Ol HappyDaze on the money again
vw54
| posted on August 13th, 2016 at 06:44 PM |
yeah 7/16 UNF thread I have tap and spare bolts CT if you need
hellbugged
A.k.a.: Daimo Pell
| posted on August 13th, 2016 at 07:58 PM |
7/16 unf yep
Got it,...
.....read the updated post....
.......put it back.....
......Jeff swore at you
psimitar
Threads: 148
| posted on August 13th, 2016 at 08:35 PM |
7/16 is almost exactly 11mm and as far as I know the 7/16 seat belt bolt size has been an worldwide standard since the 70's.
fullnoise
Threads: 103
| posted on August 16th, 2016 at 07:01 PM |
Yup 7/16 UNF. It was a bugger of a thread to fix. In fact it felt like I was taping an entirely new one. But it's good now.
Thanks everyone.
esratrams
