[ Total Views: 708 | Total Replies: 7 | Thread Id: 18738 ]
Author: Subject: turbo charging a vw
MemberBJ
Threads: 48
Mood: COOL
posted on February 9th, 2004 at 04:52 PM
turbo charging a vw
Currently have a twin port in my a baja and was thinking of rebuilding a single port and fitting a turbo. Just to get the right set up before fitting to the twin port. just a few questions on which way I should go. Suc or blow through carby. If the 1600 sp goes alright would probably leave in car. Any idea on carbi selection curreently havew bug spray but not sure if this will handle boost / greater vacuum. Orginally i was from a holden background and have though about jetting (modifing) a 350 holley to suit with the turbo. Any ideas would be greatly appreciated.
MemberAndy42
Threads: 47
Mood: 2.5t Subi Powered
posted on February 9th, 2004 at 05:02 PM
i have a turbo on a 1600 tp with a single throat stromberg on it. It is a rajay turbo Not sure how it goes yet as i have not realy run it myself but I am told it went pretty hard. I am planning on going for a side draft webber if I decide to keep the buggy. Should be good to test out in a couple of weeks:D
Membershiftyvw
Threads: 44
posted on February 9th, 2004 at 06:46 PM
CArby
Weber DMTT. Made by weber for blowthrough turbo appications, I have one I may sell if your interested. very rare apparently. call 0413 266 808 if you're intersted.
Membertassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
Mood: Moody!
posted on February 9th, 2004 at 07:03 PM
Shifty
U Have U2U
L8tr
E
Im not a complete idiot, quite a few parts are missing....
MemberFlintstones
Threads: 69
posted on February 9th, 2004 at 08:59 PM
you can even look at a 2" SU carby.
MemberRota_Motor
Threads:
posted on February 9th, 2004 at 09:55 PM
inject it :)
well I wouldm, by the time you screw around with jets and all the time, you go buy a EA falcon CFI throttlebody which comes with injectors and inbvuilt fuel pressure regulator for $100, second hand ECU to run it for $500 or so, and it prolly costs only an extra $1000 plus dyno time if you want it tuned for you.
failing that, I woukld personally go the extra hassle of the blothru setup, then you can intercool it easily.
Membermatara
Threads: 255
Mood: 356'd
This is Shimo of Hellbugs Kit
I have a kit that Shimo of Hellbug developed. It uses the Weber DMTT carby that shiftyVW has for sale. Turbo sits underneath the rear parcel tray next to the gearbox. Good for 14.2 secs with 1835cc and stock internals (yes no special cranks rods or heads!!).
Membershiftyvw
Threads: 44
posted on February 15th, 2004 at 08:43 PM
How fast do you want to go?
MemberBiggus
posted on February 15th, 2004 at 10:34 PM
And how much do you want to spend?
