| [ Total Views: 2314 | Total Replies: 12 | Thread Id: 175 ] |
geodon
Threads: 63
Mood: stumbling
| posted on August 28th, 2002 at 06:21 PM |
"engine-in" problems
Despite having done this dozens of times I cannot get this 1600TP back in my ghia.
I've had the evergreen problems of the crank pulley hooked under the rear lip & the R/H heater box stuck in the top corner.
I've removed the gen & manifold to get a bit more room.
I've got both bottom mounting bolts in & yes the mainshaft is in the hole but I can't push it in the last 40mm. It seems to be stuck on
the mainshaft because I can rock & sway the eng on its central axis. Yes I know about rotating the pulley to line up the splines.
Any ideas?
I'm nearly ready to use a length of three-eigths all-thread to pull it in!
type82e
Threads: 108
| posted on August 28th, 2002 at 08:59 PM |
is the clutch plate aligned?
if the isnt aligned properly it makes it difficult to get it in.
56astro
Threads: 74
| posted on August 28th, 2002 at 09:00 PM |
You sound like you know what you're doing, but when I was putting my engine in I was told to select top gear in an attempt to stop/restrict the
main shaft spinning.
35MPG on 101.3kPa
Menangler
A.k.a.: Dave Becker
Threads: 309
| posted on August 28th, 2002 at 09:07 PM |
You didn't leave the flywheel lock on did you?...don't laugh, Ive done that one before!!  |
Bizarre
| posted on August 28th, 2002 at 09:28 PM |
"flywheel lock" - call me a newbie but i dont understand?
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on August 28th, 2002 at 09:44 PM |
Flywheel locks are devices that bolt onto the case (using either one of the two lower engine mount studs, or a separate bolt through one of the top
mounting holes)...they mesh with the flywheel ring gear (teeth) and stops it from spinning when you torque up the gland nut that holds the flywheel on
type I engines.
geodon
Threads: 63
Mood: stumbling
| posted on August 29th, 2002 at 07:21 AM |
Sleepless night
I own 2 flywheel locks & I got them both on dismantling engines i have bought- a pleasant surprise. Also a couple of 17mm sockets left on the top
mounts! Yes clutch is alligned & engine is locked in gear. The only thing that came to me one night is that I adjusted the new clutch cable right
up tight to stop it falling off at the pedal end while I installed it- my better half refused to help hold it under tension so I had to improvise. I
may be trying to depress the clutch pressure plate as I install the engine. Can't check it out till the weekend- will keep you posted.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on August 29th, 2002 at 01:20 PM |
a swingaxle colleted pressure plate won't go in an IRS gearbox with the throw-out guide tube either. Just another thing to check.
geodon
Threads: 63
Mood: stumbling
| posted on August 29th, 2002 at 09:02 PM |
Gearbox
Thank you Wes but it's a 1500 non-IRS trans. I would have been quite happy with a 1200 engine but the flywheel was too narrow for the opening
hence the 1600 went in.
Bizarre
| posted on August 29th, 2002 at 09:39 PM |
posted by geodon
I would have been quite happy with a 1200 engine but the flywheel was too narrow for the opening hence the 1600 went in.
Yeah right....sure........
geodon
Threads: 63
Mood: stumbling
| posted on August 29th, 2002 at 09:51 PM |
Seriously....
I ran it with the 36hp for about 3 months but the starter didn't mesh- it worked by friction drive! The noise drive me crazy! (And scared the
crap out of admiring onlookers)
[Edited on 29-8-2002 by geodon]
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on August 30th, 2002 at 10:17 AM |
yeah last time i couldnt get it completely all the way, only about 5mm to go. I already had the car in gear handbrake on, i turned over the engine
and yep, the shaft was aligned.
So i just tightened up the bolts and that was that.
strange seeing every other time i was able to push it all the way in.
Jon
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on August 30th, 2002 at 10:30 AM |
you could use the 1200, you just have to use a 6V starter. To do that you'd need a special 12-6V adaptor bush for the gearbox. Should be able to
buy one or easily get one made / make one.
Bizarre
| posted on August 30th, 2002 at 10:59 AM |
posted by Baja Wes
Oh PLEASE.....C'mon Wes - just think about what you are saying
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on August 30th, 2002 at 11:50 AM |
well it'd be fuel economic
geodon
Threads: 63
Mood: stumbling
| posted on September 2nd, 2002 at 10:15 PM |
HOORAY!
The bugger is in! The problem was the clutch - I was trying to depress the pressure plate because I had it adjusted all the way till the thread ran
out. Why? Because I installed a new clutch cable solo ie with no one tugging at the transmission end to hold it on the hook. I managed to do it by
using one of the mounting screws on the dipper switch and a long cable tie to hold the clutch pedal fully depressed while I angled the pedal cluster
in & wound the adjustment as far as I could at the other end. Then I forgot about it. Oh well all part of the rich tapestry blah blah etc
