| [ Total Views: 893 | Total Replies: 17 | Thread Id: 20841 ] |
cumonghia
Threads: 26
| posted on March 29th, 2004 at 06:58 PM |
rust prootfing
I want to rust proof my karmann. The left hand heater channel was pretty rotton, the outer was replaced and a new reinforcing was welded in. its a
convertible. the right was never opened up and Im preying its not as bad as the left, because the car has just been painted. I know it was silly to go
ahead with the paint, and not look inside the other channel, but most of the rust for some reason was on the left hand side of the car.
Anyway, assuming there is still rust lurking in there some where, how long will rust proofing the car hold this at bay? can the insides be blasted
with rust converter first and then rust proofed? what about electronic rust proofing?
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on March 29th, 2004 at 07:13 PM |
check out the range of POR-15 stuff....
http://www.ppc.com.au i think...
68AutoBug
posted on March 29th, 2004 at 07:19 PM |
FISH OIL is the way to go.... Lee
Fish oil is the best anti rust agent.. its inexpensive.. runs everywhere... can apply with spray gun, brush or squeeze trigger sprayer..
Lasts forever.. it just seals the metal & keeps the air & water away from the metal. It used to smell like fish for a long time, but nowdays
You can buy deodorised fish oil.. Don't buy the el cheapo stuff its no good.
Motorpro or Killrust etc are good brands... If You fish oil a rusted piece of metal, it won't rust any more.... just make sure the fish oil
doesn't get wet while its drying. The drying time varies according to the air temperature.. One or two days in the hot summer.. maybe up to a week
or longer during the winter... I have been using it since 1968....
and highly recommend it.. You can apply it again & again over the years and it just builds up.... its very runny so it gets into joins in the
metal etc...
cumonghia
Threads: 26
| posted on March 29th, 2004 at 07:25 PM |
thanks for that youve sold me. How can I saturate this stuff right through the heater channels now there all closed up?
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on March 29th, 2004 at 08:16 PM |
Probly like they do on other cars drill holes spray in and plug holes with rubber plugs,but im only guessin dude goodluck. |
68AutoBug
| posted on April 3rd, 2004 at 11:16 AM |
Can You get it into the heater outlets near the floor?
and take the rear seat out.. and in later beetles there are holres that go into the heater channels. I don't know why these holes are there, but if
they aren't in Your car, You can also drill holes and use a blanking off rubber grommet afterwards....
Motorpro make a pressure pack can of Fish oil, so You can squirt away to Your hearts content.... Remember that You can't use too much... it doesn't
hurt anything... its just like oil but dries... when You spray inside the doors, the excess will just come out the drain holes... leave the doors
open...
You can remove it with turps or maybe it was thinners.... probably kerosene would remove it also... within a few weeks.. after that it sets hard...
its great stuff...
Just remember, the cheap pressure pack $3 -$4 stuff isn't any good....
| Error |
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on April 3rd, 2004 at 06:24 PM |
You can get a gun with a hose on the end of it. They are not very expensive only about $20. The fish oil comes in a litre can and the gun screws in
the top.
Yeah drill 13mm (1/2 inch) holes and put the hose inside, then squirt away and put grommets in the holes.
The left side of most cars rusts first, because a car spends a bit of it's time parked on the road and the car will lean to the left. This means more
often the water will run to the left side of the car. Therefore rust left first.
cumonghia
Threads: 26
| posted on April 13th, 2004 at 06:09 PM |
Thanks guys
where do I drill the holes? under the sill? wont weaken it will it?
68AutoBug
posted on April 13th, 2004 at 08:04 PM |
Pressure Pack deodorised fish oil **
I would drill into the heater channel under the rear seat ..
but a 1/2 inch hole isn't going to hurt anything...
I also sprayed heaps of fish oil into the heater outlets on the floor in the front.... another trick, is to use a pressure pack can with the small
nozzle and stick the nozzle under the windscreen rubber on the top and let the fish oil stop any corrosion going on under the rubber... The rear
window rubber is probably more important, as they are prone to rust under the rubber... as I said, it doesn't hurt anything... and You can wipe away
the excess with a Rag... it takes a while to dry... different brands seem to differ with their drying time.. also depends whether its just a fine
coat or 3mm thick..
and the temperature plays its part too...
