| [ Total Views: 1092 | Total Replies: 5 | Thread Id: 112377 ] |
VWBoothy
Threads: 14
| posted on April 25th, 2017 at 11:05 AM |
Starting problem
Hey all. I got a quick question with my bug. When the pulley is at tdc it wont turn over at all, but if i rotate it 90 degrees or more it will turn
over. Also the motor is alot easier to turn by hand at tdc, but harder when you turn it 90 degrees or more. To me it sounds like maybe the flywheel or
maybe something internal on the motor. Do you have any idea what it could be? It has a brand new starter motor in it. New plugs belt and pulley. Any
help would be appreciated.
62' Beetle
vw54
| posted on April 25th, 2017 at 06:31 PM |
Check all your EARTH POINTS
Is it 6 volts ??? more info please
VWBoothy
Threads: 14
| posted on April 26th, 2017 at 06:54 AM |
Hey, i pulled the motor out. It was teeth missing on the flywheel. I must have the wrong flywheel on
62' Beetle
vw54
| posted on April 26th, 2017 at 07:27 AM |
or starter
bevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
| posted on April 26th, 2017 at 09:43 AM |
VW engines are always easier to rock at TDC. All pistons are either up or down. Very little piston movement, lots of leverage. No issue..
68AutoBug
| posted on June 4th, 2017 at 07:45 PM |
posted by VWBoothy
ODD one....
Was it the correct starter motor??
The teeth wouldn't have been missing when it was started last????
