| [ Total Views: 681 | Total Replies: 6 | Thread Id: 112054 ] |
auditwmba
Threads: 10
posted on January 20th, 2017 at 07:43 PM |
WTB - Brake master cylinder connecting piece
Evening all,
I am seeking the connecting plug for a remote brake reservoir for a Country Buggy. The part number for item 10 on the picture is 114 611 395.
Rob
| Error |
2014 Skoda Octavia Elegance 110Tdi sedan
1968 VW Country buggy (KO 606)
steveo169
Threads: 18
Mood: moderate to south easterly
| posted on January 21st, 2017 at 11:33 AM |
Here
Comes with a nos cylinder
Good value
https://www.thesamba.com/vw/classifieds/detail.php?id=1895521
Steveo
auditwmba
Threads: 10
| posted on January 21st, 2017 at 12:11 PM |
Thanks steveo169,
The correct master cylinder (which I have) is a split kombi 22.2mm dia. and the plug screws into the cylinder whereas a beetle version is 19mm dia.
and is push-in.
Thanks anyway.
regards
Robert
southspark
Threads: 9
Mood: always helpful(not to dickheads)
| posted on January 21st, 2017 at 12:13 PM |
The rubber grommet is the same as any beetle, the steel tube is a push fit into it.
Regards Paul
southspark
Threads: 9
| posted on January 21st, 2017 at 12:18 PM |
Hindsight yes you are correct,splitty one is the one
Paul
bevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
| posted on January 21st, 2017 at 03:08 PM |
A County Buggy has a 22mm like a Kombi but the rubber seal like a beetle. They are unique. You have to make a screw in fitting to do the job.
auditwmba
Threads: 10
| posted on January 28th, 2017 at 10:18 AM |
Thanks for all responses.
Internet, overseas and best local sources came to nil. I followed advice from VVD and used Pirtek for a good solution.
regards
Rob
