| [ Total Views: 1571 | Total Replies: 4 | Thread Id: 112150 ] |
steveo169
Threads: 18
Mood: moderate to south easterly
| posted on February 13th, 2017 at 12:34 PM |
Speedo Cable length
Hi All
What speedo cable length do I need to get?
Beetle v bus and what length?
various lengths include
2450, 2060, 1390, 1235, 1590, 1530 and 1545 !!!!
C24-112-957-801-K - GERMAN QUALITY - 1590MM RHD from CIP is beetle
C24-112-957-801-J - GERMAN QUALITY -1530MM RHD (RIGHT HAND DRIVE ONLY) SPEEDOMETER CABLE 1545MM - STANDARD BEETLE 10/65-77(NOT SUPER)/ GHIA 10/65-71
SOLD EACH
APpreciate help
bevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
| posted on February 14th, 2017 at 09:40 AM |
Hi Steve
The cable is a CB only thing, longer than a beetle.
Get some 6mm black polly air line and use it to find th length, then get your cable man to make you one up. That's the best bet.
Tony
steveo169
Threads: 18
| posted on February 14th, 2017 at 03:47 PM |
Thanks Tony
Is there an obvious way or defined way the cable runs?
Anyone with a diagram or photo?
bevoracing
A.k.a.: Tony Beven
Threads: 36
| posted on March 10th, 2017 at 09:06 AM |
I just measured my speedo cable. It has a casing length of 2500mm exactly. I recon this one will do the job.
Bus (right hand drive only) 68 - 79 2520 long C24-214-957-801-H
https://www2.cip1.com/ProductDetails.asp?ProductCode=C24%2D214%2D957%2D801%2DH
Tony
steveo169
Threads: 18
| posted on March 10th, 2017 at 09:19 PM |
Thanks Tony
You have been a great help again. Always contributing and I appreciate the efforts to answer practically.
FYI the indicator switch from cip1 Was too small for the steering shaft diameter.