Don't forget.. don't let the fish oil get wet before its dry..
Although I have used a paint brush & 4 litres of fish oil on My car plus 4 large pressure pack cans, the pressure packs are probably the best , as
You only need a 5mm hole to put the nozzle thru and it really sprays a fine mist everywhere....
I See Big W have PowerPlus Fish Oil & Auto One have their own brand & Motorpro also... around $7 -$9 a can..
They is also rust inhibiting additives in fish oil these days.. and not much smell.... not like in the 60s... Car used to smell like a fish shop for 6
months... You were lucky that the cats didn't eat Your Mud Flaps..!!
regards
aggri1
A.k.a.: Aurel Griesser
Threads: 35
Mood: ska'd for life
| posted on April 17th, 2004 at 01:46 PM |
Cool. That's all really helpful, thanks guys! I've been wondering the same kinda thing recently (got a Bay though).
Aurel
cumonghia
Threads: 26
| posted on April 22nd, 2004 at 05:49 PM |
can you paint over dry fish oil?
mnsKmobi
Threads: 27
| posted on April 23rd, 2004 at 01:26 PM |
posted by cumonghia
Yes. It doesn't really totally dry just gets less sticky after a couple of days depending on the temp.
I used Kill Rust primer over Kill Rust fish oil with no probs. This also stopped any lingering fish smell.
BiX
Threads: 154
| posted on April 23rd, 2004 at 01:29 PM |
what baout lanolin? i have heard its pretty good?
Go hard or go home!!!!
aggri1
Threads: 35
| posted on April 26th, 2004 at 02:31 PM |
Can you buy liquid fish oil (ie - not in a spray can: I realise that I sound daft, I'm used to it) and then use one of those garden hand water
sprayer bottle things? That would seem like a cheaper larger-scale option?
Also, if this scheme would work, any ideas where this material (the 'liquid' fish oil) is obtainable?
Aurel
PS: I'm not sure if I'm 'hijacking' (?) the post, sorry if so...
Anthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
| posted on April 26th, 2004 at 02:41 PM |
auto one and probobly supercheap should have it....i have definatly seen it in auto one
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
PurpleT3
Threads: 55
Mood: knackered
| posted on April 26th, 2004 at 04:46 PM |
I bought a 1L can of deodorised fish oil from Milsom's Auto Paints in Ferntree gully. Under $20.
I've also thought about the using one of the pump up type of gardening spray bottles. Attach a flexible tube to the bottle, insert a spray nozzle in
the tube, feed tube into heater channel. Fill bottle with fish oil, pump up the bottle, pull the trigger and drag the tube through the channel. Hey
presto, fish oil sprayed all along the length of the cavity and no drilling holes.
There may be some technical details to be worked out, but I'll get there one day.
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on June 28th, 2004 at 12:40 PM |
so... how did it all go PurpleT3?
PurpleT3
Threads: 55
Mood: knackered
| posted on June 28th, 2004 at 01:11 PM |
Ahhh. Haven't got there yet. Now you've reminded me, I might have to have go at it.
aggri1
Threads: 35
| posted on June 28th, 2004 at 01:15 PM |
Hi there.'
Well I ended up getting an aerosol spray of fish oil. It wasn't meant to be the ultimate in long term protection, but should help for now... budget
stuff, see.
Sure is smelly, even deodorised. Luckily I won't be needing the car for the next two weeks.
I sprayed under the car, into the chassis rails and all the holes I could find down there. One can did moderate coverage between the axles, but I put
a fair bit into the sealed sections. I also gave the battery trays a go. Couldn't do up front nor a few inside spots because I ran out.
I spent the morning getting bruised and sore fingers from cleaning dirt out of holes with wire, and brushing off the underside (which was still quite
clean).
See how it goes hey?
Aurel
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on June 28th, 2004 at 01:18 PM |
PurpleT3 - hahaha get busy! *whip!*
